Коннект к MySQL 5.0.45 из Apache Tomcat-7.0.32 под Linux Mandriva - Communications failure
Приветствую. Столкнулся со следующей проблемой - приложение, развернутое в ОС Linux Mandriva в контейнере сервлетов Apache Tomcat-7.0.32 не может получить соединение с СУБД MySQL 5.0.45 , выполняемой на том же сервере, что и контейнер. В catalina.out , говорится, что - + ... INFO: Server startup in 5315 ms 17.10.2012 15:36:52 com.vaadin.terminal.gwt.server.AbstractApplicationServlet serveStaticResourcesInVAADIN INFO: Requested resource [VAADIN/themes/web13theme/favicon.ico] not found from filesystem or through class loader. Add widgetset and/or theme JAR to your classpath or add files to WebContent/VAADIN folder. 17.10.2012 15:36:58 com.vaadin.terminal.gwt.server.AbstractApplicationServlet serveStaticResourcesInVAADIN INFO: Requested resource [VAADIN/themes/projtheme/img/cancel.png] not found from filesystem or through class loader. Add widgetset and/or theme JAR to your classpath or add files to WebContent/VAADIN folder. 3 [http-bio-8081-exec-7] INFO org.hibernate.cfg.annotations.Version - Hibernate Annotations 3.4.0.GA 25 [http-bio-8081-exec-7] INFO org.hibernate.cfg.Environment - Hibernate 3.3.0.SP1 39 [http-bio-8081-exec-7] INFO org.hibernate.cfg.Environment - hibernate.properties not found 44 [http-bio-8081-exec-7] INFO org.hibernate.cfg.Environment - Bytecode provider name : javassist 50 [http-bio-8081-exec-7] INFO org.hibernate.cfg.Environment - using JDK 1.4 java.sql.Timestamp handling 148 [http-bio-8081-exec-7] INFO org.hibernate.annotations.common.Version - Hibernate Commons Annotations 3.1.0.GA 176 [http-bio-8081-exec-7] INFO org.hibernate.cfg.search.HibernateSearchEventListenerRegister - Unable to find org.hibernate.search.event.FullTextIndexEventListener on the classpath. Hibernate Search is not enabled. 247 [http-bio-8081-exec-7] INFO org.hibernate.cfg.AnnotationBinder - Binding entity from annotated class: com.ssi.domen.Incoming 313 [http-bio-8081-exec-7] INFO org.hibernate.cfg.annotations.EntityBinder - Bind entity com.ssi.domen.Incoming on table INCOMING 397 [http-bio-8081-exec-7] INFO org.hibernate.cfg.AnnotationBinder - Binding entity from annotated class: com.ssi.domen.Outcoming 397 [http-bio-8081-exec-7] INFO org.hibernate.cfg.annotations.EntityBinder - Bind entity com.ssi.domen.Outcoming on table OUTCOMING 400 [http-bio-8081-exec-7] INFO org.hibernate.cfg.AnnotationBinder - Binding entity from annotated class: com.ssi.domen.User 400 [http-bio-8081-exec-7] INFO org.hibernate.cfg.annotations.EntityBinder - Bind entity com.ssi.domen.User on table USER 402 [http-bio-8081-exec-7] INFO org.hibernate.cfg.AnnotationBinder - Binding entity from annotated class: com.ssi.domen.Cable 402 [http-bio-8081-exec-7] INFO org.hibernate.cfg.annotations.EntityBinder - Bind entity com.ssi.domen.Cable on table CABLE 497 [http-bio-8081-exec-7] INFO org.hibernate.cfg.AnnotationConfiguration - Hibernate Validator not found: ignoring 509 [http-bio-8081-exec-7] INFO org.hibernate.connection.DriverManagerConnectionProvider - Using Hibernate built-in connection pool (not for production use!) 510 [http-bio-8081-exec-7] INFO org.hibernate.connection.DriverManagerConnectionProvider - Hibernate connection pool size: 20 510 [http-bio-8081-exec-7] INFO org.hibernate.connection.DriverManagerConnectionProvider - autocommit mode: false 514 [http-bio-8081-exec-7] INFO org.hibernate.connection.DriverManagerConnectionProvider - using driver: com.mysql.jdbc.Driver at URL: jdbc:mysql://---ip here----/gibrid 514 [http-bio-8081-exec-7] INFO org.hibernate.connection.DriverManagerConnectionProvider - connection properties: {user=java, password=****} 189691 [http-bio-8081-exec-7] WARN org.hibernate.cfg.SettingsFactory - Could not obtain connection metadata com.mysql.jdbc.CommunicationsException: Communications link failure due to underlying exception: ** BEGIN NESTED EXCEPTION ** java.net.ConnectException MESSAGE: Connection timed out STACKTRACE: java.net.ConnectException: Connection timed out at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:351) at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:213) at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:200) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366) at java.net.Socket.connect(Socket.java:529) at java.net.Socket.connect(Socket.java:478) at java.net.Socket.