Could not Remount read-only filesystem as read-write
Dear experts, I have trouble with read-only filesystem exactly Linux server suddenly goes to read-only. I will provide all necessary information below: Platform Related information: Код: python 1. 2. Info from /etc/fstab: Код: powershell 1. 2. 3. 4. 5. 6. 7. 8. Info from df -h: Код: powershell 1. 2. 3. 4. 5. Info from fdisk: Код: powershell 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. Info from dmesg: Код: powershell 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. So after searching i tried to remount /dev/sdb1 which have "/" mount point. But got : Код: powershell 1. 2. This server is Virtual server. It is really appreciate to get from you all advice..Could you please explain, what may cause such kind situation? or how to solve? Thanks. ... |
| 07.04.2014, 11:00:48 |
And info from mount -l shows that /dev/sdb1 is in rw mode. Код: powershell 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. ... |
| 07.04.2014, 11:04:12 |
Info from /proc/mounts Код: powershell 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. ... |
| 07.04.2014, 11:24:53 |
Shahriyar.R, Please login with enough permission and type mount -o rw, remount <partition> ... |
| 07.04.2014, 11:58:31 |
Jahangir-ShPlease login with enough permission and type mount -o rw, remount <partition> Ничего не выйдет. Ядро считает устройство sdb1 отказавшим и не будет его перемонтировать в RW. Надо разбираться почему на виртуальном сервере отказывают диски, изнутри виртуалки тут ничего не поправить. ... |
| 07.04.2014, 12:57:41 |
Jahangir-Sh, Код: powershell 1. 2. what other steps we should do to figure out what is the problem? ... |
| 07.04.2014, 13:10:10 |
start [/forum/topic.php?desktop=1&fid=25&tid=1482568]: |
57ms |
63ms |
| others: | 334ms |
| total: | 529ms |
