Ребята помогите разобратьца!
Как в PHP закадировать строку? строка: AT&T is a big company и получить к примеру такое дело: AT%26T%20is%20a%20big%20company. Тоесть, в место пробела ставить %20 а в место & ставить %26. За рание спосибо! ... |
| 25.02.2004, 16:06 |
Вот так авторrawurldecode Decode URL-encoded strings (PHP 3, PHP 4 ) string rawurldecode ( string str ) Returns a string in which the sequences with percent (%) signs followed by two hex digits have been replaced with literal characters. For example, the string foo%20bar%40baz decodes into foo bar@baz. Note: rawurldecode() does not decode plus symbols ('+') into spaces. urldecode() does. See also rawurlencode(), urldecode(), urlencode(). User contributed notes: ronen at greyzone dot com (07-Mar-2002 06:08) This is a unicode safe version of rawurldecode. encoded entities %unnnn n={0..F} get decoded to matching mutlibyte utf-8 entities. Note: this function uses utf8Encode() which I posted in the comments section for PHP function utf8_encode ( http://www.php.net/manual/function.utf8-encode.php ). /** * RFC1738 compliant replacement to PHP's rawurldecode - which actually works with unicode (using utf-8 encoding) * @param $source [STRING] * @return unicode safe rawurldecoded string [STRING] * @access public */ function utf8RawUrlDecode ($source) { $decodedStr = ''; $pos = 0; $len = strlen ($source); while ($pos < $len) { $charAt = substr ($source, $pos, 1); if ($charAt == '%') { $pos++; $charAt = substr ($source, $pos, 1); if ($charAt == 'u') { // we got a unicode character $pos++; $unicodeHexVal = substr ($source, $pos, 4); $unicode = hexdec ($unicodeHexVal); $entity = "". $unicode . ';'; $decodedStr .= utf8Encode ($entity); $pos += 4; } else { // we have an escaped ascii character $hexVal = substr ($source, $pos, 2); $decodedStr .= chr (hexdec ($hexVal)); $pos += 2; } } else { $decodedStr .= $charAt; $pos++; } } return $decodedStr; } и вот так тоже авторrawurlencode URL-encode according to RFC 1738 (PHP 3, PHP 4 ) string rawurlencode ( string str ) Returns a string in which all non-alphanumeric characters except -_. have been replaced with a percent (%) sign followed by two hex digits. This is the encoding described in RFC 1738 for protecting literal characters from being interpreted as special URL delimiters, and for protecting URL's from being mangled by transmission media with character conversions (like some email systems). For example, if you want to include a password in an FTP URL: Example 997. rawurlencode() example 1 copy to clipboard <?php echo '<a href="ftp://user:', rawurlencode('foo @+%/'), '@ftp.my.com/x.txt">'; ?> Or, if you pass information in a PATH_INFO component of the URL: Example 998. rawurlencode() example 2 copy to clipboard <?php echo '<a href="http://x.com/department_list_script/', rawurlencode('sales and marketing/Miami'), '">'; ?> See also rawurldecode(), urldecode(), urlencode() and » RFC 1738. User contributed notes: Andrew Eigus (24-Jan-2003 09:31) note that if you implement your own server request engine in the HTTP manner like: GET $request_uri you should first split all parts of the $request_uri path and rawurlencode() each part, then concatenate those parts back again. this function will translate the URI correctly: function translate_uri($uri) { $parts = explode('/', $uri); for ($i = 0; $i < count($parts); $i++) { $parts[$i] = rawurlencode($parts[$i]); } return implode('/', $parts); } because if you do rawurlencode() over the whole URI, path separator characters '/' are also encoded and request will not happen to be correct. '/' characters should not be encoded, only those parts in between. hope this helps someone like me... (15-Nov-2002 01:30) Note that RFC 1738 has been amended: The "[" and "]" are no longer considered unsafe, but instead are now considered "reserved", meaning that they CAN be used in URLs! Currently this usage has only been allowed in the hostname part, but there are some proposals to allow such use in some URL schemes. Similar extensions are now found that use the "{}" characters as "reserved" characters with special semantics, instead of "unsafe" characters that must be URL encoded... Note also that some characters are currently "reserved" but should have instead been considered as "unsafe": this includes the parenthesis "()" which are clearly unsafe when a URL is used in MIME headers. Because of this, if a valid URL contains "()" characters, one should use an upper-level encoding to either enclose the URL with a pair of "unsafe" characters defined in the upper-level protocol (for example a "<>" pair in MIME headers, because these characters cannot be part of a valid URL)... (15-Nov-2002 01:20) About the ";" reserved character in URLs: rawurlencode() will encode it with a "%2A" triplet. When used on the path part of a URL, this will break the usage defined in URL RFCs, that allows specifying additional parameters to *EACH* element of a path (separated by "/"). So if a path element contains a ";" character (some filesystems allow it, but this is not recommanded) as part of a directory name, this character must be encoded so that it won't be mixed with a parameter extension. This mapping is allowed on URLs that use a hierarchical scheme (HTTP, HTTPS, FTP, FILE, ...), so that each path element prefixed by "/" can have additional navigational parameters such as authorization strings or semantic parameters. The generic format of a path element may include path elements such as: "/." or "/.." or "/.specialname" or "/regularname" Each part may be