Не удается установить Pandas при помощи Pip на Windows 10 x64. Как побороть?
Windows 10 Python 3.6.5 При выполнении в командном окне windows команды: pip install pandas==0.16.2 получаю список ошибок Collecting pandas==0.16.2 Using cached https://files.pythonhosted.org/packages/b6/39/9c18df7531a2aaf65e44920aef0fbd21c7ce9ce7aad296fc7e2b323e81b7/pandas-0.16.2.tar.gz Requirement already satisfied: python-dateutil>=2 in c:\python36amd64\lib\site-packages (from pandas==0.16.2) (2.7.3) Requirement already satisfied: pytz>=2011k in c:\python36amd64\lib\site-packages (from pandas==0.16.2) (2018.4) Requirement already satisfied: numpy>=1.7.0 in c:\python36amd64\lib\site-packages (from pandas==0.16.2) (1.14.5) Requirement already satisfied: six>=1.5 in c:\python36amd64\lib\site-packages (from python-dateutil>=2->pandas==0.16.2) (1.11.0) Installing collected packages: pandas Running setup.py install for pandas ... error Complete output from command c:\python36amd64\python.exe -u -c "import setuptools, tokenize;__file__='C:\\Temp\\pip-install-10mbx_19\\pandas\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record C:\Temp\pip-record-f1exvoet\install-record.txt --single-version-externally-managed --compile: running install running build running build_py creating build creating build\lib.win-amd64-3.6 creating build\lib.win-amd64-3.6\pandas copying pandas\info.py -> build\lib.win-amd64-3.6\pandas copying pandas\version.py -> build\lib.win-amd64-3.6\pandas copying pandas\__init__.py -> build\lib.win-amd64-3.6\pandas creating build\lib.win-amd64-3.6\pandas\compat copying pandas\compat\chainmap.py -> build\lib.win-amd64-3.6\pandas\compat copying pandas\compat\chainmap_impl.py -> build\lib.win-amd64-3.6\pandas\compat copying pandas\compat\openpyxl_compat.py -> build\lib.win-amd64-3.6\pandas\compat copying pandas\compat\pickle_compat.py -> build\lib.win-amd64-3.6\pandas\compat copying pandas\compat\__init__.py -> build\lib.win-amd64-3.6\pandas\compat creating build\lib.win-amd64-3.6\pandas\computation copying pandas\computation\align.py -> build\lib.win-amd64-3.6\pandas\computation copying pandas\computation\api.py -> build\lib.win-amd64-3.6\pandas\computation copying pandas\computation\common.py -> build\lib.win-amd64-3.6\pandas\computation copying pandas\computation\engines.py -> build\lib.win-amd64-3.6\pandas\computation copying pandas\computation\eval.py -> build\lib.win-amd64-3.6\pandas\computation copying pandas\computation\expr.py -> build\lib.win-amd64-3.6\pandas\computation copying pandas\computation\expressions.py -> build\lib.win-amd64-3.6\pandas\computation copying pandas\computation\ops.py -> build\lib.win-amd64-3.6\pandas\computation copying pandas\computation\pytables.py -> build\lib.win-amd64-3.6\pandas\computation copying pandas\computation\scope.py -> build\lib.win-amd64-3.6\pandas\computation copying pandas\computation\__init__.py -> build\lib.win-amd64-3.6\pandas\computation creating build\lib.win-amd64-3.6\pandas\computation\tests copying pandas\computation\tests\test_eval.py -> build\lib.win-amd64-3.6\pandas\computation\tests copying pandas\computation\tests\__init__.py -> build\lib.win-amd64-3.6\pandas\computation\tests creating build\lib.win-amd64-3.6\pandas\core copying pandas\core\algorithms.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\api.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\base.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\categorical.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\common.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\config.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\config_init.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\datetools.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\format.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\frame.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\generic.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\groupby.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\index.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\indexing.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\internals.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\matrix.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\nanops.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\ops.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\panel.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\panel4d.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\panelnd.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\reshape.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\series.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\sparse.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\strings.py -> build\lib.win-amd64-3.6\pandas\core copying pandas\core\__init__.py -> build\lib.win-amd64-3.6\pandas\core creating build\lib.win-amd64-3.6\pandas\io copying pandas\io\api.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\auth.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\clipboard.