Mazda 3 2014
Приветствую всех. Нужна небольшая помощь. В машине стоит Linux: Данные по ОС: Linux cmu 3.0.35 #1 SMP PREEMPT Tue Jul 29 17:03:04 EDT 2014 armv71 GNU\Linux BusyBox v1/19/2 (2014-05-26 21:41:02 IST) milti-call binary хочу снять дамп и поковырять на ПК, но есть небольшой нюанс, дамп не снимается. Вот список разделов: /tmp/root # cat /proc/partitions major minor #blocks name 31 0 64 mtdblock0 31 1 64 mtdblock1 31 2 128 mtdblock2 31 3 128 mtdblock3 31 4 64 mtdblock4 31 5 448 mtdblock5 31 6 7168 mtdblock6 31 7 128 mtdblock7 253 0 22372 ffx00 253 16 931056 ffx01 253 17 489408 ffx01p1 253 18 63360 ffx01p2 253 19 63360 ffx01p3 253 20 314496 ffx01p4 179 0 3842048 mmcblk0 179 1 3256064 mmcblk0p1 179 2 585976 mmcblk0p2 179 16 1024 mmcblk0boot1 179 8 1024 mmcblk0boot0 8 0 31490048 sda 8 1 31489024 sda1 Вот более подробно: /tmp/root # fdisk -l Disk /dev/mtdblock0: 0 MB, 65536 bytes 255 heads, 63 sectors/track, 0 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk /dev/mtdblock0 doesn't contain a valid partition table Disk /dev/mtdblock1: 0 MB, 65536 bytes 255 heads, 63 sectors/track, 0 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk /dev/mtdblock1 doesn't contain a valid partition table Disk /dev/mtdblock2: 0 MB, 131072 bytes 255 heads, 63 sectors/track, 0 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk /dev/mtdblock2 doesn't contain a valid partition table Disk /dev/mtdblock3: 0 MB, 131072 bytes 255 heads, 63 sectors/track, 0 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk /dev/mtdblock3 doesn't contain a valid partition table Disk /dev/mtdblock4: 0 MB, 65536 bytes 255 heads, 63 sectors/track, 0 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk /dev/mtdblock4 doesn't contain a valid partition table Disk /dev/mtdblock5: 0 MB, 458752 bytes 255 heads, 63 sectors/track, 0 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk /dev/mtdblock5 doesn't contain a valid partition table Disk /dev/mtdblock6: 7 MB, 7340032 bytes 255 heads, 63 sectors/track, 0 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk /dev/mtdblock6 doesn't contain a valid partition table Disk /dev/mtdblock7: 0 MB, 131072 bytes 255 heads, 63 sectors/track, 0 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk /dev/mtdblock7 doesn't contain a valid partition table Note: sector size is 4096 (not 512) Disk /dev/ffx00: 22 MB, 22908928 bytes 2 heads, 16 sectors/track, 174 cylinders Units = cylinders of 32 * 4096 = 131072 bytes Disk /dev/ffx00 doesn't contain a valid partition table Note: sector size is 4096 (not 512) Disk /dev/ffx01: 953 MB, 953401344 bytes 6 heads, 48 sectors/track, 808 cylinders Units = cylinders of 288 * 4096 = 1179648 bytes Device Boot Start End Blocks Id System /dev/ffx01p1 1 425 489408 83 Linux /dev/ffx01p2 426 480 63360 83 Linux /dev/ffx01p3 481 535 63360 83 Linux /dev/ffx01p4 536 808 314496 83 Linux Disk /dev/mmcblk0: 3934 MB, 3934257152 bytes 4 heads, 16 sectors/track, 120064 cylinders Units = cylinders of 64 * 512 = 32768 bytes Device Boot Start End Blocks Id System /dev/mmcblk0p1 18313 120064 3256064 83 Linux /dev/mmcblk0p2 1 18312 585976 83 Linux Partition table entries are not in disk order Disk /dev/mmcblk0boot1: 1 MB, 1048576 bytes 4 heads, 16 sectors/track, 32 cylinders Units = cylinders of 64 * 512 = 32768 bytes Disk /dev/mmcblk0boot1 doesn't contain a valid partition table Disk /dev/mmcblk0boot0: 1 MB, 1048576 bytes 4 heads, 16 sectors/track, 32 cylinders Units = cylinders of 64 * 512 = 32768 bytes Disk /dev/mmcblk0boot0 doesn't contain a