Лог файл апатч.
МИР ВАМ И ВАШЕМУ ДОМУ! PHP Warning: PHP Startup: mcrypt: Unable to initialize module\nModule compiled with build ID=API20090626,TS,VC6\nPHP compiled with build ID=API20090626,TS,VC9\nThese options need to match\n in Unknown on line 0 PHP Warning: PHP Startup: zip: Unable to initialize module\nModule compiled with module API=20060613\nPHP compiled with module API=20090626\nThese options need to match\n in Unknown on line 0 [Wed Apr 03 14:09:09 2013] [notice] Apache/2.2.17 (Win32) PHP/5.3.10 configured -- resuming normal operations [Wed Apr 03 14:09:09 2013] [notice] Server built: Oct 18 2010 01:58:12 [Wed Apr 03 14:09:09 2013] [notice] Parent: Created child process 3676 PHP Warning: PHP Startup: mcrypt: Unable to initialize module\nModule compiled with build ID=API20090626,TS,VC6\nPHP compiled with build ID=API20090626,TS,VC9\nThese options need to match\n in Unknown on line 0 PHP Warning: PHP Startup: zip: Unable to initialize module\nModule compiled with module API=20060613\nPHP compiled with module API=20090626\nThese options need to match\n in Unknown on line 0 [Wed Apr 03 14:09:10 2013] [notice] Child 3676: Child process is running [Wed Apr 03 14:09:10 2013] [notice] Child 3676: Acquired the start mutex. [Wed Apr 03 14:09:10 2013] [notice] Child 3676: Starting 150 worker threads. [Wed Apr 03 14:09:10 2013] [notice] Child 3676: Starting thread to listen on port 80. Не пойму я этот Warning, что это за предупреждение? ... |
| 03.04.2013, 14:15 |
Лог файл апатч.
АсланалиPHP Warning: PHP Startup: mcrypt : Unable to initialize module\nModule compiled with build ID=API20090626,TS,VC6\nPHP compiled with build ID=API20090626,TS,VC9\nThese options need to match\n in Unknown on line 0 PHP Warning: PHP Startup: zip : Unable to initialize module\nModule compiled with module API=20060613\nPHP compiled with module API=20090626\nThese options need to match\n in Unknown on line 0 Проблемы с этими 2-мя модулями. Попробуйте их отключить в конфиге. А так как у вас апач под виндой, быстрей всего поражена вирусом. имхо. ... |
| 03.04.2013, 18:34 |
Лог файл апатч.
АсланалиModule compiled with module API=20060613\nPHP compiled with module API=20090626Файлы модулей неродные подсунули, похоже. ... |
| 03.04.2013, 20:50 |
Лог файл апатч.
С0ВЕСТЬбыстрей всего поражена вирусомБывает что самый страшный вирус - это пользователь :-) ... |
| 03.04.2013, 20:52 |
Лог файл апатч.
vkleС0ВЕСТЬбыстрей всего поражена вирусомБывает что самый страшный вирус - это пользователь :-) а может и хакнули... ... |
| 03.04.2013, 21:09 |
start [/forum/topic.php?desktop=1&fid=23&tid=1463941]: |
68ms |
43ms |
| others: | 238ms |
| total: | 391ms |
