akmodsbuild error after upgrade FC14 -> FC15
Dell Studio 1555 (Wireless WLAN 1397 Half MiniCard (4312bg)) Попытался Код: plaintext 1. + exit 0 Executing(%build): /bin/sh -e /var/tmp/rpm-tmp.JkFSRQ + umask 022 + cd /tmp/akmodsbuild.fsXThrrl//BUILD + cd wl-kmod-5.100.82.38 + for kernel_version in 2.6.38.6-27.fc15.i686.PAE___/usr/src/kernels/2.6.38.6-27.fc15.i686.PAE + pushd _kmod_build_2.6.38.6-27.fc15.i686.PAE /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38 ++ pwd + make -C /usr/src/kernels/2.6.38.6-27.fc15.i686.PAE M=/tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE modules make: Entering directory `/usr/src/kernels/2.6.38.6-27.fc15.i686.PAE' CC [M] /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE/src/shared/linux_osl.o CC [M] /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE/src/wl/sys/wl_linux.o /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE/src/wl/sys/wl_linux.c: In function 'wl_attach': /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE/src/wl/sys/wl_linux.c:487:3: error: implicit declaration of function 'init_MUTEX' [-Werror=implicit-function-declaration] cc1: some warnings being treated as errors make[1]: *** [/tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE/src/wl/sys/wl_linux.o] Error 1 make: *** [_module_/tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE] Error 2 make: Leaving directory `/usr/src/kernels/2.6.38.6-27.fc15.i686.PAE' error: Bad exit status from /var/tmp/rpm-tmp.JkFSRQ (%build) RPM build errors: user mockbuild does not exist - using root group mockbuild does not exist - using root user mockbuild does not exist - using root group mockbuild does not exist - using root user mockbuild does not exist - using root group mockbuild does not exist - using root user mockbuild does not exist - using root group mockbuild does not exist - using root user mockbuild does not exist - using root group mockbuild does not exist - using root Bad exit status from /var/tmp/rpm-tmp.JkFSRQ (%build) 04 Jun 07:45:31 akmodsbuild: * Rebuilding /usr/src/akmods/wl-kmod.latest for kernel(s) 2.6.38.6-27.fc15.i686.PAE: warning: user mockbuild does not exist - using root 04 Jun 07:45:31 akmodsbuild: warning: group mockbuild does not exist - using root 04 Jun 07:45:31 akmodsbuild: warning: user mockbuild does not exist - using root 04 Jun 07:45:31 akmodsbuild: warning: group mockbuild does not exist - using root 04 Jun 07:45:31 akmodsbuild: warning: user mockbuild does not exist - using root 04 Jun 07:45:31 akmodsbuild: warning: group mockbuild does not exist - using root 04 Jun 07:45:31 akmodsbuild: warning: user mockbuild does not exist - using root 04 Jun 07:45:31 akmodsbuild: warning: group mockbuild does not exist - using root 04 Jun 07:45:31 akmodsbuild: warning: user mockbuild does not exist - using root 04 Jun 07:45:31 akmodsbuild: warning: group mockbuild does not exist - using root 04 Jun 07:45:31 akmodsbuild: Installing /usr/src/akmods/wl-kmod.latest 04 Jun 07:45:31 akmodsbuild: Building target platforms: i686 04 Jun 07:45:31 akmodsbuild: Building for target i686 04 Jun 07:45:31 akmodsbuild: Executing(%prep): /bin/sh -e /var/tmp/rpm-tmp.TS1s9k 04 Jun 07:45:31 akmodsbuild: + umask 022 04 Jun 07:45:31 akmodsbuild: + cd /tmp/akmodsbuild.fsXThrrl//BUILD 04 Jun 07:45:31 akmodsbuild: + kmodtool --target i686 --repo rpmfusion --kmodname wl-kmod --filterfile /tmp/akmodsbuild.fsXThrrl/SOURCES/broadcom-wl-kmodtool-excludekernel-filterfile --for-kernels 2.6.38.6-27.fc15.i686.PAE 04 Jun 07:45:31 akmodsbuild: %package -n kmod-wl-2.6.38.6-27.fc15.i686.PAE 04 Jun 07:45:31 akmodsbuild: Summary: wl kernel module(s) for 2.6.38.6-27.fc15.i686.PAE 04 Jun 07:45:31 akmodsbuild: Group: System