Не отправляется почта через скрипт
Здравствуйте ув. форумчане. Подскажите пожалуйста как решить проблему. Если в консоли запустить echo “test-test-test” | mail s "Subject" netscout@yandex.ru то почта приходит исправно. А Вот через ПХП скрипт никак не шлёт, лог привожу: May 14 12:59:00 158214 sendmail[3712]: t4EAwxVK003712: Authentication-Warning: 158214.vs.webtropia.com: apache set sender to webmaster@josefin.ru using -f May 14 12:59:00 158214 sendmail[3712]: t4EAwxVK003712: from=webmaster@josefin.ru, size=105, class=0, nrcpts=1, msgid=<201505141058.t4EAwxVK003712@158214.vs.webtropia.com>, relay=apache@localhost May 14 12:59:00 158214 sendmail[3713]: STARTTLS=server, relay=localhost [127.0.0.1], version=TLSv1/SSLv3, verify=NO, cipher=DHE-RSA-AES256-GCM-SHA384, bits=256/256 May 14 12:59:00 158214 sendmail[3712]: STARTTLS=client, relay=[127.0.0.1], version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-GCM-SHA384, bits=256/256 May 14 12:59:00 158214 sendmail[3712]: t4EAwxVK003712: to=netscout@yandex.ru, ctladdr=webmaster@josefin.ru (48/48), delay=00:00:01, xdelay=00:00:00, mailer=relay, pri=30105, relay=[127.0.0.1] [127.0.0.1], dsn=5.6.0, stat=Data format error May 14 12:59:00 158214 sendmail[3712]: t4EAwxVK003712: t4EAwxVL003712: DSN: Data format error May 14 12:59:00 158214 sendmail[3713]: t4EAx0HH003713: <webmaster@josefin.ru>... No such user here May 14 12:59:00 158214 sendmail[3712]: t4EAwxVL003712: to=webmaster@josefin.ru, delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=31129, relay=[127.0.0.1], dsn=5.3.0, stat=User unknown May 14 12:59:00 158214 sendmail[3713]: t4EAx0HH003713: from=<>, size=1129, class=0, nrcpts=0, bodytype=8BITMIME, proto=ESMTP, daemon=MTA, relay=localhost [127.0.0.1] May 14 12:59:00 158214 sendmail[3712]: t4EAwxVL003712: t4EAwxVM003712: return to sender: User unknown May 14 12:59:00 158214 sendmail[3713]: t4EAx0HJ003713: from=<>, size=4244, class=0, nrcpts=1, msgid=<201505141059.t4EAwxVM003712@158214.vs.webtropia.com>, bodytype=8BITMIME, proto=ESMTP, daemon=MTA, relay=localhost [127.0.0.1] May 14 12:59:00 158214 sendmail[3712]: t4EAwxVM003712: to=postmaster, delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=32153, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (t4EAx0HJ003713 Message accepted for delivery) May 14 12:59:00 158214 sendmail[3714]: t4EAx0HJ003713: to=root, delay=00:00:00, xdelay=00:00:00, mailer=local, pri=34537, dsn=2.0.0, stat=Sent ... |
| 14.05.2015, 14:16:31 |
проблема решена... помогло простое удаление строки с проблемным доменом somedomain.com из файла /etc/mail/local-host-names всем спасибо, в том числе и автору блога http://prostoorgru.blogspot.com/2009/11/sendmail-dsn-data-format-error.html ... |
| 14.05.2015, 14:32:38 |
start [/forum/topic.php?desktop=1&fid=25&tid=1482097]: |
40ms |
56ms |
| others: | 322ms |
| total: | 486ms |