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\common.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\data.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\date_converters.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\excel.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\ga.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\gbq.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\html.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\json.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\packers.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\parsers.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\pickle.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\pytables.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\sql.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\stata.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\wb.py -> build\lib.win-amd64-3.6\pandas\io copying pandas\io\__init__.py -> build\lib.win-amd64-3.6\pandas\io creating build\lib.win-amd64-3.6\pandas\rpy copying pandas\rpy\base.py -> build\lib.win-amd64-3.6\pandas\rpy copying pandas\rpy\common.py -> build\lib.win-amd64-3.6\pandas\rpy copying pandas\rpy\mass.py -> build\lib.win-amd64-3.6\pandas\rpy copying pandas\rpy\vars.py -> build\lib.win-amd64-3.6\pandas\rpy copying pandas\rpy\__init__.py -> build\lib.win-amd64-3.6\pandas\rpy creating build\lib.win-amd64-3.6\pandas\sandbox copying pandas\sandbox\qtpandas.py -> build\lib.win-amd64-3.6\pandas\sandbox copying pandas\sandbox\__init__.py -> build\lib.win-amd64-3.6\pandas\sandbox creating build\lib.win-amd64-3.6\pandas\sparse copying pandas\sparse\api.py -> build\lib.win-amd64-3.6\pandas\sparse copying pandas\sparse\array.py -> build\lib.win-amd64-3.6\pandas\sparse copying pandas\sparse\frame.py -> build\lib.win-amd64-3.6\pandas\sparse copying pandas\sparse\list.py -> build\lib.win-amd64-3.6\pandas\sparse copying pandas\sparse\panel.py -> build\lib.win-amd64-3.6\pandas\sparse copying pandas\sparse\scipy_sparse.py -> build\lib.win-amd64-3.6\pandas\sparse copying pandas\sparse\series.py -> build\lib.win-amd64-3.6\pandas\sparse copying pandas\sparse\__init__.py -> build\lib.win-amd64-3.6\pandas\sparse creating build\lib.win-amd64-3.6\pandas\sparse\tests copying pandas\sparse\tests\test_array.py -> build\lib.win-amd64-3.6\pandas\sparse\tests copying pandas\sparse\tests\test_libsparse.py -> build\lib.win-amd64-3.6\pandas\sparse\tests copying pandas\sparse\tests\test_list.py -> build\lib.win-amd64-3.6\pandas\sparse\tests copying pandas\sparse\tests\test_sparse.py -> build\lib.win-amd64-3.6\pandas\sparse\tests copying pandas\sparse\tests\__init__.py -> build\lib.win-amd64-3.6\pandas\sparse\tests creating build\lib.win-amd64-3.6\pandas\stats copying pandas\stats\api.py -> build\lib.win-amd64-3.6\pandas\stats copying pandas\stats\common.py -> build\lib.win-amd64-3.6\pandas\stats copying pandas\stats\fama_macbeth.py -> build\lib.win-amd64-3.6\pandas\stats copying pandas\stats\interface.py -> build\lib.win-amd64-3.6\pandas\stats copying pandas\stats\math.py -> build\lib.win-amd64-3.6\pandas\stats copying pandas\stats\misc.py -> build\lib.win-amd64-3.6\pandas\stats copying pandas\stats\moments.py -> build\lib.win-amd64-3.6\pandas\stats copying pandas\stats\ols.py -> build\lib.win-amd64-3.6\pandas\stats copying pandas\stats\plm.py -> build\lib.win-amd64-3.6\pandas\stats copying pandas\stats\var.py -> build\lib.win-amd64-3.6\pandas\stats copying pandas\stats\__init__.py -> build\lib.win-amd64-3.6\pandas\stats creating build\lib.win-amd64-3.6\pandas\util copying pandas\util\clipboard.py -> build\lib.win-amd64-3.6\pandas\util copying pandas\util\decorators.py -> build\lib.win-amd64-3.6\pandas\util copying pandas\util\doctools.py -> build\lib.win-amd64-3.6\pandas\util copying pandas\util\misc.py -> build\lib.win-amd64-3.6\pandas\util copying pandas\util\print_versions.py -> build\lib.win-amd64-3.6\pandas\util copying pandas\util\terminal.py -> build\lib.win-amd64-3.6\pandas\util copying pandas\util\testing.py -> build\lib.win-amd64-3.6\pandas\util copying pandas\util\__init__.py -> build\lib.win-amd64-3.6\pandas\util creating build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_algos.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_base.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_categorical.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_common.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_compat.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_config.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_expressions.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_format.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_frame.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_generic.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_graphics.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_groupby.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_index.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_indexing.