Авторизация через локальных пользователей в Dovecot
Авторизация через локальных пользователей в Dovecot Добрый день! Как настроить Dovecot, чтобы авторизация проходила через локальных пользователей? Пытаюсь с хоста (10.1.10.54) зайти на хост (10.1.10.53), где установлен Dovecot (настроен на 1110 порт): [root@mxnvs korenevb]# telnet 10.1.10.53 1110 Trying 10.1.10.53... Connected to 10.1.10.53. Escape character is '^]'. +OK Dovecot ready. user korenevb +OK pass qwerty123 -ERR Authentication failed. quit +OK Logging out Connection closed by foreign host. [root@mxnvs korenevb]# Смотрю в журнал: Dec 08 11:47:24 master: Warning: Killed with signal 15 (by pid=11693 uid=0 code=kill) Dec 08 11:47:25 master: Info: Dovecot v2.0.9 starting up (core dumps disabled) Dec 08 11:47:36 auth: Debug: Loading modules from directory: /usr/lib64/dovecot/auth Dec 08 11:47:36 auth: Debug: Module loaded: /usr/lib64/dovecot/auth/libauthdb_ldap.so Dec 08 11:47:36 auth: Debug: Module loaded: /usr/lib64/dovecot/auth/libdriver_sqlite.so Dec 08 11:47:36 auth: Debug: Module loaded: /usr/lib64/dovecot/auth/libmech_gssapi.so Dec 08 11:47:36 auth: Debug: auth client connected (pid=11717) Dec 08 11:48:16 auth: Debug: client in: AUTH 1 PLAIN service=pop3 lip=10.1.10.53 rip=10.1.10.54 lport=1110 rport=44278 resp=AGtvcmVuZXZiAG5ia2tibjEyMw== Dec 08 11:48:16 auth: Debug: Loading modules from directory: /usr/lib64/dovecot/auth Dec 08 11:48:16 auth: Debug: Module loaded: /usr/lib64/dovecot/auth/libauthdb_ldap.so Dec 08 11:48:16 auth: Debug: Module loaded: /usr/lib64/dovecot/auth/libdriver_sqlite.so Dec 08 11:48:16 auth: Debug: Module loaded: /usr/lib64/dovecot/auth/libmech_gssapi.so Dec 08 11:48:16 auth: Debug: passwd(korenevb@krasnodar.vbrr.ru,10.1.10.54): lookup Dec 08 11:48:16 auth: Info: passwd(korenevb@krasnodar.vbrr.ru,10.1.10.54): unknown user Dec 08 11:48:18 auth: Debug: client out: FAIL 1 user=korenevb@krasnodar.vbrr.ru Dec 08 11:48:34 pop3-login: Info: Aborted login (auth failed, 1 attempts): user=<korenevb@krasnodar.vbrr.ru>, method=PLAIN, rip=10.1.10.54, lip=10.1.10.53 Говорит, что пользователя такого нет, но пользователь есть, вот: [root@mxkras ~]# id korenevb uid=500(korenevb) gid=500(korenevb) groups=500(korenevb) [root@mxkras ~]# cat /etc/passwd | grep korenevb korenevb:x:500:500:Boris:/home/korenevb:/bin/bash [root@mxkras ~]# Настройки Dovecot: [root@mxkras ~]# doveconf # 2.0.9: /etc/dovecot/dovecot.conf # OS: Linux 2.6.32-279.el6.x86_64 x86_64 Red Hat Enterprise Linux Server release 6.3 (Santiago) auth_anonymous_username = anonymous auth_cache_negative_ttl = 1 hours auth_cache_size = 0 auth_cache_ttl = 1 hours auth_debug = yes auth_debug_passwords = yes auth_default_realm = krasnodar.vbrr.ru auth_failure_delay = 2 secs auth_first_valid_uid = 500 auth_gssapi_hostname = auth_krb5_keytab = auth_last_valid_uid = 0 auth_master_user_separator = auth_mechanisms = plain login auth_realms = auth_socket_path = auth-userdb auth_ssl_require_client_cert = no auth_ssl_username_from_cert = no auth_use_winbind = no auth_username_chars = abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ01234567890.-_@ auth_username_format = auth_username_translation = auth_verbose = yes auth_verbose_passwords = no auth_winbind_helper_path = /usr/bin/ntlm_auth auth_worker_max_count = 30 base_dir = /var/run/dovecot/ config_cache_size = 1 M debug_log_path = default_client_limit = 1000 default_idle_kill = 60 default_internal_user = dovecot default_login_user = dovenull default_process_limit = 100 default_vsz_limit = 256 M deliver_log_format = msgid=%m: %$ dict_db_config = director_doveadm_port = 0 director_mail_servers = director_servers = director_user_expire = 15 mins disable_plaintext_auth = no dotlock_use_excl = yes doveadm_socket_path = doveadm-server doveadm_worker_count = 0 first_valid_gid = 1 first_valid_uid = 500 hostname = imap_capability = imap_client_workarounds = imap_id_log = imap_id_send = imap_idle_notify_interval = 2 mins imap_logout_format = bytes=%i/%o imap_max_line_length = 64 k info_log_path = last_valid_gid = 0 last_valid_uid = 0 lda_mailbox_autocreate = no lda_mailbox_autosubscribe = no lda_original_recipient_header = libexec_dir = /usr/libexec/dovecot listen = * lmtp_proxy = no lmtp_save_to_detail_mailbox = no lock_method = fcntl