не работает cluebringer
Дано: Linux Debian wheezy 7.5 stable Postfix postfix-cluebringer (2.0.10-1) Проблема: таблица триплетов пуста. содержимое cluebringer.conf: [server] protocols=<<EOT Postfix Bizanga EOT # Modules to load modules=<<EOT Core AccessControl CheckHelo CheckSPF Greylisting Quotas EOT # User to run this daemon as user=cluebringer group=cluebringer # Filename to store pid of parent process pid_file=/var/run/cluebringer/cbpolicyd.pid background=no log_level=4 log_file=/var/log/cbpolicyd.log log_mail=mail@syslog:native host=127.0.0.1 port=10031 [database] DSN=DBI:mysql:database=policyd;host=localhost Username=root Password= # What do we do when we have a database connection problem # tempfail - Return temporary failure # pass - Return success bypass_mode=tempfail # How many seconds before we retry a DB connection bypass_timeout=30 # Access Control module [AccessControl] enable=1 # Greylisting module [Greylisting] enable=1 # CheckHelo module [CheckHelo] enable=1 # CheckSPF module [CheckSPF] enable=1 # Quotas module [Quotas] enable=1 содержимое cppolicyd.log после коннекта [CORE]CONNECT TCP Peer: «[127.0.0.1]:52753» Local: [127.0.0.1]:10031" [CORE]CONNECT TCP Peer: «[127.0.0.1]:52754» Local: «[127.0.0.1]:10031» [CORE] Killing «1» children [CBPOLICYD] DEBUG: Shutting down caching engine (6594) [CORE] CONNECT TCP Peer: «[127.0.0.1]:52755» Local: «[127.0.0.1]:10031» [CORE] INFO: Starting «1» children [CORE] DEBUG: Child Preforked (6653) [CBPOLICYD] DEBUG: Starting up caching engine [CORE] INFO: Killing «1» children [CBPOLICYD] DEBUG: Shutting down caching engine (6653) ... |
| 06.07.2014, 08:15:08 |
start [/forum/topic.php?desktop=1&fid=25&tid=1482490]: |
50ms |
51ms |
| others: | 381ms |
| total: | 549ms |