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_internals.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_lib.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_multilevel.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_nanops.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_panel.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_panel4d.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_panelnd.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_reshape.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_rplot.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_series.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_stats.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_strings.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_testing.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_tseries.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\test_util.py -> build\lib.win-amd64-3.6\pandas\tests copying pandas\tests\__init__.py -> build\lib.win-amd64-3.6\pandas\tests creating build\lib.win-amd64-3.6\pandas\tests\test_msgpack copying pandas\tests\test_msgpack\test_buffer.py -> build\lib.win-amd64-3.6\pandas\tests\test_msgpack copying pandas\tests\test_msgpack\test_case.py -> build\lib.win-amd64-3.6\pandas\tests\test_msgpack copying pandas\tests\test_msgpack\test_except.py -> build\lib.win-amd64-3.6\pandas\tests\test_msgpack copying pandas\tests\test_msgpack\test_format.py -> build\lib.win-amd64-3.6\pandas\tests\test_msgpack copying pandas\tests\test_msgpack\test_obj.py -> build\lib.win-amd64-3.6\pandas\tests\test_msgpack copying pandas\tests\test_msgpack\test_pack.py -> build\lib.win-amd64-3.6\pandas\tests\test_msgpack copying pandas\tests\test_msgpack\test_read_size.py -> build\lib.win-amd64-3.6\pandas\tests\test_msgpack copying pandas\tests\test_msgpack\test_seq.py -> build\lib.win-amd64-3.6\pandas\tests\test_msgpack copying pandas\tests\test_msgpack\test_sequnpack.py -> build\lib.win-amd64-3.6\pandas\tests\test_msgpack copying pandas\tests\test_msgpack\test_subtype.py -> build\lib.win-amd64-3.6\pandas\tests\test_msgpack copying pandas\tests\test_msgpack\test_unpack_raw.py -> build\lib.win-amd64-3.6\pandas\tests\test_msgpack copying pandas\tests\test_msgpack\__init__.py -> build\lib.win-amd64-3.6\pandas\tests\test_msgpack creating build\lib.win-amd64-3.6\pandas\tools copying pandas\tools\merge.py -> build\lib.win-amd64-3.6\pandas\tools copying pandas\tools\pivot.py -> build\lib.win-amd64-3.6\pandas\tools copying pandas\tools\plotting.py -> build\lib.win-amd64-3.6\pandas\tools copying pandas\tools\rplot.py -> build\lib.win-amd64-3.6\pandas\tools copying pandas\tools\tile.py -> build\lib.win-amd64-3.6\pandas\tools copying pandas\tools\util.py -> build\lib.win-amd64-3.6\pandas\tools copying pandas\tools\__init__.py -> build\lib.win-amd64-3.6\pandas\tools creating build\lib.win-amd64-3.6\pandas\tools\tests copying pandas\tools\tests\test_merge.py -> build\lib.win-amd64-3.6\pandas\tools\tests copying pandas\tools\tests\test_pivot.py -> build\lib.win-amd64-3.6\pandas\tools\tests copying pandas\tools\tests\test_tile.py -> build\lib.win-amd64-3.6\pandas\tools\tests copying pandas\tools\tests\test_util.py -> build\lib.win-amd64-3.6\pandas\tools\tests copying pandas\tools\tests\__init__.py -> build\lib.win-amd64-3.6\pandas\tools\tests creating build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\api.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\base.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\common.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\converter.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\frequencies.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\holiday.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\index.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\interval.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\offsets.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\period.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\plotting.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\resample.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\tdi.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\timedeltas.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\tools.