(Python)TypeError: incompatible types при исполнении скрипт по FDB
Вероятно, сталкивались с ошибкой “TypeError: incompatible types, LP_c_short instance instead of LP_c_short instance”. Подскажите, пожалуйста, как от нее можно избавиться? Лог Apache: mod_wsgi (pid=4789): Exception occurred processing WSGI script ‘/home/nasmork/PycharmProjects/accounting/myapp.py’., referer: http://www.example.com/purchadding.py Traceback (most recent call last):, referer: http://www.example.com/purchadding.py File “/home/nasmork/PycharmProjects/accounting/myapp.py”, line 17, in application, referer: http://www.example.com/purchadding.py cur.execute(select_purchase), referer: http://www.example.com/purchadding.py File “/usr/local/lib/python2.7/dist-packages/fdb/fbcore.py”, line 3322, in execute, referer: http://www.example.com/purchadding.py PreparedStatement(operation, self, True)), referer: http://www.example.com/purchadding.py File “/usr/local/lib/python2.7/dist-packages/fdb/fbcore.py”, line 1989, in __init__, referer: http://www.example.com/purchadding.py self.__coerce_XSQLDA(self._out_sqlda), referer: http://www.example.com/purchadding.py File “/usr/local/lib/python2.7/dist-packages/fdb/fbcore.py”, line 2284, in __coerce_XSQLDA, referer: http://www.example.com/purchadding.py sqlvar.sqlind = ctypes.pointer(ISC_SHORT(0)), referer: http://www.example.com/purchadding.py TypeError: incompatible types, LP_c_short instance instead of LP_c_short instance, referer: http://www.example.com/purchadding.py ... |
| 16.03.2014, 18:26 |
start [/forum/topic.php?desktop=1&fid=23&tid=1462957]: |
166ms |
26ms |
| others: | 197ms |
| total: | 423ms |
