unknown filesystem type "nfs" на gentoo
На 2.6.16-gentoo-r12, пытаюсь сделать mount -t nfs server:/home/backup /mnt/backup mount: unknown filesystem type 'nfs' emerge --search nfs Searching... [ Results for search key : nfs ] [ Applications found : 6 ] * app-pda/p3nfs Latest version available: 5.19 Latest version installed: [ Not Installed ] Size of files: 252 kB Homepage: http://www.koeniglich.de/p3nfs.html Description: Symbian to Unix and Linux communication program License: GPL-2 * dev-perl/File-NFSLock Latest version available: 1.20 Latest version installed: [ Not Installed ] Size of files: 18 kB Homepage: http://cpan.uwinnipeg.ca/dist/File-NFSLock Description: NFS compatible (safe) locking utility License: Artistic * net-fs/nfs-utils Latest version available: 1.0.8 Latest version installed: 1.0.8 Size of files: 750 kB Homepage: http://nfs.sourceforge.net/ Description: NFS client and server daemons License: GPL-2 * net-libs/libnfsidmap Latest version available: 0.16 Latest version installed: 0.16 Size of files: 304 kB Homepage: http://www.citi.umich.edu/projects/nfsv4/linux/ Description: NFSv4 ID <-> name mapping library License: BSD * sec-policy/selinux-nfs Latest version available: 20040501 Latest version installed: [ Not Installed ] Size of files: 1 kB Homepage: http://www.gentoo.org/proj/en/hardened/selinux/ Description: SELinux policy for NFS License: GPL-2 * sys-fs/unionfs Latest version available: 1.1.4-r2 Latest version installed: [ Not Installed ] Size of files: 148 kB Homepage: http://www.fsl.cs.sunysb.edu/project-unionfs.html Description: Stackable unification file system, which can appear to merge the contents of several directories License: GPL-2 Чего не хватает? ... |
| 22.02.2012, 15:14:59 |
нужна поддержка данной файловой системы на уровне ядра wiki ... |
| 22.02.2012, 16:07:08 |
start [/forum/topic.php?desktop=1&fid=25&tid=1483717]: |
47ms |
74ms |
| others: | 339ms |
| total: | 539ms |
