powered by simpleCommunicator - 2.0.59     © 2025 Programmizd 02
Форумы / Unix-системы [игнор отключен] [закрыт для гостей] / Подскажите по настройкам apache2
2 сообщений из 2, страница 1 из 1
    #39142911
Vladimir_Praha
Добрый день, подскажите пожалуйста по настройкам Апача, имеется следующая конфигурация
Код: sql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
76.
77.
78.
79.
80.
81.
82.
83.
84.
85.
86.
87.
88.
89.
90.
91.
92.
93.
94.
95.
96.
97.
98.
99.
100.
101.
102.
103.
104.
105.
106.
107.
108.
109.
110.
111.
112.
113.
114.
115.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# NOTE!  If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the LockFile documentation (available
# at <URL:http://httpd.apache.org/docs/2.2/mod/mpm_common.html#lockfile>);
# you will save yourself a lot of trouble.
# Do NOT add a slash at the end of the directory path.
#ServerRoot "/etc/apache2"
# The accept serialization lock file MUST BE STORED ON A LOCAL DISK.
LockFile ${APACHE_LOCK_DIR}/accept.lock
# PidFile: The file in which the server should record its process
# identification number when it starts.
# This needs to be set in /etc/apache2/envvars
PidFile ${APACHE_PID_FILE}
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 500
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 15
## Server-Pool Size Regulation (MPM specific)
# prefork MPM
# StartServers: number of server processes to start
# MinSpareServers: minimum number of server processes which are kept spare
# MaxSpareServers: maximum number of server processes which are kept spare
# MaxClients: maximum number of server processes allowed to start
# MaxRequestsPerChild: maximum number of requests a server process serves
<IfModule mpm_prefork_module>
    StartServers           5
    MinSpareServers        5
    MaxSpareServers       10
    MaxClients           100
    MaxRequestsPerChild 4096
</IfModule>
# worker MPM
# StartServers: initial number of server processes to start
# MaxClients: maximum number of simultaneous client connections
# MinSpareThreads: minimum number of worker threads which are kept spare
# MaxSpareThreads: maximum number of worker threads which are kept spare
# ThreadLimit: ThreadsPerChild can be changed to this maximum value during a
#              graceful restart. ThreadLimit can only be changed by stopping
#              and starting Apache.
# ThreadsPerChild: constant number of worker threads in each server process
<IfModule mpm_worker_module>
    StartServers          2
    MinSpareThreads      25
    MaxSpareThreads      75
    ThreadLimit          64
    ThreadsPerChild      25
    MaxClients          150
    MaxRequestsPerChild   0
</IfModule>
# event MPM
<IfModule mpm_event_module>
    StartServers          2
    MaxClients          150
    MinSpareThreads      25
    MaxSpareThreads      75
    ThreadLimit          64
    ThreadsPerChild      25
</IfModule>
# These need to be set in /etc/apache2/envvars
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives.  See also the AllowOverride
# directive.
AccessFileName .htaccess
работает все это дело в префорк, на сервере порядка 200 сайтов, пугает меня процесс апача отдельно взятый который грузит память до 70-80мб
Код: sql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
 2632 mysql     20   0 4951m 4.6g  12m S  457 14.9  14914:20 /usr/sbin/mysqld --basedir=/usr --da
 3445 www-data  20   0  292m  79m 7272 R   94  0.3   0:57.85 /usr/sbin/apache2 -k start
 4397 www-data  20   0  275m  63m 7348 S   30  0.2   0:19.49 /usr/sbin/apache2 -k start
 3355 www-data  20   0  302m  90m 6304 S   24  0.3   0:27.98 /usr/sbin/apache2 -k start
 4360 www-data  20   0  281m  65m 5556 S   15  0.2   0:11.47 /usr/sbin/apache2 -k start
 3424 www-data  20   0  278m  65m 5924 S   14  0.2   0:15.08 /usr/sbin/apache2 -k start
 4370 www-data  20   0  279m  64m 6076 S   14  0.2   0:20.91 /usr/sbin/apache2 -k start
 4450 www-data  20   0  275m  61m 6072 S   14  0.2   0:09.92 /usr/sbin/apache2 -k start
 4352 www-data  20   0  275m  61m 6164 S   12  0.2   0:14.31 /usr/sbin/apache2 -k start
 4435 www-data  20   0  280m  64m 6044 S   12  0.2   0:17.28 /usr/sbin/apache2 -k start
 4327 www-data  20   0  285m  71m 5636 S   10  0.2   0:09.72 /usr/sbin/apache2 -k start
 3310 www-data  20   0  279m  64m 6776 S    9  0.2   0:31.19 /usr/sbin/apache2 -k start
 3246 www-data  20   0  270m  58m 6816 R    5  0.2   0:24.91 /usr/sbin/apache2 -k start
 4454 www-data  20   0  286m  72m 6044 S    2  0.2   1:12.21 /usr/sbin/apache2 -k start
 2587 www-data  20   0  286m  74m 7508 S    1  0.2   0:47.20 /usr/sbin/apache2 -k start
 1872 gitlab    20   0  859m  99m 1360 S    0  0.3   3:59.82 resque-1.20.0: Waiting for post_rece
 3447 www-data  20   0  287m  74m 6612 S    0  0.2   0:14.11 /usr/sbin/apache2 -k start
 4357 www-data  20   0  281m  66m 7004 S    0  0.2   0:12.11 /usr/sbin/apache2 -k start
 4373 www-data  20   0  275m  63m 6324 S    0  0.2   1:02.64 /usr/sbin/apache2 -k start
подскажите пожалуйста что где можно оптимизировать или подкрутить в апаче? Заранее признателен за советы
    #39146105
Q.Tarantino
Vladimir_Prahaпугает меня процесс апача отдельно взятый который грузит память до 70-80мб
а сколько он должен отъедать? 64кб???