Environment/Kernel 04 Jun 07:45:31 akmodsbuild: Provides: kernel-modules-for-kernel = 2.6.38.6-27.fc15.i686.PAE 04 Jun 07:45:31 akmodsbuild: Provides: wl-kmod = %{?epoch:%{epoch}:}%{version}-%{release} 04 Jun 07:45:31 akmodsbuild: Requires: wl-kmod-common >= %{?epoch:%{epoch}:}%{version} 04 Jun 07:45:31 akmodsbuild: Requires(post): /sbin/depmod 04 Jun 07:45:31 akmodsbuild: Requires(postun): /sbin/depmod 04 Jun 07:45:31 akmodsbuild: Requires: kernel-uname-r = 2.6.38.6-27.fc15.i686.PAE 04 Jun 07:45:31 akmodsbuild: BuildRequires: kernel-devel-uname-r = 2.6.38.6-27.fc15.i686.PAE 04 Jun 07:45:31 akmodsbuild: %post -n kmod-wl-2.6.38.6-27.fc15.i686.PAE 04 Jun 07:45:31 akmodsbuild: /sbin/depmod -aeF /boot/System.map-2.6.38.6-27.fc15.i686.PAE 2.6.38.6-27.fc15.i686.PAE > /dev/null || : 04 Jun 07:45:31 akmodsbuild: %postun -n kmod-wl-2.6.38.6-27.fc15.i686.PAE 04 Jun 07:45:31 akmodsbuild: /sbin/depmod -aF /boot/System.map-2.6.38.6-27.fc15.i686.PAE 2.6.38.6-27.fc15.i686.PAE &> /dev/null || : 04 Jun 07:45:31 akmodsbuild: 04 Jun 07:45:31 akmodsbuild: %description -n kmod-wl-2.6.38.6-27.fc15.i686.PAE 04 Jun 07:45:31 akmodsbuild: This package provides the wl kernel modules built for the Linux 04 Jun 07:45:31 akmodsbuild: kernel 2.6.38.6-27.fc15.i686.PAE for the %{_target_cpu} family of processors. 04 Jun 07:45:31 akmodsbuild: %files -n kmod-wl-2.6.38.6-27.fc15.i686.PAE 04 Jun 07:45:31 akmodsbuild: %defattr(644,root,root,755) 04 Jun 07:45:31 akmodsbuild: /lib/modules/2.6.38.6-27.fc15.i686.PAE/extra/wl/ 04 Jun 07:45:31 akmodsbuild: 04 Jun 07:45:31 akmodsbuild: 04 Jun 07:45:31 akmodsbuild: 04 Jun 07:45:31 akmodsbuild: %define kmodinstdir_prefix /lib/modules/ 04 Jun 07:45:31 akmodsbuild: %define kmodinstdir_postfix /extra/wl/ 04 Jun 07:45:31 akmodsbuild: %define kernel_versions 2.6.38.6-27.fc15.i686.PAE___%{_usrsrc}/kernels/2.6.38.6-27.fc15.i686.PAE 04 Jun 07:45:31 akmodsbuild: 04 Jun 07:45:31 akmodsbuild: + cd /tmp/akmodsbuild.fsXThrrl/BUILD 04 Jun 07:45:31 akmodsbuild: + rm -rf wl-kmod-5.100.82.38 04 Jun 07:45:31 akmodsbuild: + /bin/mkdir -p wl-kmod-5.100.82.38 04 Jun 07:45:31 akmodsbuild: + cd wl-kmod-5.100.82.38 04 Jun 07:45:31 akmodsbuild: + /bin/chmod -Rf a+rX,u+w,g-w,o-w . 04 Jun 07:45:31 akmodsbuild: + mkdir wl-kmod-5.100.82.38-src 04 Jun 07:45:31 akmodsbuild: + pushd wl-kmod-5.100.82.38-src 04 Jun 07:45:31 akmodsbuild: /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/wl-kmod-5.100.82.38-src /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38 04 Jun 07:45:31 akmodsbuild: + tar xzf /tmp/akmodsbuild.fsXThrrl/SOURCES/hybrid-portsrc_x86_32-v5_100_82_38.tar.gz 04 Jun 07:45:31 akmodsbuild: + echo 'Patch #0 (broadcom-wl-5.100.82.38-license.patch):' 04 Jun 07:45:31 akmodsbuild: Patch #0 (broadcom-wl-5.100.82.38-license.patch): 04 Jun 07:45:31 akmodsbuild: + /bin/cat /tmp/akmodsbuild.fsXThrrl/SOURCES/broadcom-wl-5.100.82.38-license.patch 04 Jun 07:45:31 akmodsbuild: + /usr/bin/patch -s -p1 -b --suffix .license --fuzz=0 04 Jun 07:45:31 akmodsbuild: + popd 04 Jun 07:45:31 akmodsbuild: /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38 04 Jun 07:45:31 akmodsbuild: + for kernel_version in 2.6.38.6-27.fc15.i686.PAE___/usr/src/kernels/2.6.38.6-27.fc15.i686.PAE 04 Jun 07:45:31 akmodsbuild: + cp -a wl-kmod-5.100.82.38-src _kmod_build_2.6.38.6-27.fc15.i686.PAE 04 Jun 07:45:31 akmodsbuild: + exit 0 04 Jun 07:45:31 akmodsbuild: Executing(%build): /bin/sh -e /var/tmp/rpm-tmp.JkFSRQ 04 Jun 07:45:31 akmodsbuild: + umask 022 04 Jun 07:45:31 akmodsbuild: + cd /tmp/akmodsbuild.fsXThrrl//BUILD 04 Jun 07:45:31 akmodsbuild: + cd wl-kmod-5.100.82.38 04 Jun 07:45:31 akmodsbuild: + for kernel_version in 2.6.38.6-27.fc15.i686.PAE___/usr/src/kernels/2.6.38.6-27.fc15.i686.PAE 