Проблема настройки MSSQL+PHP
Помогите пожалуйста советом Не могу соединится с MSSQL установлены Win 7/32 xampp-win32-5.6.8-0-VC11 Microsoft SQL Server 2008 скачал отсюда http://www.microsoft.com/en-us/download/details.aspx?id=20098 драйвер закинул файл php_sqlsrv_56_ts.dll в D:\xampp\php\ext Прописал в php.ini extension=php_sqlsrv_56_ts.dll Передернул сервер .... но увы глухо((( Что я делаю не так?! ... |
| 28.05.2015, 11:11 |
в IIS все настраивается парой щелчков мыши. ... |
| 28.05.2015, 14:37 |
error_log смотри ... |
| 28.05.2015, 15:58 |
логи смотрел, честно говоря ничего не понял: [Fri May 29 07:37:28.039007 2015] [ssl:warn] [pid 7188:tid 224] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name [Fri May 29 07:37:28.126990 2015] [core:warn] [pid 7188:tid 224] AH00098: pid file D:/xampp/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run? [Fri May 29 07:37:28.360943 2015] [ssl:warn] [pid 7188:tid 224] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name [Fri May 29 07:37:29.885638 2015] [mpm_winnt:notice] [pid 7188:tid 224] AH00455: Apache/2.4.12 (Win32) OpenSSL/1.0.1l PHP/5.6.8 configured -- resuming normal operations [Fri May 29 07:37:29.885638 2015] [mpm_winnt:notice] [pid 7188:tid 224] AH00456: Apache Lounge VC11 Server built: Jan 28 2015 16:48:40 [Fri May 29 07:37:29.885638 2015] [core:notice] [pid 7188:tid 224] AH00094: Command line: 'd:\\xampp\\apache\\bin\\httpd.exe -d D:/xampp/apache' [Fri May 29 07:37:29.900635 2015] [mpm_winnt:notice] [pid 7188:tid 224] AH00418: Parent: Created child process 4044 [Fri May 29 07:37:30.723470 2015] [ssl:warn] [pid 4044:tid 236] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name [Fri May 29 07:37:31.021411 2015] [ssl:warn] [pid 4044:tid 236] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name [Fri May 29 07:37:31.112393 2015] [mpm_winnt:notice] [pid 4044:tid 236] AH00354: Child: Starting 150 worker threads. ... |
| 29.05.2015, 07:38 |
киньте пожалуйста ссылку на мануал по настройке iis ... |
| 29.05.2015, 08:30 |
mika1киньте пожалуйста ссылку на мануал по настройке iis Да там не мануал, там сам увидишь. В IIS открываешь "Установщик WEB-платформы", там устанавливаешь сам php и "администратор PHP для IIS". И потом уже работаешь в этом администраторе, там внизу будет "включить или выключить расширение" и "добавить расширение". Я просто включил модули для sql server и все заработало. Никуда сам никакие файлы не копировал. win7 64x ... |
| 29.05.2015, 10:15 |
Дикий Билл, спасибо через iis действительно просто. ... |
| 02.06.2015, 08:53 |
start [/forum/topic.php?desktop=1&fid=23&tid=1461369]: |
415ms |
57ms |
| others: | 222ms |
| total: | 746ms |