<init>(Socket.java:375) at java.net.Socket.<init>(Socket.java:218) at com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:256) at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:271) at com.mysql.jdbc.Connection.createNewIO(Connection.java:2771) at com.mysql.jdbc.Connection.<init>(Connection.java:1555) at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:285) at java.sql.DriverManager.getConnection(DriverManager.java:582) at java.sql.DriverManager.getConnection(DriverManager.java:154) at org.hibernate.connection.DriverManagerConnectionProvider.getConnection(DriverManagerConnectionProvider.java:133) at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:111) at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2101) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1325) at org.hibernate.cfg.AnnotationConfiguration.buildSessionFactory(AnnotationConfiguration.java:867) at com.ssi.hbnutils.HibernateUtil.<clinit>(HibernateUtil.java:34) at com.ssi.windows.RegWindow.check(RegWindow.java:167) at com.ssi.windows.RegWindow.insert(RegWindow.java:140) at com.ssi.windows.RegWindow.access$0(RegWindow.java:139) at com.ssi.windows.RegWindow$1.buttonClick(RegWindow.java:107) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at com.vaadin.event.ListenerMethod.receiveEvent(ListenerMethod.java:510) at com.vaadin.event.EventRouter.fireEvent(EventRouter.java:164) at com.vaadin.ui.AbstractComponent.fireEvent(AbstractComponent.java:1219) at com.vaadin.ui.Button.fireClick(Button.java:567) at com.vaadin.ui.Button.changeVariables(Button.java:223) at com.vaadin.terminal.gwt.server.AbstractCommunicationManager.changeVariables(AbstractCommunicationManager.java:1460) at com.vaadin.terminal.gwt.server.AbstractCommunicationManager.handleVariableBurst(AbstractCommunicationManager.java:1404) at com.vaadin.terminal.gwt.server.AbstractCommunicationManager.handleVariables(AbstractCommunicationManager.java:1329) at com.vaadin.terminal.gwt.server.AbstractCommunicationManager.doHandleUidlRequest(AbstractCommunicationManager.java:761) at com.vaadin.terminal.gwt.server.CommunicationManager.handleUidlRequest(CommunicationManager.java:323) at com.vaadin.terminal.gwt.server.AbstractApplicationServlet.service(AbstractApplicationServlet.java:501) at javax.servlet.http.HttpServlet.service(HttpServlet.java:722) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:929) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1002) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) at java.lang.Thread.run(Thread.java:662) ** END NESTED EXCEPTION ** Last packet sent to the server was 6 ms ago. at com.mysql.jdbc.Connection.createNewIO(Connection.java:2847) at com.mysql.jdbc.Connection.<init>(Connection.java:1555) at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:285) at java.sql.DriverManager.getConnection(DriverManager.java:582) at java.sql.DriverManager.getConnection(DriverManager.java:154) at org.hibernate.connection.DriverManagerConnectionProvider.getConnection(DriverManagerConnectionProvider.java:133) at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:111) at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2101) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1325) at org.hibernate.cfg.AnnotationConfiguration.buildSessionFactory(AnnotationConfiguration.java:867) at com.ssi.hbnutils.HibernateUtil.<clinit>(HibernateUtil.java:34) at com.ssi.windows.RegWindow.check(RegWindow.java:167) at com.ssi.windows.RegWindow.insert(RegWindow.java:140) at com.ssi.windows.RegWindow.access$0(RegWindow.java:139) at com.ssi.windows.RegWindow$1.buttonClick(RegWindow.java:107) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at com.vaadin.event.ListenerMethod.receiveEvent(ListenerMethod.java:510) at com.vaadin.event.EventRouter.fireEvent(EventRouter.java:164) at com.vaadin.ui.AbstractComponent.fireEvent(AbstractComponent.java:1219) at com.vaadin.ui.Button.fireClick(Button.java:567) at com.vaadin.ui.Button.changeVariables(Button.java:223) at com.vaadin.terminal.gwt.server.AbstractCommunicationManager.changeVariables(AbstractCommunicationManager.java:1460) at