Как скомпилировать squashfs?
Уважаемые линуксоиды, помогите скомпилировать своими руками squashfs на Ubuntu. авторuser@user-ubuntu:~/squashfs4.1/squashfs-tools$ make install cc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -DCOMP_DEFAULT=\"gzip\" -O2 -Wall -DGZIP_SUPPORT -DXATTR_SUPPORT -DXATTR_DEFAULT -c -o mksquashfs.o mksquashfs.c cc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -DCOMP_DEFAULT=\"gzip\" -O2 -Wall -DGZIP_SUPPORT -DXATTR_SUPPORT -DXATTR_DEFAULT -c -o read_fs.o read_fs.c cc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -DCOMP_DEFAULT=\"gzip\" -O2 -Wall -DGZIP_SUPPORT -DXATTR_SUPPORT -DXATTR_DEFAULT -c -o sort.o sort.c cc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -DCOMP_DEFAULT=\"gzip\" -O2 -Wall -DGZIP_SUPPORT -DXATTR_SUPPORT -DXATTR_DEFAULT -c -o swap.o swap.c cc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -DCOMP_DEFAULT=\"gzip\" -O2 -Wall -DGZIP_SUPPORT -DXATTR_SUPPORT -DXATTR_DEFAULT -c -o pseudo.o pseudo.c cc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -DCOMP_DEFAULT=\"gzip\" -O2 -Wall -DGZIP_SUPPORT -DXATTR_SUPPORT -DXATTR_DEFAULT -c -o compressor.o compressor.c cc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -DCOMP_DEFAULT=\"gzip\" -O2 -Wall -DGZIP_SUPPORT -DXATTR_SUPPORT -DXATTR_DEFAULT -c -o gzip_wrapper.o gzip_wrapper.c gzip_wrapper.c:23:18: error: zlib.h: No such file or directory gzip_wrapper.c: In function ‘gzip_compress’: gzip_wrapper.c:29: error: ‘z_stream’ undeclared (first use in this function) gzip_wrapper.c:29: error: (Each undeclared identifier is reported only once gzip_wrapper.c:29: error: for each function it appears in.) gzip_wrapper.c:29: error: ‘stream’ undeclared (first use in this function) gzip_wrapper.c:35: error: ‘Z_NULL’ undeclared (first use in this function) gzip_wrapper.c:39: warning: implicit declaration of function ‘deflateInit’ gzip_wrapper.c:39: error: ‘Z_OK’ undeclared (first use in this function) gzip_wrapper.c:41: warning: implicit declaration of function ‘deflateReset’ gzip_wrapper.c:49: warning: implicit declaration of function ‘deflate’ gzip_wrapper.c:49: error: ‘Z_FINISH’ undeclared (first use in this function) gzip_wrapper.c:50: error: ‘Z_STREAM_END’ undeclared (first use in this function) gzip_wrapper.c: In function ‘gzip_uncompress’: gzip_wrapper.c:75: warning: implicit declaration of function ‘uncompress’ gzip_wrapper.c:79: error: ‘Z_OK’ undeclared (first use in this function) make: *** [gzip_wrapper.o] Error 1 Что конкретно надо СДЕЛАТЬ, чтобы оно со 100% вероятностью скомпилировалось? ... |
| 04.05.2011, 23:51:34 |
BPKУважаемые линуксоиды, помогите скомпилировать своими руками squashfs на Ubuntu. Главное в убунту никогда ничего не пытаться компилировать и верить в Шаттлворта. попробуй такую команду : modprobe squashfs все само подключится. ... |
| 05.05.2011, 00:26:16 |
On 05.05.2011 1:26, netwind wrote: > Главное в убунту никогда ничего не пытаться компилировать и верить в Шаттлворта. Ага, вот оно что... а я-то, дурак, компилил ... (товарищъ как бэ намекает, что оно там уже вполне возможно стоит). Posted via ActualForum NNTP Server 1.4 ... |
| 05.05.2011, 00:40:40 |
MasterZiv> Главное в убунту никогда ничего не пытаться компилировать и верить в Шаттлворта. Ага, вот оно что... а я-то, дурак, компилил ... (товарищъ как бэ намекает, что оно там уже вполне возможно стоит). истинно так! говорю вам! надысь вот решил ведро покомпилить, а оказалось то, что в backports вполне работает и все новое оборудование видит. ... |
| 05.05.2011, 00:43:46 |
netwindmodprobe squashfs Сделал. Фиг поймёшь, выполнилось или нет. Судя по такому результату: Код: plaintext 1. 2. 3. 4. modprobe скорее всего не сработала. Блин, почему в Linux ни одна программа не начинает работать с первого раза?!! Постоянно какие-то косяки. ... |
| 05.05.2011, 00:59:23 |
BPKnetwindmodprobe squashfs Сделал. Фиг поймёшь, выполнилось или нет. достаточно проверить список поддерживаемых файловых систем в ядре cat /proc/filesystems | grep squa после modprobe должна добавиться ... |
| 05.05.2011, 01:10:04 |
On 05.05.2011 1:59, BPK wrote: > Блин, почему в Linux ни одна программа не начинает работать с первого раза?!! Традиция ... Posted via ActualForum NNTP Server 1.4 ... |
| 05.05.2011, 02:06:51 |
BPKБлин, почему в Linux ни одна программа не начинает работать с первого раза?!! Постоянно какие-то косяки. 1. Не косяки, а фичи! 2. Линукс система для истинных программистов!! 3. Неудачники перекочевывают в виндовс!!! ... |
| 05.05.2011, 14:31:33 |
start [/forum/topic.php?desktop=1&fid=25&tid=1484263]: |
53ms |
140ms |
488ms |
| others: | 445ms |
| total: | 1174ms |