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\util.py -> build\lib.win-amd64-3.6\pandas\tseries copying pandas\tseries\__init__.py -> build\lib.win-amd64-3.6\pandas\tseries creating build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\test_base.py -> build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\test_converter.py -> build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\test_daterange.py -> build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\test_frequencies.py -> build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\test_holiday.py -> build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\test_offsets.py -> build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\test_period.py -> build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\test_plotting.py -> build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\test_resample.py -> build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\test_timedeltas.py -> build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\test_timeseries.py -> build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\test_timeseries_legacy.py -> build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\test_timezones.py -> build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\test_tslib.py -> build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\test_util.py -> build\lib.win-amd64-3.6\pandas\tseries\tests copying pandas\tseries\tests\__init__.py -> build\lib.win-amd64-3.6\pandas\tseries\tests creating build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\generate_legacy_pickles.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_clipboard.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_common.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_cparser.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_data.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_date_converters.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_excel.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_ga.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_gbq.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_html.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_json_norm.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_packers.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_parsers.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_pickle.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_pytables.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_sql.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_stata.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\test_wb.py -> build\lib.win-amd64-3.6\pandas\io\tests copying pandas\io\tests\__init__.py -> build\lib.win-amd64-3.6\pandas\io\tests creating build\lib.win-amd64-3.6\pandas\io\tests\test_json copying pandas\io\tests\test_json\test_pandas.py -> build\lib.win-amd64-3.6\pandas\io\tests\test_json copying pandas\io\tests\test_json\test_ujson.py -> build\lib.win-amd64-3.6\pandas\io\tests\test_json copying pandas\io\tests\test_json\__init__.py -> build\lib.win-amd64-3.6\pandas\io\tests\test_json creating build\lib.win-amd64-3.6\pandas\stats\tests copying pandas\stats\tests\common.py -> build\lib.win-amd64-3.6\pandas\stats\tests copying pandas\stats\tests\test_fama_macbeth.py -> build\lib.win-amd64-3.6\pandas\stats\tests copying pandas\stats\tests\test_math.py -> build\lib.win-amd64-3.6\pandas\stats\tests copying pandas\stats\tests\test_moments.py -> build\lib.win-amd64-3.6\pandas\stats\tests copying pandas\stats\tests\test_ols.py -> build\lib.win-amd64-3.6\pandas\stats\tests copying pandas\stats\tests\test_var.py -> build\lib.win-amd64-3.6\pandas\stats\tests copying pandas\stats\tests\__init__.py -> build\lib.win-amd64-3.6\pandas\stats\tests creating build\lib.win-amd64-3.6\pandas\io\tests\data creating build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_hdf copying pandas\io\tests\data\legacy_hdf\legacy.h5 -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_hdf copying pandas\io\tests\data\legacy_hdf\legacy_0.10.h5 -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_hdf copying pandas\io\tests\data\legacy_hdf\legacy_table.h5 -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_hdf copying pandas\io\tests\data\legacy_hdf\legacy_table_0.11.h5 -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_hdf copying pandas\io\tests\data\legacy_hdf\pytables_native.h5 -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_hdf copying pandas\io\tests\data\legacy_hdf\pytables_native2.h5 -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_hdf creating build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle creating build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.10.1 copying pandas\io\tests\data\legacy_pickle\0.10.1\AMD64_windows_2.7.3.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.10.1 copying pandas\io\tests\data\legacy_pickle\0.10.1\x86_64_linux_2.7.3.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.10.1 creating build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.11.0 copying pandas\io\tests\data\legacy_pickle\0.11.0\0.11.0_x86_64_linux_3.3.0.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.11.0 copying pandas\io\tests\data\legacy_pickle\0.11.0\x86_64_linux_2.7.3.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.11.0 copying pandas\io\tests\data\legacy_pickle\0.11.0\x86_64_linux_3.3.0.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.11.0 creating build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.12.0 copying pandas\io\tests\data\legacy_pickle\0.12.0\0.12.0_AMD64_windows_2.7.3.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.12.0 copying pandas\io\tests\data\legacy_pickle\0.12.0\0.12.0_x86_64_linux_2.7.3.