Linux не грузится вообще после установки на ПК.
День добрый! Есть ПК с видеокартой: root@lubuntu:/media/lubuntu/C4E8-CAE6# lspci 00:00.0 Host bridge: Intel Corporation 82P965/G965 Memory Controller Hub (rev 02) 00:01.0 PCI bridge: Intel Corporation 82P965/G965 PCI Express Root Port (rev 02) 00:02.0 VGA compatible controller: Intel Corporation 82G965 Integrated Graphics Controller (rev 02) 00:1a.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #4 00:1a.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 00:1a.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller 00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 00:1d.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 00:1d.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 00:1d.2 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 00:1d.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev f0) 00:1f.0 ISA bridge: Intel Corporation 82801HB/HR (ICH8/R) LPC Interface Controller 00:1f.2 IDE interface: Intel Corporation 82801H (ICH8 Family) 4 port SATA Controller [IDE mode] 00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller 00:1f.5 IDE interface: Intel Corporation 82801HR/HO/HH (ICH8R/DO/DH) 2 port SATA Controller [IDE mode] 02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 01) root@lubuntu:/media/lubuntu/C4E8-CAE6# lsusb Bus 002 Device 003: ID 058f:6387 Alcor Micro Corp. Flash Drive Bus 002 Device 002: ID 1005:b113 Apacer Technology, Inc. Handy Steno 2.0/HT203 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub root@lubuntu:/media/lubuntu/C4E8-CAE6# На нём WindowsXP без проблем работает. Теперь необходимо, вместо ХР ставить убунту. После успешной установки убунту через LiveCD при перезагрузке после загрузки биоса даже граб не виден, только чёрный экран, иногда даже No signal. Если вынуть с этого ПК жёсткий диск и подключить на другой ПК с другими параметрами, то он там без проблем работает. Пробовал: 1. установить ОС ubuntu14.04, 12.04, ставить самое свежее ядро 3.17.6*, старые ядра: 2.6.32.*, не помогло 2. установить mesa-utils, не помогло 3. Intel(R) Graphics Installer for Linux* 1.0.7 говорит, что у меня нет видеокарты Intel и поэтому нечего обновлять 4. запустить только в текстовом режиме тоже такой результат выходит. 3. ставить дебиан вообще не вышло, так как даже LiveCD у него не запустился. Странно Live-CD без проблем работает, а после установки даже граб не может запуститься, или Кто-нибудь сталкивался с подобного рода глюками? Не знаю что делать. Спасибо за внимание! ... |
| 13.12.2014, 13:55:32 |
dpkg-reconfigure xserver-xorg не дал положительных результатов. Далее предоставляю то, что вывела команда lshw: root@lubuntu:/home/lubuntu# lshw PCI (sysfs) lubuntu description: Desktop Computer product: To Be Filled By O.E.M. (To Be Filled By O.E.M.) vendor: To Be Filled By O.E.M. version: To Be Filled By O.E.M. serial: To Be Filled By O.E.M. width: 32 bits capabilities: smbios-2.4 dmi-2.4 smp-1.4 smp configuration: boot=normal chassis=desktop cpus=1 family=To Be Filled By O.E.M. sku=To Be Filled By O.E.M. uuid=00020003-0004-0005-0006-000700080009 *-core description: Motherboard product: 965 Serial vendor: XZX Development&Technology CO.,LTD physical id: 0 version: Ver:1.4 serial: To be filled by O.E.M. slot: To Be Filled By O.E.M. *-firmware description: BIOS vendor: American Megatrends Inc. physical id: 0 version: 080014 date: 05/13/2008 size: 64KiB capacity: 448KiB capabilities: isa pci pnp apm upgrade shadowing escd cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer int10video acpi usb ls120boot zipboot biosbootspecification *-cpu description: CPU product: Intel(R) Celeron(R) D CPU 3.06GHz vendor: Intel Corp. physical id: 4 bus info: cpu@0 version: 15.6.5 serial: 0000-0F65-0000-0000-0000-0000 slot: CPU 1 size: 3066MHz capacity: 3066MHz width: 64 bits clock: 133MHz capabilities: boot fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx x86-64 constant_tsc pebs bts pni dtes64 monitor ds_cpl cid cx16 xtpr pdcm lahf_lm configuration: id=0 *-cache:0 description: L1 cache physical id: 5 slot: L1-Cache size: 16KiB capacity: 16KiB capabilities: internal write-back data *-cache:1 description: L2 cache physical id: 6 slot: L2-Cache size: 512KiB capacity: 512KiB capabilities: internal write-back unified *-memory description: System Memory physical id: f slot: System board or motherboard size: 1GiB *-bank:0 description: DIMM [empty] product: PartNum0 vendor: Manufacturer0 physical id: 0 serial: SerNum0 slot: DIMM0 *-bank:1 description: DIMM [empty] product: PartNum1 vendor: Manufacturer1 physical id: 1 serial: SerNum1 slot: DIMM1 *-bank:2 description: DIMM SDRAM Synchronous product: PartNum2 vendor: Manufacturer2 physical id: 2 serial: SerNum2 slot: DIMM2 size: 1GiB width: 64 bits *-bank:3 description: DIMM [empty] product: PartNum3 vendor: Manufacturer3 physical id: 3 serial: SerNum3 slot: DIMM3 *-pci description: Host bridge product: 82P965/G965 Memory Controller Hub vendor: Intel Corporation physical id: 100 bus info: pci@0000:00:00.0 version: 02 width: 32 bits clock: 33MHz configuration: driver=agpgart-intel resources: irq:0 *-pci:0 description: PCI bridge product: 82P965/G965 PCI Express Root Port vendor: Intel Corporation physical id: 1 bus info: pci@0000:00:01.0 version: 02 width: 32 bits clock: 33MHz capabilities: pci pm msi pciexpress normal_decode bus_master cap_list configuration: driver=pcieport resources: irq:40 *-display description: VGA compatible controller product: 82G965 Integrated Graphics Controller vendor: Intel Corporation physical id: 2 bus info: pci@0000:00:02.0 version: 02 width: 64 bits clock: 33MHz capabilities: msi pm vga_controller bus_master cap_list rom configuration: driver=i915 latency=0 resources: irq:43 memory:fea00000-feafffff memory:40000000-4fffffff ioport:dc00(size=8) *-usb:0 description: USB controller product: 82801H (ICH8 Family) USB UHCI Controller #4 vendor: Intel Corporation physical id: 1a bus info: pci@0000:00:1a.0 version: 00 width: 32 bits clock: 33MHz capabilities: uhci bus_master configuration: driver=uhci_hcd latency=0 resources: irq:16 ioport:d880(size=32) *-usb:1 description: USB controller product: 82801H (ICH8 Family) USB UHCI Controller #5 vendor: Intel Corporation physical id: 1a.1 bus info: pci@0000:00:1a.1 version: 00 width: 32 bits clock: 33MHz capabilities: uhci bus_master configuration: driver=uhci_hcd latency=0 resources: irq:21 ioport:d800(size=32) *-usb:2 description: USB controller product: 82801H (ICH8 Family) USB2 EHCI Controller #2 vendor: Intel Corporation physical id: 1a.7 bus info: pci@0000:00:1a.7 version: 00 width: 32 bits clock: 33MHz capabilities: pm debug ehci bus_master cap_list configuration: driver=ehci-pci latency=0 resources: irq:18 memory:fe9fbc00-fe9fbfff *-multimedia description: Audio device product: 82801H (ICH8 Family) HD Audio Controller vendor: Intel Corporation physical id: 1b bus info: pci@0000:00:1b.0 version: 00 width: 64 bits clock: 33MHz capabilities: pm msi pciexpress bus_master cap_list configuration: driver=snd_hda_intel latency=0 resources: irq:44 memory:50200000-50203fff *-pci:1 description: PCI bridge product: 82801H (ICH8 Family) PCI Express Port 1 vendor: Intel Corporation physical id: 1c bus info: pci@0000:00:1c.0 version: 00 width: 32 bits clock: 33MHz capabilities: pci pciexpress msi pm normal_decode bus_master cap_list configuration: driver=pcieport resources: irq:41 ioport:e000(size=4096) memory:feb00000-febfffff ioport:50000000(size=2097152) *-network description: Ethernet interface product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:02:00.0 logical name: eth0 version: 01 serial: 00:e1:4c:04:32:01 size: 100Mbit/s capacity: 100Mbit/s width: 64 bits clock: 33MHz capabilities: pm vpd msi pciexpress bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full ip=192.168.2.55 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s resources: irq:42 ioport:e800(size=256) memory:febff000-febfffff memory:febc0000-febdffff *-usb:3 description: USB controller product: 82801H (ICH8 Family) USB UHCI Controller #1 vendor: Intel Corporation physical id: 1d bus info: pci@0000:00:1d.0 version: 00 width: 32 bits clock: 33MHz capabilities: uhci bus_master configuration: driver=uhci_hcd latency=0 resources: irq:23 ioport:d480(size=32) *-usb:4 description: USB controller product: 82801H (ICH8 Family) USB UHCI Controller #2 vendor: Intel Corporation