Не проходят письма на gmail и rambler
Ребята, помогите! Всю голову сломал....обработка в 1с через наш почтовый сервер рассылает нашим клиентам сообщения с файлами. Позавчера начали приходить обратно письма от gmail и rambler, с таким текстом: "This is the mail system at host mail.mydomen.ru. I'm sorry to have to inform you that your message could not be delivered to one or more recipients. It's attached below. For further assistance, please send mail to postmaster. If you do so, please include this problem report. You can delete your own text from the attached returned message. The mail system <user@gmail.com>: host gmail-smtp-in.l.google.com[173.194.71.26] said: 550-5.7.1 [xxx.xxx.xxx.xxx 1] Our system has detected an unusual rate of 550-5.7.1 unsolicited mail originating from your IP address. To protect our 550-5.7.1 users from spam, mail sent from your IP address has been blocked. 550-5.7.1 Please visit http://www.google.com/mail/help/bulk_mail.html to review 550 5.7.1 our Bulk Email Senders Guidelines. 8si3120368lav.138 - gsmtp (in reply to end of DATA command) " и "This is the mail system at host mail.trade-alco.ru. I'm sorry to have to inform you that your message could not be delivered to one or more recipients. It's attached below. For further assistance, please send mail to postmaster. If you do so, please include this problem report. You can delete your own text from the attached returned message. The mail system <user@rambler.ru>: host imx1.rambler.ru[81.19.66.235] said: 554 5.7.1 Client host [xxx.xxx.xxx.xxx] blocked using xbl.spamhaus.org; http://www.spamhaus.org/query/bl?ip=85.234.38.167 (in reply to RCPT TO command) " Обратная запись PTR у провайдера создана на наш IP. SPF запись в DNS: mydomen.ru text = "v=spf1 ip4:xxx.xxx.xxx.xxx include:_spf.google.com +mx ~all" Подскажите как можно исправить? ... |
| 16.01.2014, 17:13:48 |
RichyПодскажите как можно исправить? для начала: как отправляется почта? напрямую из 1С на сервера получателей/используется relay? Если релей то чей? По приведенной ссылке http://www.google.com/mail/help/bulk_mail.html содержимое читалось? Касаемо второго отлупа - там вообще все просто IP-адрес, с которого производится отправка попал в черный список. Его надо вручную убрать из него, все инструкции можно найти по ссылке, содержащейся в отлупе. ... |
| 16.01.2014, 17:41:43 |
bga83RichyПодскажите как можно исправить? для начала: как отправляется почта? напрямую из 1С на сервера получателей/используется relay? Если релей то чей? По приведенной ссылке http://www.google.com/mail/help/bulk_mail.html содержимое читалось? Касаемо второго отлупа - там вообще все просто IP-адрес, с которого производится отправка попал в черный список. Его надо вручную убрать из него, все инструкции можно найти по ссылке, содержащейся в отлупе. в обработке вписывается адрес почты нашего сервака+настройки почтового сервера, 1с формирует отчеты с файлами и через этот почтовый ящик отправляет письмо клиентам. На счет релея не пойму, он у меня вроде выключен на сервере. Содержимое от гугла читалось, все выполняется....кроме скрытого заголовка, не пойму как создавать скрытые заголовки в теме письма. По поводу отлупа, по ссылке сайт не доступен ... |
| 16.01.2014, 18:04:51 |
Richy, Рамблер разбанил, Гугль до сих пор никак...Какие будут еще мысли? ... |
| 17.01.2014, 17:37:44 |
Richy, да никаких тут мыслей быть не может. Это НОРМАЛЬНО. Если NN пользователей ваша рассылка надоела и они нажали кнопочку Это спам, то вы ничего не сделаете, кроме как сменить IP и адреса. Нужно слать нормальную почту и терпеливо ждать. В качестве факультатива попробуйте поискать каким именно образом ваш сервер попал в xbl.spamhaus.org. Но сильно не надейтесь. Гуглу нет смысла доверять дебильным черными спискам. ... |
| 19.01.2014, 00:50:12 |
start [/forum/topic.php?desktop=1&fid=25&tid=1482655]: |
46ms |
56ms |
| others: | 336ms |
| total: | 503ms |
