Как удалить более старый дублирующий rpm пакет в Linux?
Добрый день! Есть два установленных дублирующих пакета: [root@bss-post ~]# rpm -qa | grep mysql-libs mysql-libs-5.1.66-2.el6_3.x86_64 mysql-libs-5.5.34-1.el6.x86_64 Надо удалить более старый: [root@bss-post ~]# rpm -e mysql-libs-5.1.66-2.el6_3.x86_64 error: Failed dependencies: libmysqlclient.so.16()(64bit) is needed by (installed) postfix-2:2.6.6-2.2.el6_1.x86_64 libmysqlclient.so.16()(64bit) is needed by (installed) perl-DBD-MySQL-4.013-3.el6.x86_64 libmysqlclient.so.16()(64bit) is needed by (installed) dovecot-mysql-1:2.0.9-5.el6.x86_64 libmysqlclient.so.16()(64bit) is needed by (installed) php-mysql-5.3.3-26.el6.x86_64 libmysqlclient.so.16()(64bit) is needed by (installed) mysql-5.1.66-2.el6_3.x86_64 libmysqlclient.so.16()(64bit) is needed by (installed) mysql-server-5.1.66-2.el6_3.x86_64 libmysqlclient.so.16(libmysqlclient_16)(64bit) is needed by (installed) postfix-2:2.6.6-2.2.el6_1.x86_64 libmysqlclient.so.16(libmysqlclient_16)(64bit) is needed by (installed) perl-DBD-MySQL-4.013-3.el6.x86_64 libmysqlclient.so.16(libmysqlclient_16)(64bit) is needed by (installed) dovecot-mysql-1:2.0.9-5.el6.x86_64 libmysqlclient.so.16(libmysqlclient_16)(64bit) is needed by (installed) php-mysql-5.3.3-26.el6.x86_64 libmysqlclient.so.16(libmysqlclient_16)(64bit) is needed by (installed) mysql-5.1.66-2.el6_3.x86_64 libmysqlclient.so.16(libmysqlclient_16)(64bit) is needed by (installed) mysql-server-5.1.66-2.el6_3.x86_64 libmysqlclient_r.so.16()(64bit) is needed by (installed) mysql-5.1.66-2.el6_3.x86_64 libmysqlclient_r.so.16()(64bit) is needed by (installed) mysql-server-5.1.66-2.el6_3.x86_64 libmysqlclient_r.so.16(libmysqlclient_16)(64bit) is needed by (installed) mysql-5.1.66-2.el6_3.x86_64 libmysqlclient_r.so.16(libmysqlclient_16)(64bit) is needed by (installed) mysql-server-5.1.66-2.el6_3.x86_64 mysql-libs = 5.1.66-2.el6_3 is needed by (installed) mysql-5.1.66-2.el6_3.x86_64 Но он не удаляется из-за зависимостей. Пытаюсь удалить принудительно: [root@bss-post ~]# rpm -e --force mysql-libs-5.1.66-2.el6_3.x86_64 rpm: only installation, upgrading, rmsource and rmspec may be forced Операционная система: [root@bss-post ~]# uname -a Linux bss-post.dbo.vbrr.loc 2.6.32-358.el6.x86_64 #1 SMP Tue Jan 29 11:47:41 EST 2013 x86_64 x86_64 x86_64 GNU/Linux [root@bss-post ~]# ВОПРОС: Как удалить более старый дублирующий rpm пакет в Linux? Заранее благодарен. ... |
| 17.12.2013, 12:35:01 |
start [/forum/topic.php?desktop=1&fid=25&tid=1482691]: |
50ms |
55ms |
| others: | 366ms |
| total: | 549ms |