log_path = /var/log/dovecot/dovecot.log log_timestamp = "%b %d %H:%M:%S " login_access_sockets = login_greeting = Dovecot ready. login_log_format = %$: %s login_log_format_elements = user=<%u> method=%m rip=%r lip=%l mpid=%e %c login_trusted_networks = mail_access_groups = mail_attachment_dir = mail_attachment_fs = sis posix mail_attachment_hash = %{sha1} mail_attachment_min_size = 128 k mail_cache_fields = flags mail_cache_min_mail_count = 0 mail_chroot = mail_debug = no mail_fsync = optimized mail_full_filesystem_access = no mail_gid = mail_home = mail_location = mbox:~/mail:INBOX=/var/mail/%u mail_log_prefix = "%s(%u): " mail_max_keyword_length = 50 mail_max_lock_timeout = 0 mail_max_userip_connections = 10 mail_never_cache_fields = imap.envelope mail_nfs_index = no mail_nfs_storage = no mail_plugin_dir = /usr/lib64/dovecot mail_plugins = mail_privileged_group = mail mail_save_crlf = no mail_temp_dir = /tmp mail_uid = mailbox_idle_check_interval = 30 secs mailbox_list_index_disable = no maildir_copy_with_hardlinks = yes maildir_stat_dirs = no maildir_very_dirty_syncs = no master_user_separator = mbox_dirty_syncs = yes mbox_dotlock_change_timeout = 2 mins mbox_lazy_writes = yes mbox_lock_timeout = 5 mins mbox_min_index_size = 0 mbox_read_locks = fcntl mbox_very_dirty_syncs = no mbox_write_locks = fcntl mdbox_preallocate_space = no mdbox_rotate_interval = 0 mdbox_rotate_size = 2 M mmap_disable = no passdb { args = deny = no driver = passwd master = no pass = no } pop3_client_workarounds = pop3_enable_last = no pop3_fast_size_lookups = no pop3_lock_session = no pop3_logout_format = top=%t/%p, retr=%r/%b, del=%d/%m, size=%s pop3_no_flag_updates = no pop3_reuse_xuidl = no pop3_save_uidl = no pop3_uidl_format = %08Xu%08Xv postmaster_address = protocols = imap pop3 quota_full_tempfail = no recipient_delimiter = + rejection_reason = Your message to <%t> was automatically rejected:%n%r rejection_subject = Rejected: %s sendmail_path = /usr/sbin/sendmail service anvil { chroot = empty client_limit = 0 drop_priv_before_exec = no executable = anvil extra_groups = group = idle_kill = 4294967295 secs privileged_group = process_limit = 1 process_min_avail = 1 protocol = service_count = 0 type = anvil unix_listener anvil-auth-penalty { group = mode = 0600 user = } unix_listener anvil { group = mode = 0600 user = } user = $default_internal_user vsz_limit = 18446744073709551615 B } service auth-worker { chroot = client_limit = 1 drop_priv_before_exec = no executable = auth -w extra_groups = group = idle_kill = 0 privileged_group = process_limit = 0 process_min_avail = 0 protocol = service_count = 1 type = unix_listener auth-worker { group = mode = 0600 user = $default_internal_user } user = vsz_limit = 18446744073709551615 B } service auth { chroot = client_limit = 4096 drop_priv_before_exec = no executable = auth extra_groups = group = idle_kill = 0 privileged_group = process_limit = 1 process_min_avail = 0 protocol = service_count = 0 type = unix_listener /var/spool/postfix/private/auth { group = postfix mode = 0660 user = postfix } unix_listener auth-client { group = mode = 0600 user = } unix_listener auth-login { group = mode = 0600 user = $default_internal_user } unix_listener auth-master { group = mode = 0600 user = } unix_listener auth-userdb { group = mode = 0600 user = } unix_listener login/login { group = mode = 0666 user = } user = $default_internal_user vsz_limit = 18446744073709551615 B } service config { chroot = client_limit = 0 drop_priv_before_exec = no executable = config extra_groups = group = idle_kill = 0 privileged_group = process_limit = 0 process_min_avail = 0 protocol = service_count = 0 type = config unix_listener config { group = mode = 0600 user = } user = vsz_limit = 18446744073709551615 B } service dict { chroot = client_limit = 1 drop_priv_before_exec = no executable = dict extra_groups = group = idle_kill = 0 privileged_group = process_limit = 0 process_min_avail = 0 protocol = service_count = 0 type = unix_listener dict { group = mode = 0600 user = } user = $default_internal_user vsz_limit = 18446744073709551615 B } service director { chroot = client_limit = 0 drop_priv_before_exec = no executable = director extra_groups = fifo_listener login/proxy-notify { group = mode = 00 