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.12.0 creating build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.13.0 copying pandas\io\tests\data\legacy_pickle\0.13.0\0.13.0_AMD64_windows_2.7.3.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.13.0 copying pandas\io\tests\data\legacy_pickle\0.13.0\0.13.0_i686_linux_2.6.5.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.13.0 copying pandas\io\tests\data\legacy_pickle\0.13.0\0.13.0_i686_linux_2.7.3.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.13.0 copying pandas\io\tests\data\legacy_pickle\0.13.0\0.13.0_i686_linux_3.2.3.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.13.0 copying pandas\io\tests\data\legacy_pickle\0.13.0\0.13.0_x86_64_darwin_2.7.5.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.13.0 copying pandas\io\tests\data\legacy_pickle\0.13.0\0.13.0_x86_64_darwin_2.7.6.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.13.0 copying pandas\io\tests\data\legacy_pickle\0.13.0\0.13.0_x86_64_linux_2.7.3.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.13.0 copying pandas\io\tests\data\legacy_pickle\0.13.0\0.13.0_x86_64_linux_2.7.8.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.13.0 copying pandas\io\tests\data\legacy_pickle\0.13.0\0.13.0_x86_64_linux_3.3.0.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.13.0 creating build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.14.0 copying pandas\io\tests\data\legacy_pickle\0.14.0\0.14.0_x86_64_darwin_2.7.6.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.14.0 copying pandas\io\tests\data\legacy_pickle\0.14.0\0.14.0_x86_64_linux_2.7.8.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.14.0 creating build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.14.1 copying pandas\io\tests\data\legacy_pickle\0.14.1\0.14.1_x86_64_linux_2.7.8.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.14.1 creating build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.15.0 copying pandas\io\tests\data\legacy_pickle\0.15.0\0.15.0_x86_64_linux_2.7.8.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.15.0 creating build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.15.2 copying pandas\io\tests\data\legacy_pickle\0.15.2\0.15.2_x86_64_darwin_2.7.9.pickle -> build\lib.win-amd64-3.6\pandas\io\tests\data\legacy_pickle\0.15.2 copying pandas\io\tests\data\banklist.csv -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\iris.csv -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata3.csv -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata5.csv -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata6.csv -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\test1.csv -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\test1.csv.bz2 -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\test1.csv.gz -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\test2.csv -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\tips.csv -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\unicode_series.csv -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata10_115.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata10_117.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata11_115.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata11_117.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata12_117.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata1_114.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata1_117.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata1_encoding.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata2_113.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata2_114.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata2_115.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata2_117.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata3_113.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata3_114.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata3_115.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata3_117.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata4_113.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata4_114.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata4_115.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata4_117.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata5_113.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata5_114.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata5_115.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata5_117.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata6_113.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata6_114.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata6_115.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata6_117.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata7_115.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata7_117.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata8_113.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata8_115.