debian пакеты
Хотел поставить php-pear он мне вот что выдал: luna852:~# aptitude install php-pear The following NEW packages will be installed: php-pear The following packages will be upgraded: php5-common 1 packages upgraded, 1 newly installed, 0 to remove and 37 not upgraded. Need to get 912 kB of archives. After unpacking 2,306 kB will be used. The following packages have unmet dependencies: php5-xsl: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-sqlite: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. libapache2-mod-php5: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-gd: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-curl: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-mcrypt: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-imap: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-mysql: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-cgi: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-cli: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. The following actions will resolve these dependencies: Remove the following packages: 1) libapache2-mod-php5 2) php5 3) php5-cgi 4) php5-cli 5) php5-curl 6) php5-gd 7) php5-imap 8) php5-mcrypt 9) php5-memcache 10) php5-mysql 11) php5-sqlite 12) php5-suhosin 13) php5-xcache 14) php5-xsl 15) plesk-core 16) plesk-l10n 17) pp-sitebuilder 18) psa 19) psa-atis 20) psa-atmail 21) psa-backup-manager 22) psa-cs-gs 23) psa-fileserver 24) psa-firewall 25) psa-health-monitor 26) psa-horde 27) psa-imp 28) psa-ingo 29) psa-kav8 30) psa-kronolith 31) psa-libxml-proxy 32) psa-mimp 33) psa-miva 34) psa-mnemo 35) psa-passwd 36) psa-php5-configurator 37) psa-spamassassin 38) psa-turba 39) psa-updates 40) psa-vhost 41) psa-vpn 42) psa-watchdog 43) sshterm Keep the following packages at their current version: 44) php-pear [Not Installed] Leave the following dependencies unresolved: 45) php5-common recommends php5-suhosin 46) libapache2-mod-php5 recommends php5-cli Accept this solution? [Y/n/q/?] q Abandoning all efforts to resolve these dependencies. Abort. luna852:~# clear luna852:~# aptitude install php-pear The following NEW packages will be installed: php-pear The following packages will be upgraded: php5-common 1 packages upgraded, 1 newly installed, 0 to remove and 37 not upgraded. Need to get 912 kB of archives. After unpacking 2,306 kB will be used. The following packages have unmet dependencies: php5-xsl: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-sqlite: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. libapache2-mod-php5: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-gd: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-curl: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-mcrypt: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-imap: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-mysql: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-cgi: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. php5-cli: Depends: php5-common (= 5.3.3-7+squeeze9) but 5.3.3-7+squeeze13 is to be installed. The following actions will resolve these dependencies: Remove the following packages: 1) libapache2-mod-php5 2) php5 3) php5-cgi 4) php5-cli 5) php5-curl 6) php5-gd 7) php5-imap 8) php5-mcrypt 9) php5-memcache 10) php5-mysql 11) php5-sqlite 12) php5-suhosin 13) php5-xcache 14) php5-xsl 15) plesk-core 16) plesk-l10n 17) pp-sitebuilder 18) psa 19) psa-atis 20) psa-atmail 21) psa-backup-manager 22) psa-cs-gs 23) psa-fileserver 24) psa-firewall 25) psa-health-monitor 26) psa-horde 27) psa-imp 28) psa-ingo 29) psa-kav8 30) psa-kronolith 31) psa-libxml-proxy 32) psa-mimp 33) psa-miva 34) psa-mnemo 35) psa-passwd 36) psa-php5-configurator 37) psa-spamassassin 38) psa-turba 39) psa-updates 40) psa-vhost 41) psa-vpn 42) psa-watchdog 43) sshterm Keep the following packages at their current version: 44) php-pear [Not Installed] Leave the following dependencies unresolved: 45) php5-common recommends php5-suhosin 46) libapache2-mod-php5 recommends php5-cli Accept this solution? [Y/n/q/?] Как-то бы не очень хотелось такого щасться. Нажимаю n, пишет: The following actions will resolve these dependencies: Upgrade the following packages: 1) libapache2-mod-php5 [5.3.3-7+squeeze9 (now) -> 5.3.3-7+squeeze13 (stable)] 2) php5-cgi [5.3.3-7+squeeze9 (now) -> 5.3.3-7+squeeze13 (stable)] 3) php5-cli [5.3.3-7+squeeze9 (now) -> 5.3.3-7+squeeze13 (stable)] 4) php5-curl [5.3.3-7+squeeze9 (now) -> 5.3.3-7+squeeze13 (stable)] 5) php5-gd [5.3.3-7+squeeze9 (now) -> 5.3.3-7+squeeze13 (stable)] 6) php5-imap [5.3.3-7+squeeze9 (now) -> 5.3.3-7+squeeze13 (stable)] 7) php5-mcrypt [5.3.3-7+squeeze9 (now) -> 5.3.3-7+squeeze13 (stable)] 8) php5-mysql [5.3.3-7+squeeze9 (now) -> 5.3.3-7+squeeze13 (stable)] 9) php5-sqlite [5.3.3-7+squeeze9 (now) -> 5.3.3-7+squeeze13 (stable)] 10) php5-xsl [5.3.3-7+squeeze9 (now) -> 5.3.3-7+squeeze13 (stable)] Accept this solution? [Y/n/q/?] Так понимаю в этом случае он ничего не удалит? А то не хотелось бы на продакшен сервере пхп удалять. ... |
| 02.07.2012, 09:38:59 |
debian пакеты
А если через апт гет, то luna852:~# apt-get install php-pear Reading package lists... Done Building dependency tree Reading state information... Done The following extra packages will be installed: libapache2-mod-php5 php5-cgi php5-cli php5-common php5-curl php5-gd php5-imap php5-mcrypt php5-mysql php5-sqlite php5-xsl Suggested packages: php5-dev The following NEW packages will be installed: php-pear The following packages will be upgraded: libapache2-mod-php5 php5-cgi php5-cli php5-common php5-curl php5-gd php5-imap php5-mcrypt php5-mysql php5-sqlite php5-xsl 11 upgraded, 1 newly installed, 0 to remove and 27 not upgraded. Need to get 13.0 MB of archives. After this operation, 1,786 kB of additional disk space will be used. Do you want to continue [Y/n]? Почему он говорит что установит пакеты, которые в самом то деле уже есть? ... |
| 02.07.2012, 09:41:36 |
start [/forum/topic.php?desktop=1&fid=25&tid=1483481]: |
23ms |
48ms |
65ms |
| others: | 345ms |
| total: | 532ms |
