Форумы / PHP, Perl, Python [игнор отключен] [закрыт для гостей] / Direct link to mp4 from mail.ru
18 сообщений из 18, страница 1 из 1
    #38930562
xSlavikx
Hello,
First of all, excuse me, i only speak a little english.
I'm trying to get the direct link of videos of mail.ru directly in a script.
I am able to get the link of the mp4 ( http://cdnxx.mail.ru) from the json (ex : http://videoapi.mail.ru/videos/..../_myvideo//100.json).
But the link i get does'nt work, it gives me a blank white screen.
Is it possible to make a script that give me a good link to the mp4 ?
I hope you understand me :)
Thank you.
    #38930574
xSlavikx
http://videoapi.my.mail.ru/videos/mail/userxyz/_myvideo/videoxyz.json --> ex of json link
when i put this link direct in my browser, the links are available.
when i get the json by a remote server with script, links are not available.
Maybe that's more clear. Maybe the post is in the bad section, sorry...
    #38930593
SharuPoNemnogu
link shows this {"error":"Can't find VideoInstance mail/userxyz/_myvideo/videoxyz"} it's ok?
show your script
    #38930633
xSlavikx
userxyz and videoxyz are exemple to replace with good values like :
here is a good exemple --> http://videoapi.mail.ru/videos/bk/dinskc/_myvideo/1117.json
i can't copy the little script here, i don't have access to my server from my job... i will copy it tonight.
The script is execute from my server. i have for ex : mysite.com/link.php?file=1117
so i'll retreive the json, parse it and extract link but don't work since one server.
I must put manually the json link in browser and copy link in the json. Autamatically that's not working.
    #38930801
SharuPoNemnogu
http://cdn45.my.mail.ru/v/53452064.mp4 returns forbidden 403. likely access to files directly closed
    #38930822
xSlavikx
No, we can access via http://videoapi.my.mail.ru/videos/bk/dinskc/_myvideo/1117.json
to have 360p : http://cdn24.my.mail.ru/v/53452064.mp4?sign=31e26e6092b27fe6834505498ed9245802e9d37e&slave []=s%3Ahttp%3A%2F%2F127.0.0.1%3A5010%2F53452064-v.mp4&p=f&expire_at=1428613200&touch=1426513631
and 480p : http://cdn24.my.mail.ru/hv/53452064.mp4?sign=3e21ce44899a82655ea7a36386e3445b2e203774&slave []=s%3Ahttp%3A%2F%2F127.0.0.1%3A5010%2F53452064-hv.mp4&p=f&expire_at=1428613200&touch=1426513631
    #38930844
SharuPoNemnogu
360 & 480 links returned forbidden
    #38930876
xSlavikx
yes of course, you must copy link to json before in your browser and copy entire link in json to have access file.
you also can have the direct link using this site but in 2 time : http://zasasa.com/ru/skachat_video_s_mail.ru.php
i see on one site that it is possible to generate an available link automatically but how ? that's the question :)
    #38931135
xSlavikx
the little script to get url... but whitescreen...
<?php
$file = $_GET['file'];
$json = file_get_contents('http://videoapi.my.mail.ru/videos/bk/dinskc/_myvideo/' .$file .'.json');
$json_a = json_decode($json,true);
$url = $json_a[videos][0];
$img = $json_a[meta][poster];
    #38931215
SharuPoNemnogu
i try uri http://my.mail.ru/mail/spasenieviisuse/video/_myvideo/309.html
when use file_get_contents or curl (with emulate browser) returned link http://cdn51.my.mail.ru/hv/34240857.mp4?sign=20cec26ff4d916ea62ba5e31953ef31e9c896a69&slave []=s%3Ahttp%3A%2F%2F127.0.0.1%3A5010%2F34240857-hv.mp4&p=f&expire_at=1428613200
in browser returned link http://cdn51.my.mail.ru/hv/34240857.mp4?sign=ead04bdc094d699a1e000d3d9c3e43ac8027628b&slave []=s%3Ahttp%3A%2F%2F127.0.0.1%3A5010%2F34240857-hv.mp4&p=f&expire_at=1428613200
different parameter sign . If change sign parameter in link one to sign from link two it's work fine.
I don't know why it happens... information for consideration.
I hope to help you.
    #38931254
Фотография NekZ
xSlavikx,
At first, I think, you should play with HTTP headers and emulate a proper HTTP request, similar to your browser one. Perhaps they might introduce some kind of security to detect and reject such requests.
Then you'd better to try running a background browser, or the same mechanism, such as Selenium, I dunno...
    #38931260
Фотография NekZ
SharuPoNemnogu http://my.mail.ru/mail/spasenieviisuse/
D'oh... Is that you on those videos?
    #38931407
SharuPoNemnogu
NekZ,
да взял первое попавшееся для теста)
    #38931500
xSlavikx
@SharuPoNemnogu
Thank you. Yes, i noticed parameter is different, that's why i wrote this topic here, to find a way :p
@NekZ
Thank you for the answer, probably the best way but too difficult for me too.
But i'll check this way.
I also see on another topic here link like this to open file : http://videoapi.my.mail.ru/file/v//mail/ua0app/_myvideo/7?c=mr_api_video&expire_at=1417904149&sign=79bbdc605945a43ed7f0fa3cbcb32ae1f70755cd ( http://www.sql.ru/forum/1130981/kak-eto-snyali)
but don't know what are the parameters for... if someone knows...
Thank you.
    #38933221
xSlavikx
up, nobody for an idea ? :)
    #38933255
SharuPoNemnogu
xSlavikx,
read about selenium, maybe it's help you
    #38933271
Фотография NekZ
SharuPoNemnoguxSlavikx,
read about selenium , maybe it's help you
That was a raw idea, besides I'm not a web developer to advise Selenium using for xSlavikx's purposes.
xSlavikx,
Why don't you consider CURL library for that? E.g. http://stackoverflow.com/a/2440753/2080453
If I were you, I would look for the services which are designed to emulate real web browsers as well.
    #38933289
SharuPoNemnogu
I tried curl, but it did not work. Try again, maybe you will..
