Простейший шлюз на smtp.gmail.com
Настроил постфикс на убунту 14-04 теперь вылетает ошибка Feb 8 04:11:27 ubuntu-eME728 postfix/smtpd[4673]: NOQUEUE: reject: RCPT from unknown[192.168.1.156]: 454 4.7.1 <zafar.zainulloev@gmail.com>: Relay access denied; from=<yatest111@gmail.com> to=<yatest111@gmail.com> proto=ESMTP helo=<192.168.1.156> Feb 8 04:11:27 ubuntu-eME728 postfix/smtpd[4673]: disconnect from unknown[192.168.1.156] Не подскажете в чем дело ... |
| 08.02.2016, 12:18:10 |
RomantiktjRelay access deniedзапрет на пересылку. Смотри ограничения, выставленные в smtpd_*_restrictions ... |
| 08.02.2016, 12:35:51 |
bga83, Таковых не нашёл вроде как # See /usr/share/postfix/main.cf.dist for a commented, more complete version # Debian specific: Specifying a file name will cause the first # line of that file to be used as the name. The Debian default # is /etc/mailname. #myorigin = /etc/mailname smtpd_banner = $myhostname ESMTP $mail_name (Ubuntu) biff = no # appending .domain is the MUA's job. append_dot_mydomain = no # Uncomment the next line to generate "delayed mail" warnings #delay_warning_time = 4h readme_directory = no # TLS parameters smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key smtpd_use_tls=yes smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache smtp_sasl_auth_enable = yes smtp_sasl_password_maps = hash:/etc/postfix/smtp_auth smtp_sasl_security_options = noanonymous # See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for # information on enabling SSL in the smtp client. myhostname = ubuntu-eME728 alias_maps = hash:/etc/aliases alias_database = hash:/etc/aliases mydestination = ubuntu-eME728, localhost.localdomain, , localhost relayhost =[smtp.gmail.com]:587 mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128 mailbox_size_limit = 0 recipient_delimiter = + inet_interfaces = all inet_protocols = all myorigin = /etc/mailname ... |
| 08.02.2016, 13:10:13 |
RomantiktjТаковых не нашёл вроде какесли они явно не указаны в конфиге это еще ни о чем не говорит. Надо смотреть вывод postconf ... |
| 08.02.2016, 14:42:27 |
start [/forum/topic.php?desktop=1&fid=25&tid=1481790]: |
30ms |
56ms |
89ms |
| others: | 332ms |
| total: | 569ms |