followed by a ";" and other parameters separated by ";". These parameters can be eithger ordered or unordered. Unordered parameters have a symbolic name separated from their value with an equal sign. Do not mix path element parameters with a query string: these parameters are directly attached to the individual path element, and this makes a difference when this path element is not the last one of the URL. These parameters are part of the resource name (unlike the query string), and the semantic of "." and ".." apply to the full path element with its parameters, so that: "/subdir1/subdir2/page.html;charset=UTF-8/../index.html" will resolve to "/subdir1/index.html". Note that: "/subdir1/subdir2/page.html;charset=UTF-8" designates a DISTINCT resource name from: "/subdir1/subdir2/page.html" It does not necessarily involves a query, and so it can be cached by default (unlike URLs that contain a query string). When using path element parameters, their optional name and required value must be rawurlencode()'d separately before inserting ";" and "=" parameters and creating the path elements that will be imploded in the full path. The consequence is that you MUST not urlencode() or rawurlencode individual path elements, without first parsing them: - first explode the path into its path lements separated by "/" - then explode each path element in their name and parameters separated by ";" characters - then split path element parameters that contain a "=" sign into a name/value pair. - make sure that unordered path paremeters (that have been cut according to "=" into a pair) are specified *after* ordered parameters (including the main path element name) in each path element, and that no two unordered parameters have the same name (this restriction does not occur on unordered, unnamed parameters which only supply a value). - finally you can interpret rawurlencoded names and values that constitute each path element. Note also that some non-compliant HTTP servers consider that named parameters are ordered, and don't add a semantic to the ";" and "=" used to break up the list of path element parameters. On client agents, when validating URLs, it's best then not to try to interpret this list, and you should just split the main part of a path element and the parameters list by isolating the first ";" that introduces this list. However, the encoded parameter list cannot include any "/" parameter. Caveats: note that path element parameters (introduced by ";") may be used on upper levels of a hierarchic URL, even before the final document name and its query parameters. When building lists of URLs, you should not separate URLs blindly with a ";" separator, as each URL may include a ";" character, in their path part (the ";" character cannot ocur safely in a query string). In that case, use a surrounding pair such as "<>" or quotes to enclose each URL in such a list. (15-Nov-2002 12:41) --- 1) About "reserved" characters in URLS: Beware that RFC 1738 specifies that the characters "{", "}", "|", "\", "^", "~", "[", "]", and "`" are all considered unsafe and SHOULD be URL-encoded with a "%xx" triplet within *ALL* URLs. However, some HTTP URLs seem to use the "~" character as a prefix for a user account for example: http://www.any.host.domain/~user/subpath/page.html?query#fragment This usage is acceptable, but the RFC specifies that "%7E" should be used instead of "~" in the path component. HTTP servers should accept "~" as being equivalent to "%7E", and according to the RFC, the "%7E" form should be the canonical one. However, some HTTP servers are not fully complying to this RFC and consider "%7E" differently from "~" (i.e. they consider it as being part of a path component name, and search a directory name containing a "~" character, instead of mapping the "~user" path component to a user's directory. In that case, these non compliant HTTP server will not find the resource associated to that URL and may return a 404 error or other errors such as an access denied. When using rawurlencode() on such HTTP URLs, it's best to consider this legacy usage, by using str_replace() on the result to convert back "/%7E" to "/~", so that the URLs will correctly map to the legacy use of the "~" character by these servers. On compliant HTTP servers, they will treat the "~" unsafe character equivalently with the "%7E" recommanded form, so they will automatically canonicalize the "~" character into "%7E". --- 2) Encoding of hostnames in URLs Finally, beware that host domain names parts in URLs *MUST NOT* be encoded with rawurlencode(), as the "[" and "]" are valid delimiters that *MUST* be used to reference an IPv6 address or other hostnames that don't fit to the restricted set of characters allowed in a host name (the "[" and "]" characters MUST be used if the hostname includes characters such as ":" which is typically used to specify an alternate non-default port number). The encoding of host names uses another encoding, required to encode international domain names, with a base-64 encoding of Unicode characters and a "bq--" prefix. This encoding must be used only on individual subdomain parts (separated by "." characters). This encoding does not use any "%xx" triplets. So NEVER use urlencode() or rawurlencode() on an unparsed URL, unless this full URL is part of a query parameter string! --- 3) Encoding of username/passwords in URLs: There is no standard to specify a password in a URL. In fact, there's a legacy usage of the ":" character to separate a username from a password, but it is strongly