perl как получить конкретную запись из базы данных mysql
Доброго времени суток! Есть база данных следующей структуры: MariaDB [pdns]> SELECT * FROM domains; +-----+--------------------+--------+------------+--------+-----------------+---------+ | id | name | master | last_check | type | notified_serial | account | +-----+--------------------+--------+------------+--------+-----------------+---------+ | 106 | mnc001.mcc400.gprs | | NULL | MASTER | 2006022801 | NULL | | 107 | localhost | | NULL | MASTER | 2005020801 | NULL | +-----+--------------------+--------+------------+--------+-----------------+---------+ 2 rows in set (0.00 sec) MariaDB [pdns]> SELECT * FROM records; +------+-----------+----------------------+-------+------------------------------------------------------------------------------------------+------+------+-------------+----------+-----------+------+ | id | domain_id | name | type | content | ttl | prio | change_date | disabled | ordername | auth | +------+-----------+----------------------+-------+------------------------------------------------------------------------------------------+------+------+-------------+----------+-----------+------+ | 1906 | 106 | mnc001.mcc400.gprs | SOA | idns1.mnc001.mcc400.gprs. admin.mnc001.mcc400.gprs. 2006022801 43200 1800 3456000 432000 | 3600 | 0 | NULL | 0 | NULL | 1 | | 1907 | 106 | mnc001.mcc400.gprs | NS | idns1.mnc001.mcc400.gprs | 3600 | 0 | NULL | 0 | NULL | 1 | | 1908 | 106 | *.mnc001.mcc400.gprs | A | 192.168.123.123 | 3600 | 0 | NULL | 0 | NULL | 1 | | 1909 | 106 | mnc001.mcc400.gprs | NS | idns2.mnc001.mcc400.gprs | 3600 | 0 | NULL | 0 | NULL | 1 | | 1910 | 107 | localhost | SOA | idns1.mnc001.mcc400.gprs. admin.mnc001.mcc400.gprs. 2005020801 86400 7200 3600000 172800 | 3600 | 0 | NULL | 0 | NULL | 1 | | 1911 | 107 | localhost | NS | idns1.mnc001.mcc400.gprs | 3600 | 0 | NULL | 0 | NULL | 1 | | 1912 | 107 | localhost | A | 127.0.0.1 | 3600 | 0 | NULL | 0 | NULL | 1 | | 1913 | 107 | localhost.localhost | CNAME | localhost | 3600 | 0 | NULL | 0 | NULL | 1 | | 1914 | 107 | localhost | NS | idns2.mnc001.mcc400.gprs | 3600 | 0 | NULL | 0 | NULL | 1 | +------+-----------+----------------------+-------+------------------------------------------------------------------------------------------+------+------+-------------+----------+-----------+------+ 9 rows in set (0.00 sec) пытаюсь получить запись из таблицы records с типом CNAME через скрипт perl : use JSON; use LWP::UserAgent; use Data::Dumper; my $ua = LWP::UserAgent->new; my $req = HTTP::Request->new( GET => " http://127.0.0.1:8081/servers/localhost/zones/localhost", ['X-API-Key' => 'aaa123'] ); $req->content('["type":"CNAME"]'); print Dumper($req). "\n"; my $res = $ua->request($req); my $content = $res->content; print "$content\n\n"; print "\n------------------------------\n"; print Dumper($res). "\n\n"; print "\n=----------------------------=\n"; print $req->as_string(),"\n"; print "\n=----------------------------=\n"; print $res->as_string(),"\n"; но в результате получаю данные о всей зоне DNS: $VAR1 = bless( { '_content' => '["type":"CNAME"]', '_uri' => bless( do{\(my $o = 'http://127.0.0.1:8081/servers/localhost/zones/localhost')}, 'URI::http' ), '_headers' => bless( { 'x-api-key' => 'aaa123', '::std_case' => { 'x-api-key' => 'X-API-Key' } }, 'HTTP::Headers' ), '_method' => 'GET' }, 'HTTP::Request' ); {"id":"localhost.","url":"/servers/localhost/zones/localhost.","name":"localhost","kind":"Master","dnssec":false,"account":"","masters":[],"serial":2005020801,"notified_serial":2005020801,"last_check":0,"soa_edit_api":"","soa_edit":"","records":[{"name":"localhost","type":"A","ttl":3600,"disabled":false,"content":"127.0.0.1"},{"name":"localhost","type":"NS","ttl":3600,"disabled":false,"content":"idns1.mnc001.mcc400.gprs"},{"name":"localhost","type":"NS","ttl":3600,"disabled":false,"content":"idns2.mnc001.mcc400.gprs"},{"name":"localhost","type":"SOA","ttl":3600,"disabled":false,"content":"idns1.mnc001.mcc400.gprs. admin.mnc001.mcc400.gprs. 