PUTTy: как заставить его показывать IP-адрес сервера в title bar'e ?
Всем привет. Сабж. ... |
| 20.10.2010, 18:55:32 |
4.9.1 Controlling the window titleThe ‘Window title’ edit box allows you to set the title of the PuTTY window. By default the window title will contain the host name followed by ‘PuTTY’, for example server1.example.com - PuTTY. If you want a different window title, this is where to set it. PuTTY allows the server to send xterm control sequences which modify the title of the window in mid-session (unless this is disabled - see section 4.6.5); the title string set here is therefore only the initial window title. As well as the window title, there is also an xterm sequence to modify the title of the window's icon. This makes sense in a windowing system where the window becomes an icon when minimised, such as Windows 3.1 or most X Window System setups; but in the Windows 95-like user interface it isn't as applicable. By default, PuTTY only uses the server-supplied window title, and ignores the icon title entirely. If for some reason you want to see both titles, check the box marked ‘Separate window and icon titles’. If you do this, PuTTY's window title and Taskbar caption will change into the server-supplied icon title if you minimise the PuTTY window, and change back to the server-supplied window title if you restore it. (If the server has not bothered to supply a window or icon title, none of this will happen.) ... |
| 20.10.2010, 19:34:37 |
Андрей Панфилов[quot 4.9.1 Controlling the window title]The ‘Window title’ edit box allows you to set the title of the PuTTY window. By default the window title will contain the host name followed by ‘PuTTY’Это не очень удобно. Может ли путти сам брать этот адрес из Session-настроек ? ведь он там уже есть, зачем его дублировать в Window title ? ... |
| 20.10.2010, 20:22:09 |
.nix newbie, написано же: по-умолчанию в окне и так имя хоста пишется, дальше Ваш линукс судя по всему сам меняет заголовок, можете проверить: Код: plaintext 1. 2. у нас на линуксах это дло вот так автоматизируется: Код: plaintext ... |
| 20.10.2010, 21:38:51 |
start [/forum/topic.php?desktop=1&fid=25&tid=1484575]: |
33ms |
49ms |
| others: | 293ms |
| total: | 429ms |
