частота процессора
Добрый день! Подскажи пожалуйста, из-за чего скачет частота процессора один раз такой показатель а через пару секунд запусакешь такой в чем причина ? то 800 то 2900 Мгц, cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 0: driver: powernow-k8 CPUs which run at the same hardware frequency: 0 CPUs which need to have their frequency coordinated by software: 0 maximum transition latency: 8.0 us. hardware limits: 800 MHz - 2.90 GHz available frequency steps: 2.90 GHz, 2.20 GHz, 1.70 GHz, 800 MHz available cpufreq governors: powersave, conservative, userspace, ondemand, performance current policy: frequency should be within 800 MHz and 2.90 GHz. The governor "ondemand" may decide which speed to use within this range. current CPU frequency is 2.90 GHz. cpufreq stats: 2.90 GHz:18,32%, 2.20 GHz:1,63%, 1.70 GHz:4,30%, 800 MHz:75,75% (817) analyzing CPU 1: driver: powernow-k8 CPUs which run at the same hardware frequency: 1 CPUs which need to have their frequency coordinated by software: 1 maximum transition latency: 8.0 us. hardware limits: 800 MHz - 2.90 GHz available frequency steps: 2.90 GHz, 2.20 GHz, 1.70 GHz, 800 MHz available cpufreq governors: powersave, conservative, userspace, ondemand, performance current policy: frequency should be within 800 MHz and 2.90 GHz. The governor "ondemand" may decide which speed to use within this range. current CPU frequency is 2.90 GHz. cpufreq stats: 2.90 GHz:37,24%, 2.20 GHz:1,42%, 1.70 GHz:6,38%, 800 MHz:54,96% (900) ------------------ cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 0: driver: powernow-k8 CPUs which run at the same hardware frequency: 0 CPUs which need to have their frequency coordinated by software: 0 maximum transition latency: 8.0 us. hardware limits: 800 MHz - 2.90 GHz available frequency steps: 2.90 GHz, 2.20 GHz, 1.70 GHz, 800 MHz available cpufreq governors: powersave, conservative, userspace, ondemand, performance current policy: frequency should be within 800 MHz and 2.90 GHz. The governor "ondemand" may decide which speed to use within this range. current CPU frequency is 800 MHz. cpufreq stats: 2.90 GHz:29,46%, 2.20 GHz:3,45%, 1.70 GHz:7,15%, 800 MHz:59,95% (2737) analyzing CPU 1: driver: powernow-k8 CPUs which run at the same hardware frequency: 1 CPUs which need to have their frequency coordinated by software: 1 maximum transition latency: 8.0 us. hardware limits: 800 MHz - 2.90 GHz available frequency steps: 2.90 GHz, 2.20 GHz, 1.70 GHz, 800 MHz available cpufreq governors: powersave, conservative, userspace, ondemand, performance current policy: frequency should be within 800 MHz and 2.90 GHz. The governor "ondemand" may decide which speed to use within this range. current CPU frequency is 800 MHz. cpufreq stats: 2.90 GHz:44,13%, 2.20 GHz:3,38%, 1.70 GHz:10,62%, 800 MHz:41,88% (2772) ... |
| 07.12.2014, 14:28:12 |
частота процессора
Это че технология powersave ? И как ее вообще отключить, чтобы проц работал на максимальной частоте ? Это наверное в биосе где-то отключается ? ... |
| 07.12.2014, 14:30:26 |
частота процессора
PowerNow! Там не только частота, но напряжение питания меняется. Отключать это не надо, иначе процессор и его кулер будут постоянно впустую молотить на полной мощности, что явно не прибавит им срока жизни. ... |
| 07.12.2014, 14:57:15 |
частота процессора
погуглить про свой дистр? echo performance /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor ... |
| 07.12.2014, 15:21:54 |
частота процессора
loginovruЭто че технология powersave ? И как ее вообще отключить, чтобы проц работал на максимальной частоте ? Это наверное в биосе где-то отключается ? Вот как оперативка работает на полную, так тебе это не нравится , а процессор нагрузить хочешь. Ты уже как-то определись с требованиями к железу Не надо ничего отключать, все так и должно быть. Или тебе принципиально, чтобы у тебя было 98% свободного процессорного времени? ... |
| 07.12.2014, 15:57:04 |
частота процессора
на самом деле бывают случаи когда оно сильно влияет на производительность http://www.postgresql.org/message-id/508ACF61.1000602@optionshouse.com]http://www.postgresql.org/message-id/508ACF61.1000602@optionshouse.com https://my.vertica.com/docs/7.0.x/HTML/Content/Authoring/InstallationGuide/BeforeYouInstall/cpuscaling.htm ... |
| 07.12.2014, 17:20:17 |
частота процессора
Журавлев Денис, да влияет и очень сильно, если смотреть видео например с youtube плагином adobe flash player в хорошем качестве 1044p например, то эти прижки вызывают дискомфорт при просмотре! Это во-первых, во-второых у меня же проц не 8-ми ядерный и даже не 6-ти :) поэтому скорее всего нужно выключть это PowerNOW, так проц и так холодный в простое 21 градус, при нагрузе 50% - 32 градуса... ... |
| 07.12.2014, 20:08:07 |
частота процессора
loginovruЖуравлев Денис, да влияет и очень сильно, если смотреть видео например с youtube плагином adobe flash player в хорошем качестве 1044p например, то эти прижки вызывают дискомфорт при просмотре! Это во-первых, во-второых у меня же проц не 8-ми ядерный и даже не 6-ти :) поэтому скорее всего нужно выключть это PowerNOW, так проц и так холодный в простое 21 градус, при нагрузе 50% - 32 градуса...тьфу-ты черт, я думал это на сервере. Флеш не поэтому дергается, нафига вообще смотреть ютуб через флеш, html5. ... |
| 07.12.2014, 23:20:28 |
частота процессора
Журавлев Денис, хм, а из-за чего же ? если 2 видика открыто одновременно, частота не прыгает, тормозов меньше.... ... |
| 08.12.2014, 02:56:46 |
start [/forum/topic.php?desktop=1&fid=25&tid=1482265]: |
27ms |
54ms |
25ms |
96ms |
| others: | 363ms |
| total: | 598ms |