user = } group = idle_kill = 4294967295 secs privileged_group = process_limit = 1 process_min_avail = 0 protocol = service_count = 0 type = unix_listener director-admin { group = mode = 0600 user = } unix_listener login/director { group = mode = 00 user = } user = $default_internal_user vsz_limit = 18446744073709551615 B } service dns_client { chroot = client_limit = 1 drop_priv_before_exec = no executable = dns-client extra_groups = group = idle_kill = 0 privileged_group = process_limit = 0 process_min_avail = 0 protocol = service_count = 0 type = unix_listener dns-client { group = mode = 0666 user = } unix_listener login/dns-client { group = mode = 0666 user = } user = $default_internal_user vsz_limit = 18446744073709551615 B } service doveadm { chroot = client_limit = 1 drop_priv_before_exec = no executable = doveadm-server extra_groups = group = idle_kill = 0 privileged_group = process_limit = 0 process_min_avail = 0 protocol = service_count = 1 type = unix_listener doveadm-server { group = mode = 0600 user = } user = vsz_limit = 18446744073709551615 B } service imap-login { chroot = login client_limit = 0 drop_priv_before_exec = no executable = imap-login extra_groups = group = idle_kill = 0 inet_listener imap { address = port = 1143 ssl = no } inet_listener imaps { address = port = 993 ssl = yes } privileged_group = process_limit = 0 process_min_avail = 0 protocol = imap service_count = 1 type = login user = $default_login_user vsz_limit = 64 M } service imap { chroot = client_limit = 1 drop_priv_before_exec = no executable = imap extra_groups = group = idle_kill = 0 privileged_group = process_limit = 1024 process_min_avail = 0 protocol = imap service_count = 1 type = unix_listener login/imap { group = mode = 0666 user = } user = vsz_limit = 18446744073709551615 B } service lmtp { chroot = client_limit = 0 drop_priv_before_exec = no executable = lmtp extra_groups = group = idle_kill = 0 privileged_group = process_limit = 0 process_min_avail = 0 protocol = lmtp service_count = 0 type = unix_listener lmtp { group = mode = 0666 user = } user = vsz_limit = 0 } service log { chroot = client_limit = 0 drop_priv_before_exec = no executable = log extra_groups = group = idle_kill = 0 privileged_group = process_limit = 1 process_min_avail = 0 protocol = service_count = 0 type = log user = vsz_limit = 18446744073709551615 B } service pop3-login { chroot = login client_limit = 0 drop_priv_before_exec = no executable = pop3-login extra_groups = group = idle_kill = 0 inet_listener pop3 { address = port = 1110 ssl = no } inet_listener pop3s { address = port = 995 ssl = yes } privileged_group = process_limit = 0 process_min_avail = 0 protocol = pop3 service_count = 1 type = login user = $default_login_user vsz_limit = 64 M } service pop3 { chroot = client_limit = 1 drop_priv_before_exec = no executable = pop3 extra_groups = group = idle_kill = 0 privileged_group = process_limit = 1024 process_min_avail = 0 protocol = pop3 service_count = 1 type = unix_listener login/pop3 { group = mode = 0666 user = } user = vsz_limit = 18446744073709551615 B } service ssl-params { chroot = client_limit = 0 drop_priv_before_exec = no executable = ssl-params extra_groups = group = idle_kill = 0 privileged_group = process_limit = 0 process_min_avail = 0 protocol = service_count = 0 type = startup unix_listener login/ssl-params { group = mode = 0666 user = } user = vsz_limit = 18446744073709551615 B } shutdown_clients = yes ssl = no ssl_ca = ssl_cert = </etc/pki/dovecot/certs/dovecot.pem ssl_cert_username_field = commonName ssl_cipher_list = ALL:!LOW:!SSLv2:!EXP:!aNULL ssl_key = </etc/pki/dovecot/private/dovecot.pem ssl_key_password = ssl_parameters_file = ssl-parameters.dat ssl_parameters_regenerate = 168 ssl_verify_client_cert = no syslog_facility = mail userdb { args = blocking=no driver = passwd } valid_chroot_dirs = verbose_auth = no verbose_proctitle = yes verbose_ssl = no version_ignore = no [root@mxkras ~]# В чём тогда проблема, может настройки неправильны? P.S. Настраивается в операционной системе - Red Hat Enterprise Linux Server release 6.3 (Santiago) Заранее благодарен, Борис. ... |
| 08.12.2014, 12:53:25 |
start [/forum/topic.php?desktop=1&fid=25&tid=1482264]: |
50ms |
55ms |
| others: | 407ms |
| total: | 592ms |