valid partition table Disk /dev/sda: 32.2 GB, 32245809152 bytes 256 heads, 63 sectors/track, 3905 cylinders Units = cylinders of 16128 * 512 = 8257536 bytes Device Boot Start End Blocks Id System /dev/sda1 * 1 3906 31489024 c Win95 FAT32 (LBA) На сколько я понял мне надо 2 раздела: Disk /dev/mmcblk0: 3934 MB, 3934257152 bytes и Disk /dev/ffx01: 953 MB, 953401344 bytes При попытке сделать снимок, вот такое сообщение: /tmp/mnt # chmod 777 /mnt/sda /tmp/mnt # dd if=/dev/mmcblk0 of=/mnt/sda/image.img dd: writing '/mnt/sda/image.img': No space left on device 252361+0 records in 252360+0 records out 129208320 bytes (123.2MB) copied, 15.680817 seconds, 7.9MB/s Тоже самое и с разделом на 953Мб. Флешка 32ГБ. В итоге на флешке ничего нет. Куда оно копирует не понятно. Подскажите. может я что-то не то делаю? И как сделать лучше? ... |
| 23.07.2015, 14:50:21 |
Mazda 3 2014
Valery87, а флэшка у тебя ТОЧНО на /mnt/sda примонтирована (в rw)? touch /mnt/sda/1.txt файл на флэшке создает? ... |
| 23.07.2015, 16:02:34 |
Mazda 3 2014
debosh, Сейчас нет возможности посмотреть. но команда chmod проходит нормально.Это не может быть связано с ФС? раздел в 4Гб я смогу на fat32 записать? ... |
| 23.07.2015, 16:15:58 |
Mazda 3 2014
Попробовал, файл не пишется. При переходе в этот раздел ls ничего не показывает. Пробовал перемонтировать, тоже. Безрезультатно. ... |
| 23.07.2015, 16:42:34 |
Mazda 3 2014
+ к сказанному в конфигах нашел ссылки на xubuntu, вероятно сборка основана на ней. При попытке отмонтировать раздел sda1, вылазит сообщение что раздел занят. ... |
| 23.07.2015, 20:45:47 |
Mazda 3 2014
файла fstab не существует. ... |
| 23.07.2015, 20:46:45 |
Mazda 3 2014
Valery87, вывод mount покажи ... |
| 24.07.2015, 06:59:22 |
Mazda 3 2014
Там может быть установлена защина от копирования на уровне железа или что-то в этом роде.Просто так снять дамп не получиться стандартными средствами.Защита реализована на уровне прошивки и BIOS. ... |
| 25.07.2015, 10:34:15 |
Mazda 3 2014
dd if=/dev/mmcblk0 of=/dev/null работает? Попробовать подмонтировать NFS и скопировать? ... |
| 25.07.2015, 22:14:03 |
Mazda 3 2014
Вывод mount: jci /tmp/root # mount rootfs on / type rootfs (rw) none on /sys type sysfs (rw,relatime) none on /proc type proc (rw,relatime) none on /dev type devtmpfs (rw,relatime,size=8192k,nr_inodes=96342,mode=755) /dev/ffx01p1 on / type relfs (ro,noatime) none on /sys type sysfs (rw,relatime) none on /proc type proc (rw,relatime) none on /dev type devtmpfs (rw,relatime,size=8192k,nr_inodes=96342,mode=755) none on /tmp type tmpfs (rw,relatime,size=131072k) /dev/ffx01p4 on /tmp/mnt/data type relfs (rw,noatime) /dev/mmcblk0p2 on /tmp/mnt/data_persist type relfs (rw,noatime) /dev/mtdblock5 on /config-mfg type squashfs (ro,relatime) none on /dev/mqueue type mqueue (rw,relatime) none on /dev/pts type devpts (rw,relatime,mode=600) /dev/mmcblk0p1 on /tmp/mnt/resources type relfs (ro,noatime) /dev/sda1 on /tmp/mnt/sda1 type vfat (ro,relatime,fmask=0000,dmask=0000,allow_utime=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro) /tmp/root # ... |
| 26.07.2015, 09:25:55 |
Mazda 3 2014
Valery87, ээээ.. /tmp/mnt # dd if=/dev/mmcblk0 of= /mnt/sda/ image.img dd: writing ' /mnt/sda/ image.img': No space left on device ==== /dev/sda1 on /tmp/mnt/sda1 type vfat (ro,relatime,fmask=0000,dmask=0000,allow_utime=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro) ? ... |
| 29.07.2015, 10:27:05 |
start [/forum/topic.php?desktop=1&fid=25&tid=1481995]: |
57ms |
75ms |
| others: | 358ms |
| total: | 560ms |
