[nginx] Погряз в конфигах, видимо мне пришел rewrite
Привет. Туплю над конфигом nginx'а не хочет он отрабатывать . С таким конфигом nginx просто не стал подниматься(пробует но через секунд 15 отваливается, неасилил): /home/admin/conf/web/nginx.conf server { listen 192.123.456.789:80; server_name site.com www.site.com; return 301 https://$server_name$request_uri; } server { listen 443; ssl on; ssl_certificate /etc/pki/site.com/ssl-bundle.crt; ssl_certificate_key /etc/pki/site.com/site.key; # side note: only use TLS since SSLv2 and SSLv3 have had recent vulnerabilities ssl_protocols TLSv1 TLSv1.1 TLSv1.2; root /home/admin/web/site.com/public_html; index index.php index.html index.htm; access_log /var/log/nginx/domains/site.com.log combined; access_log /var/log/nginx/domains/site.com.bytes bytes; error_log /var/log/nginx/domains/site.com.error.log error; location / { location ~ [^/]\.php(/|$) { fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name; if (!-f $document_root$fastcgi_script_name) { return 404; } fastcgi_pass 127.0.0.1:9001; fastcgi_index index.php; include /etc/nginx/fastcgi_params; } # = = = = = = = = = = = = = = = = = = = # = = = = = = = = = = = = = = = = = = = location /uploads/ { proxy_method GET; proxy_pass_request_body off; proxy_set_header Content-Length ""; proxy_pass https://ae01.alicdn.com/kf/; } if ($http_host ~* "^www\.(.*)"){ rewrite ^(.*)$ https://site.com$1 redirect; } expires 5s; rewrite ^/(img|fonts|css|js|humansonly)/(.*)$ /skin/$1/$2 last; location /skin/img { expires 1M; } if (!-e $request_filename){ rewrite ^(.*)$ /index.php; } # = = = = = = = = = = = = = = = = = = = # = = = = = = = = = = = = = = = = = = = } error_page 403 /error/404.html; error_page 404 /error/404.html; error_page 500 502 503 504 /error/50x.html; location /error/ { alias /home/admin/web/site.com/document_errors/; } location ~* "/\.(htaccess|htpasswd)$" { deny all; return 404; } } покоцал до такого (убрал участок красный, где проксировал графику снаружи): /home/admin/conf/web/nginx.conf server { listen 192.123.456.789:80; server_name site.com www.site.com; return 301 https://$server_name$request_uri; } server { listen 443; ssl on; ssl_certificate /etc/pki/site.com/ssl-bundle.crt; ssl_certificate_key /etc/pki/site.com/site.key; # side note: only use TLS since SSLv2 and SSLv3 have had recent vulnerabilities ssl_protocols TLSv1 TLSv1.1 TLSv1.2; root /home/admin/web/site.com/public_html; index index.php index.html index.htm; access_log /var/log/nginx/domains/site.com.log combined; access_log /var/log/nginx/domains/site.com.bytes bytes; error_log /var/log/nginx/domains/site.com.error.log error; location / { location ~ [^/]\.php(/|$) { fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name; if (!-f $document_root$fastcgi_script_name) { return 404; } fastcgi_pass 127.0.0.1:9001; fastcgi_index index.php; include /etc/nginx/fastcgi_params; } # = = = = = = = = = = = = = = = = = = = # = = = = = = = = = = = = = = = = = = = if ($http_host ~* "^www\.(.*)"){ rewrite ^(.*)$ https://site.com$1 redirect; } expires 5s; rewrite ^/(img|fonts|css|js|humansonly)/(.*)$ /skin/$1/$2 last; location /skin/img { expires 1M; } if (!-e $request_filename){ rewrite ^(.*)$ /index.php; } # = = = = = = = = = = = = = = = = = = = # = = = = = = = = = = = = = = = = = = = } error_page 403 /error/404.html; error_page 404 /error/404.html; error_page 500 502 503 504 /error/50x.html; location /error/ { alias /home/admin/web/site.com/document_errors/; } location ~* "/\.