Как установить php-memcached на cent os для php55w
Как установить php-memcached на cent os для php55w ? вот что выдает yum install php-memcached авторLoaded plugins: fastestmirror, replace, security Setting up Install Process Loading mirror speeds from cached hostfile * base: mirror.awanti.com * epel: ftp.uni-koeln.de * extras: mirror.awanti.com * updates: mirror.satellite-service.ru * webtatic: us-east.repo.webtatic.com Resolving Dependencies --> Running transaction check ---> Package php55w-pecl-memcached.i386 0:2.2.0-2.w6 will be installed --> Processing Dependency: php-pecl-igbinary(x86-32) for package: php55w-pecl-memcached-2.2.0-2.w6.i386 --> Processing Dependency: libmemcachedutil.so.2 for package: php55w-pecl-memcached-2.2.0-2.w6.i386 --> Processing Dependency: libmemcached.so.11 for package: php55w-pecl-memcached-2.2.0-2.w6.i386 --> Running transaction check ---> Package libmemcached10.i686 0:1.0.16-1.ius.el6 will be installed ---> Package php-pecl-igbinary.i686 0:1.2.1-1.el6 will be installed --> Processing Dependency: php(zend-abi) = 20090626 for package: php-pecl-igbinary-1.2.1-1.el6.i686 --> Processing Dependency: php(api) = 20090626 for package: php-pecl-igbinary-1.2.1-1.el6.i686 --> Running transaction check ---> Package php-common.i686 0:5.3.3-40.el6_6 will be installed --> Processing Conflict: php55w-common-5.5.18-1.w6.i386 conflicts php-common < 5.5.0 --> Finished Dependency Resolution Error: php55w-common conflicts with php-common-5.3.3-40.el6_6.i686 You could try using --skip-broken to work around the problem You could try running: rpm -Va --nofiles --nodigest а если ставить из сорсов то /configure работает нормально а make выдает ошибку автор[root@localhost memcached-2.2.0]# sudo make /bin/sh /home/telekomconsalting/memcached-2.2.0/libtool --mode=compile cc -I/usr/include/php -I. -I/home/telekomconsalting/memcached-2.2.0 -DPHP_ATOM_INC -I/home/telekomconsalting/memcached-2.2.0/include -I/home/telekomconsalting/memcached-2.2.0/main -I/home/telekomconsalting/memcached-2.2.0 -I/usr/include/php -I/usr/include/php/main -I/usr/include/php/TSRM -I/usr/include/php/Zend -I/usr/include/php/ext -I/usr/include/php/ext/date/lib -DHAVE_CONFIG_H -g -O2 -c /home/telekomconsalting/memcached-2.2.0/php_memcached.c -o php_memcached.lo libtool: compile: cc -I/usr/include/php -I. -I/home/telekomconsalting/memcached-2.2.0 -DPHP_ATOM_INC -I/home/telekomconsalting/memcached-2.2.0/include -I/home/telekomconsalting/memcached-2.2.0/main -I/home/telekomconsalting/memcached-2.2.0 -I/usr/include/php -I/usr/include/php/main -I/usr/include/php/TSRM -I/usr/include/php/Zend -I/usr/include/php/ext -I/usr/include/php/ext/date/lib -DHAVE_CONFIG_H -g -O2 -c /home/telekomconsalting/memcached-2.2.0/php_memcached.c -fPIC -DPIC -o .libs/php_memcached.o In file included from /home/telekomconsalting/memcached-2.2.0/php_memcached_private.h:28, from /home/telekomconsalting/memcached-2.2.0/php_memcached.c:26: /home/telekomconsalting/memcached-2.2.0/php_libmemcached_compat.h:56: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘php_memcached_instance_st’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c:328: error: expected declaration specifiers or ‘...’ before ‘php_memcached_instance_st’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c:329: error: expected declaration specifiers or ‘...’ before ‘php_memcached_instance_st’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c:330: error: expected declaration specifiers or ‘...’ before ‘php_memcached_instance_st’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘php_memc_get_impl’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:594: warning: passing argument 4 of ‘memcached_mget_by_key’ from incompatible pointer type /usr/include/libmemcached/memcached_get.h:38: note: expected ‘char **’ but argument is of type ‘const char **’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘php_memc_getMulti_impl’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:774: warning: passing argument 4 of ‘memcached_mget_by_key’ from incompatible pointer type /usr/include/libmemcached/memcached_get.h:38: note: expected ‘char **’ but argument is of type ‘const char **’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘php_memc_getDelayed_impl’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:976: warning: passing argument 4 of ‘memcached_mget_by_key’ from incompatible pointer type /usr/include/libmemcached/memcached_get.h:38: note: expected ‘char **’ but argument is of type ‘const char **’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘zim_Memcached_fetch’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:1067: warning: passing argument 4 of ‘add_assoc_stringl_ex’ discards qualifiers from pointer target type /usr/include/php/Zend/zend_API.h:382: note: expected ‘char *’ but argument is of type ‘const char *’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘zim_Memcached_fetchAll’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:1126: warning: passing argument 4 of ‘add_assoc_stringl_ex’ discards qualifiers from pointer target type /usr/include/php/Zend/zend_API.h:382: note: expected ‘char *’ but argument is of type ‘const char *’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘php_memc_setMulti_impl’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:1307: error: ‘MEMCACHED_SERVER_TEMPORARILY_DISABLED’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:1307: error: (Each undeclared identifier is reported only once /home/telekomconsalting/memcached-2.2.0/php_memcached.c:1307: error: for each function it appears in.) /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘php_memc_store_impl’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:1554: error: ‘MEMCACHED_SERVER_TEMPORARILY_DISABLED’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘php_memc_incdec_impl’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:1863: error: ‘MEMCACHED_SERVER_TEMPORARILY_DISABLED’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘zim_Memcached_getServerList’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2040: warning: assignment from incompatible pointer type /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘zim_Memcached_getServerByKey’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2053: error: ‘php_memcached_instance_st’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2053: error: expected ‘;’ before ‘server_instance’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2069: error: ‘server_instance’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2076:90: error: macro "memcached_server_name" requires 2 arguments, but only 1 given /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2076: error: ‘memcached_server_name’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2077:77: error: macro "memcached_server_port" requires 2 arguments, but only 1 given /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2077: error: ‘memcached_server_port’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘zim_Memcached_getLastDisconnectedServer’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2186: error: ‘php_memcached_instance_st’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2186: error: expected ‘;’ before ‘server_instance’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2195: error: ‘server_instance’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2201:90: error: macro "memcached_server_name" requires 2 arguments, but only 1 given /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2201: error: ‘memcached_server_name’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2202:77: error: macro "memcached_server_port" requires 2 arguments, but only 1 given /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2202: error: ‘memcached_server_port’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘zim_Memcached_getStats’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2238: warning: assignment from incompatible pointer type /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘zim_Memcached_getVersion’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2271: warning: assignment from incompatible pointer type /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘zim_Memcached_getAllKeys’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2295: warning: assignment from incompatible pointer type /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘php_memc_set_option’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2415: error: ‘MEMCACHED_INVALID_ARGUMENTS’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2527: error: ‘MEMCACHED_BEHAVIOR_MAX’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c: At top level: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2943: error: expected declaration specifiers or ‘...’ before ‘php_memcached_instance_st’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2950:76: error: macro "memcached_server_name" requires 2 arguments, but only 1 given /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘php_memc_do_serverlist_callback’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2950: error: ‘memcached_server_name’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2951:63: error: macro "memcached_server_port" requires 2 arguments, but only 1 given /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2951: error: ‘memcached_server_port’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c: At top level: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2961: error: expected declaration specifiers or ‘...’ before ‘php_memcached_instance_st’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2967:79: error: macro "memcached_server_name" requires 2 arguments, but only 1 given /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘php_memc_do_stats_callback’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2967: error: ‘memcached_server_name’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2967:112: error: macro "memcached_server_port" requires 2 arguments, but only 1 given /home/telekomconsalting/memcached-2.2.0/php_memcached.c:2967: error: ‘memcached_server_port’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c: At top level: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:3005: error: expected declaration specifiers or ‘...’ before ‘php_memcached_instance_st’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c:3012:79: error: macro "memcached_server_name" requires 2 arguments, but only 1 given /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘php_memc_do_version_callback’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:3012: error: ‘memcached_server_name’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:3012:112: error: macro "memcached_server_port" requires 2 arguments, but only 1 given /home/telekomconsalting/memcached-2.2.0/php_memcached.c:3012: error: ‘memcached_server_port’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:3020: error: ‘instance’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘s_compress_value’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:3105: warning: passing argument 2 of ‘compress’ from incompatible pointer type /usr/include/zlib.h:1009: note: expected ‘uLongf *’ but argument is of type ‘size_t *’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘php_memc_do_result_callback’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:3675: warning: passing argument 4 of ‘add_assoc_stringl_ex’ discards qualifiers from pointer target type /usr/include/php/Zend/zend_API.h:382: note: expected ‘char *’ but argument is of type ‘const char *’ /home/telekomconsalting/memcached-2.2.0/php_memcached.c: In function ‘php_memc_register_constants’: /home/telekomconsalting/memcached-2.2.0/php_memcached.c:4252: error: ‘LIBMEMCACHED_VERSION_HEX’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:4321: error: ‘MEMCACHED_BEHAVIOR_TCP_KEEPALIVE’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:4391: error: ‘MEMCACHED_E2BIG’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:4392: error: ‘MEMCACHED_KEY_TOO_BIG’ undeclared (first use in this function) /home/telekomconsalting/memcached-2.2.0/php_memcached.c:4393: error: ‘MEMCACHED_SERVER_TEMPORARILY_DISABLED’ undeclared (first use in this function) make: *** [php_memcached.lo] Error 1 ... |
| 14.11.2014, 20:26 |
Error: php55w -common conflicts with php-common-5.3.3 -40.el6_6.i686 ... |
| 15.11.2014, 02:03 |
ну это я вижу как установить то ? ... |
| 15.11.2014, 02:24 |
start [/forum/topic.php?desktop=1&fid=23&tid=1462255]: |
176ms |
46ms |
| others: | 246ms |
| total: | 514ms |