physical id: 1d.1 bus info: pci@0000:00:1d.1 version: 00 width: 32 bits clock: 33MHz capabilities: uhci bus_master configuration: driver=uhci_hcd latency=0 resources: irq:19 ioport:d400(size=32) *-usb:5 description: USB controller product: 82801H (ICH8 Family) USB UHCI Controller #3 vendor: Intel Corporation physical id: 1d.2 bus info: pci@0000:00:1d.2 version: 00 width: 32 bits clock: 33MHz capabilities: uhci bus_master configuration: driver=uhci_hcd latency=0 resources: irq:18 ioport:d080(size=32) *-usb:6 description: USB controller product: 82801H (ICH8 Family) USB2 EHCI Controller #1 vendor: Intel Corporation physical id: 1d.7 bus info: pci@0000:00:1d.7 version: 00 width: 32 bits clock: 33MHz capabilities: pm debug ehci bus_master cap_list configuration: driver=ehci-pci latency=0 resources: irq:23 memory:fe9fb800-fe9fbbff *-pci:2 description: PCI bridge product: 82801 PCI Bridge vendor: Intel Corporation physical id: 1e bus info: pci@0000:00:1e.0 version: f0 width: 32 bits clock: 33MHz capabilities: pci subtractive_decode bus_master cap_list *-isa description: ISA bridge product: 82801HB/HR (ICH8/R) LPC Interface Controller vendor: Intel Corporation physical id: 1f bus info: pci@0000:00:1f.0 version: 00 width: 32 bits clock: 33MHz capabilities: isa bus_master cap_list configuration: driver=lpc_ich latency=0 resources: irq:0 *-ide:0 description: IDE interface product: 82801H (ICH8 Family) 4 port SATA Controller [IDE mode] vendor: Intel Corporation physical id: 1f.2 bus info: pci@0000:00:1f.2 version: 00 width: 32 bits clock: 66MHz capabilities: ide pm bus_master cap_list configuration: driver=ata_piix latency=0 resources: irq:19 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:ff90(size=16) ioport:ffa0(size=16) *-serial UNCLAIMED description: SMBus product: 82801H (ICH8 Family) SMBus Controller vendor: Intel Corporation physical id: 1f.3 bus info: pci@0000:00:1f.3 version: 00 width: 32 bits clock: 33MHz configuration: latency=0 resources: memory:50204000-502040ff memory:50204100-5020410f ioport:400(size=32) *-ide:1 description: IDE interface product: 82801HR/HO/HH (ICH8R/DO/DH) 2 port SATA Controller [IDE mode] vendor: Intel Corporation physical id: 1f.5 bus info: pci@0000:00:1f.5 version: 00 width: 32 bits clock: 66MHz capabilities: ide pm bus_master cap_list configuration: driver=ata_piix latency=0 resources: irq:19 ioport:d000(size=8) ioport:cc00(size=4) ioport:c880(size=8) ioport:c800(size=4) ioport:c480(size=16) ioport:c400(size=16) *-scsi:0 physical id: 1 logical name: scsi2 capabilities: emulated *-cdrom description: DVD-RAM writer product: DVDRAM GH22NS40 vendor: HL-DT-ST physical id: 0.0.0 bus info: scsi@2:0.0.0 logical name: /dev/cdrom logical name: /dev/sr0 version: NL00 capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram configuration: ansiversion=5 status=nodisc *-scsi:1 physical id: 2 logical name: scsi3 capabilities: emulated *-disk description: ATA Disk product: SAMSUNG HD322GJ physical id: 0.0.0 bus info: scsi@3:0.0.0 logical name: /dev/sda version: 1AR1 serial: S2BSJ9EZA00045 size: 298GiB (320GB) capabilities: partitioned partitioned:dos configuration: ansiversion=5 sectorsize=512 signature=c045c045 *-volume:0 description: Linux swap volume physical id: 1 bus info: scsi@3:0.0.0,1 logical name: /dev/sda1 version: 1 serial: 08bf3995-6ff9-48c9-88bb-c44031b05552 size: 1906MiB capacity: 1906MiB capabilities: primary nofs swap initialized configuration: filesystem=swap pagesize=4096 *-volume:1 description: EXT4 volume vendor: Linux physical id: 2 bus info: scsi@3:0.0.0,2 logical name: /dev/sda2 version: 1.0 serial: c52b4c8d-9adf-4a49-8f12-5344d7fee18b size: 139GiB capacity: 139GiB capabilities: primary bootable journaled extended_attributes large_files huge_files dir_nlink extents ext4 ext2 initialized configuration: created=2002-01-01 00:02:41 filesystem=ext4 lastmountpoint=/ modified=2014-12-13 10:36:09 mounted=2014-12-13 10:36:09 state=clean *-volume:2 description: EXT4 volume vendor: Linux physical id: 3 bus info: scsi@3:0.0.0,3 logical name: /dev/sda3 version: 1.0 serial: 9f082f1b-4a70-424f-8e95-ca478145603f size: 156GiB capacity: 156GiB capabilities: primary journaled extended_attributes