(htaccess|htpasswd)$" { deny all; return 404; } } но на сайте валится роутер - не отрабатывает участок выделенный голубым. перечитал кипу всякой инфы, но воз и ныне там. Пособите в правильном направлении пожалуйста. PS: на всякий случай: /etc/nginx/nginx.conf# Server globals user nginx; worker_processes auto; worker_rlimit_nofile 65535; error_log /var/log/nginx/error.log crit; pid /var/run/nginx.pid; # Worker config events { worker_connections 1024; use epoll; multi_accept on; } http { # Main settings sendfile on; tcp_nopush on; tcp_nodelay on; client_header_timeout 1m; client_body_timeout 1m; client_header_buffer_size 2k; client_body_buffer_size 256k; client_max_body_size 256m; large_client_header_buffers 4 8k; send_timeout 30; keepalive_timeout 60 60; reset_timedout_connection on; server_tokens off; server_name_in_redirect off; server_names_hash_max_size 512; server_names_hash_bucket_size 512; # Log format log_format main '$remote_addr - $remote_user [$time_local] $request ' '"$status" $body_bytes_sent "$http_referer" ' '"$http_user_agent" "$http_x_forwarded_for"'; log_format bytes '$body_bytes_sent'; #access_log /var/log/nginx/access.log main; access_log off; # Mime settings include /etc/nginx/mime.types; default_type application/octet-stream; # Compression gzip on; gzip_comp_level 9; gzip_min_length 512; gzip_buffers 8 64k; gzip_types text/plain text/css text/javascript text/js text/xml application/json application/javascript application/x-javascript application/xml application/xml+rss application/x-font-ttf image/svg+xml font/opentype; gzip_proxied any; gzip_disable "MSIE [1-6]\."; # Proxy settings proxy_redirect off; proxy_set_header Host $host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_pass_header Set-Cookie; proxy_connect_timeout 90; proxy_send_timeout 90; proxy_read_timeout 90; proxy_buffers 32 4k; # Cloudflare https://www.cloudflare.com/ips set_real_ip_from 199.27.128.0/21; set_real_ip_from 173.245.48.0/20; set_real_ip_from 103.21.244.0/22; set_real_ip_from 103.22.200.0/22; set_real_ip_from 103.31.4.0/22; set_real_ip_from 141.101.64.0/18; set_real_ip_from 108.162.192.0/18; set_real_ip_from 190.93.240.0/20; set_real_ip_from 188.114.96.0/20; set_real_ip_from 197.234.240.0/22; set_real_ip_from 198.41.128.0/17; set_real_ip_from 162.158.0.0/15; set_real_ip_from 104.16.0.0/12; set_real_ip_from 172.64.0.0/13; #set_real_ip_from 2400:cb00::/32; #set_real_ip_from 2606:4700::/32; #set_real_ip_from 2803:f800::/32; #set_real_ip_from 2405:b500::/32; #set_real_ip_from 2405:8100::/32; real_ip_header CF-Connecting-IP; # SSL PCI Compliance ssl_session_cache shared:SSL:10m; ssl_protocols TLSv1 TLSv1.1 TLSv1.2; ssl_prefer_server_ciphers on; ssl_ciphers "ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA:ECDHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES256-GCM-SHA384:AES128-GCM-SHA256:AES256-SHA256:AES128-SHA256:AES256-SHA:AES128-SHA:DES-CBC3-SHA:HIGH:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4"; # Error pages error_page 403 /error/403.html; error_page 404 /error/404.html; error_page 502 503 504 /error/50x.html; # Cache settings proxy_cache_path /var/cache/nginx levels=2 keys_zone=cache:10m inactive=60m max_size=1024m; proxy_cache_key "$host$request_uri $cookie_user"; proxy_temp_path /var/cache/nginx/temp; proxy_ignore_headers Expires Cache-Control; proxy_cache_use_stale error timeout invalid_header http_502; proxy_cache_valid any 1d; # Cache bypass map $http_cookie $no_cache { default 0; ~SESS 1; ~wordpress_logged_in 1; } # File cache settings open_file_cache max=10000 inactive=30s; open_file_cache_valid 60s; open_file_cache_min_uses 2; open_file_cache_errors off; # Wildcard include include /etc/nginx/conf.d/*.conf; } Сервер работает по Centos 7 64 nginx + php7-fpm ... |
| 27.03.2017, 13:02 |
start [/forum/topic.php?desktop=1&fid=23&tid=1460692]: |
37ms |
28ms |
| others: | 226ms |
| total: | 335ms |
