pure-ftp не работает
Здравствуйте! получаю ошибку ftp: connect: Connection refused понимаю она может связана с чем угодно, вот мой /etc/pure-ftpd/db/mysql.conf файл автор############################################## # # # Sample Pure-FTPd Mysql configuration file. # # See README.MySQL for explanations. # # # ############################################## # Optional : MySQL server name or IP. Don't define this for unix sockets. MYSQLServer 127.0.0.1 # Optional : MySQL port. Don't define this if a local unix socket is used. # MYSQLPort 3306 # Optional : define the location of mysql.sock if the server runs on this host. # MYSQLSocket /var/run/mysqld/mysqld.sock # Mandatory : user to bind the server as. MYSQLUser ispconfig # Mandatory : user password. You must have a password. MYSQLPassword 91c0eb614c5c46ff1fe6d7f89baa56d3 # Mandatory : database to open. MYSQLDatabase dbispconfig # Mandatory : how passwords are stored # Valid values are : "cleartext", "crypt", "md5" and "password" # ("password" = MySQL password() function) # You can also use "any" to try "crypt", "md5" *and* "password" MYSQLCrypt crypt # In the following directives, parts of the strings are replaced at # run-time before performing queries : # # \L is replaced by the login of the user trying to authenticate. # \I is replaced by the IP address the user connected to. # \P is replaced by the port number the user connected to. # \R is replaced by the IP address the user connected from. # \D is replaced by the remote IP address, as a long decimal number. # # Very complex queries can be performed using these substitution strings, # especially for virtual hosting. # Query to execute in order to fetch the password MYSQLGetPW SELECT password FROM ftp_user WHERE active = 'y' AND server_id = '1' AND username="\L" # Query to execute in order to fetch the system user name or uid MYSQLGetUID SELECT uid FROM ftp_user WHERE active = 'y' AND server_id = '1' AND username="\L" # Optional : default UID - if set this overrides MYSQLGetUID #MYSQLDefaultUID 1000 # Query to execute in order to fetch the system user group or gid MYSQLGetGID SELECT gid FROM ftp_user WHERE active = 'y' AND server_id = '1' AND username="\L" # Optional : default GID - if set this overrides MYSQLGetGID #MYSQLDefaultGID 1000 # Query to execute in order to fetch the home directory MYSQLGetDir SELECT dir FROM ftp_user WHERE active = 'y' AND server_id = '1' AND username="\L" # Optional : query to get the maximal number of files # Pure-FTPd must have been compiled with virtual quotas support. MySQLGetQTAFS SELECT quota_files FROM ftp_user WHERE active = 'y' AND server_id = '1' AND quota_files != '-1' AND username="\L" # Optional : query to get the maximal disk usage (virtual quotas) # The number should be in Megabytes. # Pure-FTPd must have been compiled with virtual quotas support. MySQLGetQTASZ SELECT quota_size FROM ftp_user WHERE active = 'y' AND server_id = '1' AND quota_files != '-1' AND username="\L" # Optional : ratios. The server has to be compiled with ratio support. MySQLGetRatioUL SELECT ul_ratio FROM ftp_user WHERE active = 'y' AND server_id = '1' AND quota_files != '-1' AND username="\L" MySQLGetRatioDL SELECT dl_ratio FROM ftp_user WHERE active = 'y' AND server_id = '1' AND quota_files != '-1' AND username="\L" # Optional : bandwidth throttling. # The server has to be compiled with throttling support. # Values are in KB/s . MySQLGetBandwidthUL SELECT ul_bandwidth FROM ftp_user WHERE active = 'y' AND server_id = '1' AND quota_files != '-1' AND username="\L" MySQLGetBandwidthDL SELECT dl_bandwidth FROM ftp_user WHERE active = 'y' AND server_id = '1' AND quota_files != '-1' AND username="\L" # Enable ~ expansion. NEVER ENABLE THIS BLINDLY UNLESS : # 1) You know what you are doing. # 2) Real and virtual users match. # MySQLForceTildeExpansion 1 # If you upgraded your tables to transactionnal tables (Gemini, # BerkeleyDB, Innobase...), you can enable SQL transactions to # avoid races. Leave this commented if you are using the # traditionnal MyIsam databases or old (< 3.23.x) MySQL versions. MySQLTransactions On и вот мой /etc/default/pure-ftpd-common файл автор# Configuration for pure-ftpd # (this file is sourced by /bin/sh, edit accordingly) # STANDALONE_OR_INETD # valid values are "standalone" and "inetd". # Any change here overrides the setting in debconf. STANDALONE_OR_INETD=standalone # VIRTUALCHROOT: # whether to use binary with virtualchroot support # valid values are "true" or "false" # Any change here overrides the setting in debconf. VIRTUALCHROOT=true # UPLOADSCRIPT: if this is set and the daemon is run in standalone mode, # pure-uploadscript will also be run to spawn the program given below # for handling uploads. see /usr/share/doc/pure-ftpd/README.gz or # pure-uploadscript(8) # example: UPLOADSCRIPT=/usr/local/sbin/uploadhandler.pl UPLOADSCRIPT= # if set, pure-uploadscript will spawn $UPLOADSCRIPT running as the # given uid and gid UPLOADUID= UPLOADGID= Также я добавил симлинк ln -sf /usr/sbin/pure-ftpd-mysql /usr/sbin/pure-ftpd Потомучто получал ошибку: Can't exec "/usr/sbin/pure-ftpd": No such file or directory at /usr/sbin/pure-ftpd-wrapper line 174. В каком направлении копать? ... |
| 20.11.2010, 15:57:17 |
Проверь нетстатом, слушает ли оно порт. ... |
| 20.11.2010, 16:39:22 |
netstat -ap | grep "pure-ftpd" пусто ... |
| 20.11.2010, 18:23:45 |
a netstat -a | grep :21 ? ... |
| 20.11.2010, 19:01:16 |
Бамбукъa netstat -a | grep :21 ? тоже пусто оно вроде запускается, но нет, и логов нету Код: plaintext 1. 2. Код: plaintext 1. 2. ... |
| 20.11.2010, 19:26:02 |
start [/forum/topic.php?desktop=1&fid=25&tid=1484589]: |
25ms |
49ms |
80ms |
| others: | 314ms |
| total: | 526ms |