2005020801 86400 7200 3600000 172800"},{"name":"localhost.localhost","type":"CNAME","ttl":3600,"disabled":false,"content":"localhost"}],"comments":[]} ------------------------------ $VAR1 = bless( { '_protocol' => 'HTTP/1.1', '_content' => '{"id":"localhost.","url":"/servers/localhost/zones/localhost.","name":"localhost","kind":"Master","dnssec":false,"account":"","masters":[],"serial":2005020801,"notified_serial":2005020801,"last_check":0,"soa_edit_api":"","soa_edit":"","records":[{"name":"localhost","type":"A","ttl":3600,"disabled":false,"content":"127.0.0.1"},{"name":"localhost","type":"NS","ttl":3600,"disabled":false,"content":"idns1.mnc001.mcc400.gprs"},{"name":"localhost","type":"NS","ttl":3600,"disabled":false,"content":"idns2.mnc001.mcc400.gprs"},{"name":"localhost","type":"SOA","ttl":3600,"disabled":false,"content":"idns1.mnc001.mcc400.gprs. admin.mnc001.mcc400.gprs. 2005020801 86400 7200 3600000 172800"},{"name":"localhost.localhost","type":"CNAME","ttl":3600,"disabled":false,"content":"localhost"}],"comments":[]}', '_rc' => '200', '_headers' => bless( { 'connection' => 'close', 'client-response-num' => 1, 'access-control-allow-origin' => '*', 'client-peer' => '127.0.0.1:8081', 'content-length' => '798', '::std_case' => { 'client-date' => 'Client-Date', 'client-response-num' => 'Client-Response-Num', 'access-control-allow-origin' => 'Access-Control-Allow-Origin', 'client-transfer-encoding' => 'Client-Transfer-Encoding', 'client-peer' => 'Client-Peer' }, 'client-date' => 'Tue, 01 Sep 2015 13:49:10 GMT', 'content-type' => 'application/json', 'client-transfer-encoding' => [ 'chunked' ], 'server' => 'PowerDNS/3.4.5' }, 'HTTP::Headers' ), '_msg' => 'OK', '_request' => bless( { '_content' => '["type":"CNAME"]', '_uri' => bless( do{\(my $o = 'http://127.0.0.1:8081/servers/localhost/zones/localhost')}, 'URI::http' ), '_headers' => bless( { 'user-agent' => 'libwww-perl/6.05', 'x-api-key' => 'aaa123', '::std_case' => { 'x-api-key' => 'X-API-Key' } }, 'HTTP::Headers' ), '_method' => 'GET', '_uri_canonical' => $VAR1->{'_request'}{'_uri'} }, 'HTTP::Request' ) }, 'HTTP::Response' ); =----------------------------= GET http://127.0.0.1:8081/servers/localhost/zones/localhost User-Agent: libwww-perl/6.05 X-API-Key: aaa123 ["type":"CNAME"] =----------------------------= HTTP/1.1 200 OK Connection: close Server: PowerDNS/3.4.5 Content-Length: 798 Content-Type: application/json Access-Control-Allow-Origin: * Client-Date: Tue, 01 Sep 2015 13:49:10 GMT Client-Peer: 127.0.0.1:8081 Client-Response-Num: 1 Client-Transfer-Encoding: chunked {"id":"localhost.","url":"/servers/localhost/zones/localhost.","name":"localhost","kind":"Master","dnssec":false,"account":"","masters":[],"serial":2005020801,"notified_serial":2005020801,"last_check":0,"soa_edit_api":"","soa_edit":"","records":[{"name":"localhost","type":"A","ttl":3600,"disabled":false,"content":"127.0.0.1"},{"name":"localhost","type":"NS","ttl":3600,"disabled":false,"content":"idns1.mnc001.mcc400.gprs"},{"name":"localhost","type":"NS","ttl":3600,"disabled":false,"content":"idns2.mnc001.mcc400.gprs"},{"name":"localhost","type":"SOA","ttl":3600,"disabled":false,"content":"idns1.mnc001.mcc400.gprs. admin.mnc001.mcc400.gprs. 2005020801 86400 7200 3600000 172800"},{"name":"localhost.localhost","type":"CNAME","ttl":3600,"disabled":false,"content":"localhost"}],"comments":[]} Уважаемые знатоки! как правильно поменять контент в запросе, чтобы получить только строчки с CNAME? ... |
| 02.09.2015, 08:13 |
Если есть база, из которой надо получить данные то почему нельзя выполнить запрос непосредственно к этой базе? ... |
| 02.09.2015, 08:19 |
start [/forum/topic.php?desktop=1&fid=23&tid=1461556]: |
178ms |
30ms |
| others: | 217ms |
| total: | 465ms |