com.vaadin.terminal.gwt.server.AbstractCommunicationManager.handleVariableBurst(AbstractCommunicationManager.java:1404) at com.vaadin.terminal.gwt.server.AbstractCommunicationManager.handleVariables(AbstractCommunicationManager.java:1329) at com.vaadin.terminal.gwt.server.AbstractCommunicationManager.doHandleUidlRequest(AbstractCommunicationManager.java:761) at com.vaadin.terminal.gwt.server.CommunicationManager.handleUidlRequest(CommunicationManager.java:323) at com.vaadin.terminal.gwt.server.AbstractApplicationServlet.service(AbstractApplicationServlet.java:501) at javax.servlet.http.HttpServlet.service(HttpServlet.java:722) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:929) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1002) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) at java.lang.Thread.run(Thread.java:662) 190005 [http-bio-8081-exec-7] INFO org.hibernate.dialect.Dialect - Using dialect: org.hibernate.dialect.MySQLDialect 190066 [http-bio-8081-exec-7] INFO org.hibernate.transaction.TransactionFactoryFactory - Using default transaction strategy (direct JDBC transactions) 190090 [http-bio-8081-exec-7] INFO org.hibernate.transaction.TransactionManagerLookupFactory - No TransactionManagerLookup configured (in JTA environment, use of read-write or transactional second-level cache is not recommended) 190092 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Automatic flush during beforeCompletion(): disabled 190092 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Automatic session close at end of transaction: disabled 190114 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Scrollable result sets: disabled 190115 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - JDBC3 getGeneratedKeys(): disabled 190116 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Connection release mode: auto 190125 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Maximum outer join fetch depth: 2 190127 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Default batch fetch size: 1 190127 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Generate SQL with comments: disabled 190128 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Order SQL updates by primary key: disabled 190128 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Order SQL inserts for batching: disabled 190129 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Query translator: org.hibernate.hql.ast.ASTQueryTranslatorFactory 190167 [http-bio-8081-exec-7] INFO org.hibernate.hql.ast.ASTQueryTranslatorFactory - Using ASTQueryTranslatorFactory 190169 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Query language substitutions: {} 190169 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - JPA-QL strict compliance: disabled 190170 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Second-level cache: enabled 190171 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Query cache: disabled 190171 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Cache region factory : org.hibernate.cache.impl.NoCachingRegionFactory 190173 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Optimize cache for minimal puts: disabled 190174 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Structured second-level cache entries: disabled 190239 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Echoing all SQL to stdout 190250 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Statistics: disabled 190250 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Deleted entity synthetic identifier rollback: disabled 190260 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Default entity-mode: pojo 190260 [http-bio-8081-exec-7] INFO org.hibernate.cfg.SettingsFactory - Named query checking : enabled 190761 [http-bio-8081-exec-7] INFO org.hibernate.impl.SessionFactoryImpl - building session factory 191112 [http-bio-8081-exec-7] INFO org.hibernate.impl.SessionFactoryObjectFactory - Not binding factory to JNDI, no JNDI name configured 380252 [http-bio-8081-exec-7] WARN org.hibernate.util.JDBCExceptionReporter - SQL Error: 0, SQLState: 08S01 380252 [http-bio-8081-exec-7] ERROR org.hibernate.util.JDBCExceptionReporter - Communications link failure due to underlying exception: ** BEGIN NESTED EXCEPTION ** java.net.ConnectException MESSAGE: Connection timed out STACKTRACE: java.net.ConnectException: Connection timed out at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:351) at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:213) at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:200) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366) at java.net.Socket.connect(Socket.java:529) at java.net.Socket.connect(Socket.java:478) at java.net.Socket.