discouraged. The RFC does not attempt to specify a semantic to the authentication part of an URL (before the "@" character and the hostname part). If you need to encode a password, always use rawurlencode() on username and passwords separately, and then insert the ":" character to separate both components. Don't use urlencode() (which could use a "+" to encode a space, and would not work because usernames and passwords consider "+" and spaces as being different!) (13-Sep-2002 11:06) rawurlencode() MUST not be used on unparsed URLs. rawurlencode() should not be used on host and domain name parts (that may include international characters encoded in each domain part with a "q--" prefix followed by a special encoding of the international domain, currently in testbed). rawurlencode() may be used on usernames and passwords separately (so that it won't encode the ':' and '@' separators). rawurlencode() must not be used on paths (that may contain '/' separators): the ['path'] element of a parsed URL must first be exploded into individual "directory" names. A directory or filename that contains a space must not be encoded with urlencode() but with this rawurlencode(), so that it will appear as a '%20' hex sequence (not '+') rawurlencode() must not be used to encode the ['query'] element of a parsed URL. Instead you must use the urlencode() function: Typical queries often use the '&' separator between each parameter. This '&' separator however is just a convention, used in the www-url-encoded format for HTML forms using the default GET method. However, when references are done in a HTML page to an URL that contains static query parameters, these '&' separators should be encoded in the HTML code as '&' for HTML conformance. This is not part of the URL specification, but of the HTML encapsulation! Some browsers forget this, and send '&' with their HTTP GET query. You may wish to substitute '&' by '&' when parsing and validating URLs. This should be done BEFORE calling urlencode() on query parts. The ['fragment'] part of a parsed URL (after the first '#' separator found in any URL) must not be encoded with this rawurlencode() function but instead by urlencode(). Validating a URL sent in a HTTP request is then more complicated than what you may think. This must be done only on parsed URLs (where the basic elements of an URL have been splitted), and then you must explode the path components, and check the presence of '&' sequences in the query or fragment parts. The next thing to do is to check the URL scheme that you want to support (for example, only 'http', 'https', or 'ftp'). You may wich to check the ['port'] part to see if it's really a decimal integer between 1 and 65535. You may wish to remove the default port number used by the URL schemes you want to support (for example the port '80' for 'http', the port '21' for 'ftp', the port '443' for 'https'), and restrict severely all port numbers below 1024, or some critical ports below 140 (this includes DNS and NetBios ports). Then you may wish to control severely the ['host'] part (in fact a full host domain name or an IP address), by forbidding those host names that don't contain at least one dot, forbidding those that start with a dot, those that contain two consecutive dots, those that start or finish with a '-' dash, those that contain '.-' or '-.' (invalid in all domain names), those that contain two dashes in another position than the second and third character of a domain name part and not folled by at least one other character, forbid top level domain names that have only one non numeric character, or more than 6 characters (".museum" is, for now, the longest acceptable TLD), check that pseudo-TLD names that are pure integers are effectively between 0 and 255, in that case check that this is a valid IPv4 address by comparing it to long2ip(ip2long($host)), ... This done, you must use the urlencode() function on all parts up to the exploded path elements, and rawurlencode() on the query and fragment parts, according to the specs, to recreate a complete and validated URL. dphantom at ticino dot com (03-Feb-2002 08:48) PHP's functions rawurlencode() and urlencode(), both encode the whole argument parameter string, making the result useless as a valid link. The function listed here encodes a link string (e.g. http://www.domain.com/long_path/to\file.php?query=param#fragm) to a valid <a href=""> parameter string, preserving the original URI structure and the path given. function linkencode ($p_url) { $ta = parse_url($p_url); if (!empty($ta[scheme])) { $ta[scheme].='://'; } if (!empty($ta[pass]) and !empty($ta[user])) { $ta[user].=':'; $ta[pass]=rawurlencode($ta[pass]).'@'; } elseif (!empty($ta[user])) { $ta[user].='@'; } if (!empty($ta[port]) and !empty($ta[host])) { $ta[host]=''.$ta[host].':'; } elseif (!empty($ta[host])) { $ta[host]=$ta[host]; } if (!empty($ta[path])) { $tu=''; $tok=strtok($ta[path], "\\/"); while (strlen($tok)) { $tu.=rawurlencode($tok).'/'; $tok=strtok("\\/"); } $ta[path]='/'.trim($tu, '/'); } if (!empty($ta[query])) { $ta[query]='?'.$ta[query]; } if (!empty($ta[fragment])) { $ta[fragment]='#'.$ta[fragment]; } return implode('', array($ta[scheme], $ta[user], $ta[pass], $ta[host], $ta[port], $ta[path], $ta[query], $ta[fragment])); } << rawurldecode Main : Function Reference : URL Functions : rawurlencode urldecode >> This page online Report a bug /MySQLdb/ ... |
| 25.02.2004, 17:05 |
start [/forum/topic.php?desktop=1&fid=23&tid=1480040]: |
196ms |
37ms |
| others: | 244ms |
| total: | 520ms |