04 Jun 07:45:31 akmodsbuild: + pushd _kmod_build_2.6.38.6-27.fc15.i686.PAE 04 Jun 07:45:31 akmodsbuild: /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38 04 Jun 07:45:31 akmodsbuild: ++ pwd 04 Jun 07:45:31 akmodsbuild: + make -C /usr/src/kernels/2.6.38.6-27.fc15.i686.PAE M=/tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE modules 04 Jun 07:45:31 akmodsbuild: make: Entering directory `/usr/src/kernels/2.6.38.6-27.fc15.i686.PAE' 04 Jun 07:45:31 akmodsbuild: CC [M] /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE/src/shared/linux_osl.o 04 Jun 07:45:31 akmodsbuild: CC [M] /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE/src/wl/sys/wl_linux.o 04 Jun 07:45:31 akmodsbuild: /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE/src/wl/sys/wl_linux.c: In function 'wl_attach': 04 Jun 07:45:31 akmodsbuild: /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE/src/wl/sys/wl_linux.c:487:3: error: implicit declaration of function 'init_MUTEX' [-Werror=implicit-function-declaration] 04 Jun 07:45:31 akmodsbuild: cc1: some warnings being treated as errors 04 Jun 07:45:31 akmodsbuild: 04 Jun 07:45:32 akmodsbuild: make[1]: *** [/tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE/src/wl/sys/wl_linux.o] Error 1 04 Jun 07:45:32 akmodsbuild: make: *** [_module_/tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE] Error 2 04 Jun 07:45:32 akmodsbuild: make: Leaving directory `/usr/src/kernels/2.6.38.6-27.fc15.i686.PAE' 04 Jun 07:45:32 akmodsbuild: error: Bad exit status from /var/tmp/rpm-tmp.JkFSRQ (%build) 04 Jun 07:45:32 akmodsbuild: 04 Jun 07:45:32 akmodsbuild: 04 Jun 07:45:32 akmodsbuild: RPM build errors: 04 Jun 07:45:32 akmodsbuild: user mockbuild does not exist - using root 04 Jun 07:45:32 akmodsbuild: group mockbuild does not exist - using root 04 Jun 07:45:32 akmodsbuild: user mockbuild does not exist - using root 04 Jun 07:45:32 akmodsbuild: group mockbuild does not exist - using root 04 Jun 07:45:32 akmodsbuild: user mockbuild does not exist - using root 04 Jun 07:45:32 akmodsbuild: group mockbuild does not exist - using root 04 Jun 07:45:32 akmodsbuild: user mockbuild does not exist - using root 04 Jun 07:45:32 akmodsbuild: group mockbuild does not exist - using root 04 Jun 07:45:32 akmodsbuild: user mockbuild does not exist - using root 04 Jun 07:45:32 akmodsbuild: group mockbuild does not exist - using root 04 Jun 07:45:32 akmodsbuild: Bad exit status from /var/tmp/rpm-tmp.JkFSRQ (%build) 04 Jun 07:45:32 akmodsbuild: 04 Jun 07:45:32 akmods: Building rpms failed; see /var/cache/akmods/wl/5.100.82.38-1-for-2.6.38.6-27.fc15.i686.PAE.failed.log for details Как собрать akmods? _________________ "Helo, word!" - 17 errors 56 warnings Posted via ActualForum NNTP Server 1.4 ... |
| 04.06.2011, 12:30:10 |
Я так понимаю все из-за: 5.100.82.38-1-for-2.6.38.6-27.fc15.i686.PAE.failed.logmake: Entering directory `/usr/src/kernels/2.6.38.6-27.fc15.i686.PAE' CC [M] /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE/src/shared/linux_osl.o CC [M] /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE/src/wl/sys/wl_linux.o /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE/src/wl/sys/wl_linux.c: In function 'wl_attach': /tmp/akmodsbuild.fsXThrrl/BUILD/wl-kmod-5.100.82.38/_kmod_build_2.6.38.6-27.fc15.i686.PAE/src/wl/sys/wl_linux.c:487:3: error: implicit declaration of function 'init_MUTEX' [-Werror=implicit-function-declaration] cc1: some warnings being treated as errors ??? _________________ "Helo, word!" - 17 errors 56 warnings Posted via ActualForum NNTP Server 1.4 ... |
| 05.06.2011, 09:15:08 |
start [/forum/topic.php?desktop=1&fid=25&tid=1484201]: |
43ms |
56ms |
| others: | 383ms |
| total: | 548ms |