large_files huge_files dir_nlink extents ext4 ext2 initialized configuration: created=2002-01-01 00:02:45 filesystem=ext4 lastmountpoint=/home modified=2014-12-13 10:36:09 mounted=2014-12-13 10:36:09 state=clean *-scsi:2 physical id: 3 bus info: usb@2:5 logical name: scsi4 capabilities: emulated scsi-host configuration: driver=usb-storage *-disk description: SCSI Disk physical id: 0.0.0 bus info: scsi@4:0.0.0 logical name: /dev/sdb size: 14GiB (16GB) capabilities: partitioned partitioned:dos configuration: sectorsize=512 signature=a65abc46 *-volume description: Windows FAT volume vendor: SYSLINUX physical id: 1 bus info: scsi@4:0.0.0,1 logical name: /dev/sdb1 logical name: /cdrom version: FAT32 serial: 6cbe-32ea size: 14GiB capacity: 14GiB capabilities: primary bootable fat initialized configuration: FATs=2 filesystem=fat mount.fstype=vfat mount.options=ro,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro state=mounted *-scsi:3 physical id: 5 bus info: usb@2:6 logical name: scsi5 capabilities: emulated scsi-host configuration: driver=usb-storage *-disk description: SCSI Disk physical id: 0.0.0 bus info: scsi@5:0.0.0 logical name: /dev/sdc size: 8032MiB (8422MB) capabilities: partitioned partitioned:dos configuration: sectorsize=512 signature=71c7e09c *-volume description: Windows FAT volume vendor: SYSLINUX physical id: 1 bus info: scsi@5:0.0.0,1 logical name: /dev/sdc1 logical name: /media/lubuntu/C4E8-CAE6 version: FAT32 serial: c4e8-cae6 size: 8031MiB capacity: 8031MiB capabilities: primary bootable fat initialized configuration: FATs=2 filesystem=fat mount.fstype=vfat mount.options=rw,nosuid,nodev,relatime,uid=999,gid=999,fmask=0022,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro state=mounted root@lubuntu:/home/lubuntu# ... |
| 13.12.2014, 14:06:36 |
Iceberg1985, Как ты делаешь lspci, если у тебя ОС " не грузится вообще "? ... |
| 13.12.2014, 16:06:36 |
FishHook, очевидно, данные собраны из livecd lubuntu, который специально делается максимально всеядным. Лобро прожаловать в Швабодный Линукс, сынок ! Если ты не кернелхакер и не готов отдать несколько лет на освоение профессии разработчика драйверов - будь как все. Покупай только широкораспространенное железо. ... |
| 14.12.2014, 13:58:27 |
Спасибо всем! Вопрос так и остался открытым, так как на новых сбоках винды тоже не грузится этот ПК, только старвые с ним работают нормально. Кажется, это железо уже считается морально устаревшей и не поддерживается более. ... |
| 15.12.2014, 07:19:02 |
попробовать другой дистрибутив ... |
| 15.12.2014, 09:55:10 |
sldпопробовать другой дистрибутив Друг мой, испробовал почти весь дистрибутив из ветки дебиана, убунту, ничего не помогло. Может у тебя есть конкретный пример? Какой конкретно дистрибутив можешь предложить попробовать? Спасибо заранее! ... |
| 18.02.2015, 06:01:16 |
Iceberg1985sldпопробовать другой дистрибутив Друг мой, испробовал почти весь дистрибутив из ветки дебиана, убунту, ничего не помогло. Может у тебя есть конкретный пример? Какой конкретно дистрибутив можешь предложить попробовать? Спасибо заранее! Вопрос не ко мне и в друзья не набиваюсь, но все же рекомендую попробовать OpenSUSE и Fedora - как пользовательские дистрибутивы, не имеющие ничего общего с debian (раз все deb-based не взлетели). ... |
| 18.02.2015, 16:41:35 |
ну у меня конкретный пример был, чего только не ставил все как-то косячно вставало (ubuntu, fedora, opensuse, linuxmint). воткнул debian красота все заколосилось, под ним и сижу теперь. так чта попробовать OpenSUSE и Fedora . возможно драйвера проприентарные не ставить или наоборот ставить на видюху. ... |
| 19.02.2015, 08:23:14 |
А интересно версия биоса какая на ноутбуке используеться?Есть некое подозрение на использование технологии, на блокировку установки другой ОС.Сейчас подобным многие производители железа грешат.Это мало вероятно, но если, это так, то можно перепрошить BIOS, используя альтернативу. Если загрузчик выдает полное молчание, то, взамен GRUB, можно использовать дистрибутивы с LiLO загрузчиком, и старые версии > 3 года. ... |
| 27.02.2015, 14:40:48 |
start [/forum/topic.php?desktop=1&fid=25&tid=1482171]: |
23ms |
45ms |
65ms |
| others: | 336ms |
| total: | 518ms |