<init>(Socket.java:375) at java.net.Socket.<init>(Socket.java:218) at com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:256) at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:271) at com.mysql.jdbc.Connection.createNewIO(Connection.java:2771) at com.mysql.jdbc.Connection.<init>(Connection.java:1555) at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:285) at java.sql.DriverManager.getConnection(DriverManager.java:582) at java.sql.DriverManager.getConnection(DriverManager.java:154) at org.hibernate.connection.DriverManagerConnectionProvider.getConnection(DriverManagerConnectionProvider.java:133) at org.hibernate.jdbc.ConnectionManager.openConnection(ConnectionManager.java:446) at org.hibernate.jdbc.ConnectionManager.getConnection(ConnectionManager.java:167) at org.hibernate.jdbc.JDBCContext.connection(JDBCContext.java:142) at org.hibernate.transaction.JDBCTransaction.begin(JDBCTransaction.java:85) at org.hibernate.impl.SessionImpl.beginTransaction(SessionImpl.java:1353) at com.ssi.windows.RegWindow.check(RegWindow.java:168) at com.ssi.windows.RegWindow.insert(RegWindow.java:140) at com.ssi.windows.RegWindow.access$0(RegWindow.java:139) at com.ssi.windows.RegWindow$1.buttonClick(RegWindow.java:107) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at com.vaadin.event.ListenerMethod.receiveEvent(ListenerMethod.java:510) at com.vaadin.event.EventRouter.fireEvent(EventRouter.java:164) at com.vaadin.ui.AbstractComponent.fireEvent(AbstractComponent.java:1219) at com.vaadin.ui.Button.fireClick(Button.java:567) at com.vaadin.ui.Button.changeVariables(Button.java:223) at com.vaadin.terminal.gwt.server.AbstractCommunicationManager.changeVariables(AbstractCommunicationManager.java:1460) at com.vaadin.terminal.gwt.server.AbstractCommunicationManager.handleVariableBurst(AbstractCommunicationManager.java:1404) at com.vaadin.terminal.gwt.server.AbstractCommunicationManager.handleVariables(AbstractCommunicationManager.java:1329) at com.vaadin.terminal.gwt.server.AbstractCommunicationManager.doHandleUidlRequest(AbstractCommunicationManager.java:761) at com.vaadin.terminal.gwt.server.CommunicationManager.handleUidlRequest(CommunicationManager.java:323) at com.vaadin.terminal.gwt.server.AbstractApplicationServlet.service(AbstractApplicationServlet.java:501) at javax.servlet.http.HttpServlet.service(HttpServlet.java:722) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:929) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1002) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) at java.lang.Thread.run(Thread.java:662) ** END NESTED EXCEPTION ** Last packet sent to the server was 5 ms ago. Однако с виндового клиента удается получить доступ к базе данных - Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. Код: java 1. 2. 3. 4. 5. Или так - Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. С чем это может быть связано? Был бы весьма признателен за информацию. Спасибо. Модератор: Тема перенесена из форума "Java". ... |
| 17.10.2012, 19:07:58 |
Я так подозреваю, что MySQL при Код: powershell 1. 2. 3. осуществляет коммуникации через Unix - сокеты или именованные каналы (.sock). ... |
| 17.10.2012, 20:53:54 |
..does anyone know? http://stackoverflow.com/questions/12934384/linux-mandriva-tomat-can-not-get-mysql-database-connection-why] http://stackoverflow.com/questions/12934384/linux-mandriva-tomat-can-not-get-mysql-database-connection-why http://stackoverflow.com/questions/12953494/linux-mysql-java-communications-link-failure-due-to-underlying-exception-con/12953602#12953602] http://stackoverflow.com/questions/12953494/linux-mysql-java-communications-link-failure-due-to-underlying-exception-con/12953602#12953602 ... |
| 18.10.2012, 15:55:27 |
start [/forum/topic.php?desktop=1&fid=25&tid=1483287]: |
25ms |
60ms |
66ms |
| others: | 425ms |
| total: | 641ms |