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata8_117.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata9_115.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\stata9_117.dta -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\gbq_fake_job.txt -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\utf16_ex.txt -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\test.xls -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\test2.xls -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\test3.xls -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\test_converters.xls -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\test_types.xls -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\times_1900.xls -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\times_1904.xls -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\test.xlsx -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\test2.xlsx -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\test_converters.xlsx -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\test_multisheet.xlsx -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\test_types.xlsx -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\test.xlsm -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\salary.table -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\banklist.html -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\computer_sales_page.html -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\macau.html -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\nyse_wsj.html -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\spam.html -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\valid_markup.html -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\wikipedia_states.html -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\yahoo_options1.html -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\yahoo_options2.html -> build\lib.win-amd64-3.6\pandas\io\tests\data copying pandas\io\tests\data\yahoo_options3.html -> build\lib.win-amd64-3.6\pandas\io\tests\data creating build\lib.win-amd64-3.6\pandas\io\tests\data\html_encoding copying pandas\io\tests\data\html_encoding\chinese_utf-16.html -> build\lib.win-amd64-3.6\pandas\io\tests\data\html_encoding copying pandas\io\tests\data\html_encoding\chinese_utf-32.html -> build\lib.win-amd64-3.6\pandas\io\tests\data\html_encoding copying pandas\io\tests\data\html_encoding\chinese_utf-8.html -> build\lib.win-amd64-3.6\pandas\io\tests\data\html_encoding copying pandas\io\tests\data\html_encoding\letz_latin1.html -> build\lib.win-amd64-3.6\pandas\io\tests\data\html_encoding creating build\lib.win-amd64-3.6\pandas\io\tests\test_json\data copying pandas\io\tests\test_json\data\tsframe_iso_v012.json -> build\lib.win-amd64-3.6\pandas\io\tests\test_json\data copying pandas\io\tests\test_json\data\tsframe_v012.json -> build\lib.win-amd64-3.6\pandas\io\tests\test_json\data creating build\lib.win-amd64-3.6\pandas\tests\data copying pandas\tests\data\categorical_0_14_1.pickle -> build\lib.win-amd64-3.6\pandas\tests\data copying pandas\tests\data\categorical_0_15_2.pickle -> build\lib.win-amd64-3.6\pandas\tests\data copying pandas\tests\data\mindex_073.pickle -> build\lib.win-amd64-3.6\pandas\tests\data copying pandas\tests\data\multiindex_v1.pickle -> build\lib.win-amd64-3.6\pandas\tests\data copying pandas\tests\data\s1-0.12.0.pickle -> build\lib.win-amd64-3.6\pandas\tests\data copying pandas\tests\data\s2-0.12.0.pickle -> build\lib.win-amd64-3.6\pandas\tests\data copying pandas\tests\data\iris.csv -> build\lib.win-amd64-3.6\pandas\tests\data copying pandas\tests\data\tips.csv -> build\lib.win-amd64-3.6\pandas\tests\data copying pandas\tests\data\unicode_series.csv -> build\lib.win-amd64-3.6\pandas\tests\data copying pandas\tools\tests\cut_data.csv -> build\lib.win-amd64-3.6\pandas\tools\tests creating build\lib.win-amd64-3.6\pandas\tseries\tests\data copying pandas\tseries\tests\data\cday-0.14.1.pickle -> build\lib.win-amd64-3.6\pandas\tseries\tests\data copying pandas\tseries\tests\data\dateoffset_0_15_2.pickle -> build\lib.win-amd64-3.6\pandas\tseries\tests\data copying pandas\tseries\tests\data\daterange_073.pickle -> build\lib.win-amd64-3.6\pandas\tseries\tests\data copying pandas\tseries\tests\data\frame.pickle -> build\lib.win-amd64-3.6\pandas\tseries\tests\data copying pandas\tseries\tests\data\series.pickle -> build\lib.win-amd64-3.6\pandas\tseries\tests\data copying pandas\tseries\tests\data\series_daterange0.pickle -> build\lib.win-amd64-3.6\pandas\tseries\tests\data running build_ext building 'pandas.lib' extension creating build\temp.win-amd64-3.6 creating build\temp.win-amd64-3.6\Release creating build\temp.win-amd64-3.6\Release\pandas C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\bin\HostX86\x64\cl.exe /c /nologo /Ox /W3 /GL /DNDEBUG /MD -Ipandas/src/klib -Ipandas/src -Ic:\python36amd64\lib\site-packages\numpy\core\include -Ic:\python36amd64\include -Ic:\python36amd64\include "-IC:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\ATLMFC\include" "-IC:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include" "-IC:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\include\um" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\shared" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\um" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\winrt" /Tcpandas\lib.c /Fobuild\temp.win-amd64-3.6\Release\pandas\lib.obj lib.c c:\python36amd64\lib\site-packages\numpy\core\include\numpy\npy_1_7_deprecated_api.h(12) : Warning Msg: Using deprecated NumPy API, disable it by #defining NPY_NO_DEPRECATED_API NPY_1_7_API_VERSION c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(105): error C2371: int_fast16_t: переопределение; различные базовые типы C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(36): note: см. объявление "int_fast16_t" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(109): error C2371: uint_fast16_t: переопределение; различные базовые типы C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(40): note: см. объявление "uint_fast16_t" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(132): warning C4005: INT8_MIN: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(48): note: см. предыдущее определение "INT8_MIN" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(133): warning C4005: INT8_MAX: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(52): note: см. предыдущее определение "INT8_MAX" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(134): warning C4005: INT16_MIN: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(49): note: см. предыдущее определение "INT16_MIN" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(135): warning C4005: INT16_MAX: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(53): note: см. предыдущее определение "INT16_MAX" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(136): warning C4005: INT32_MIN: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(50): note: см. предыдущее определение "INT32_MIN" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(137): warning C4005: INT32_MAX: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(54): note: см. предыдущее определение "INT32_MAX" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(138): warning C4005: INT64_MIN: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(51): note: см. предыдущее определение "INT64_MIN" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(139): warning C4005: INT64_MAX: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(55): note: см. предыдущее определение "INT64_MAX" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(140): warning C4005: UINT8_MAX: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(56): note: см. предыдущее определение "UINT8_MAX" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(141): warning C4005: UINT16_MAX: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(57): note: см. предыдущее определение "UINT16_MAX" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(142): warning C4005: UINT32_MAX: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(58): note: см. предыдущее определение "UINT32_MAX" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(143): warning C4005: UINT64_MAX: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(59): note: см. предыдущее определение "UINT64_MAX" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(162): warning C4005: INT_FAST16_MIN: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(75): note: см. предыдущее определение "INT_FAST16_MIN" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(163): warning C4005: INT_FAST16_MAX: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(79): note: см. предыдущее определение "INT_FAST16_MAX" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(169): warning C4005: UINT_FAST16_MAX: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(83): note: см. предыдущее определение "UINT_FAST16_MAX" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(192): warning C4005: PTRDIFF_MIN: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(101): note: см. предыдущее определение "PTRDIFF_MIN" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(193): warning C4005: PTRDIFF_MAX: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(102): note: см. предыдущее определение "PTRDIFF_MAX" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(199): warning C4005: SIG_ATOMIC_MIN: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(108): note: см. предыдущее определение "SIG_ATOMIC_MIN" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(200): warning C4005: SIG_ATOMIC_MAX: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(109): note: см. предыдущее определение "SIG_ATOMIC_MAX" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(218): warning C4005: WINT_MIN: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(114): note: см. предыдущее определение "WINT_MIN" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(219): warning C4005: WINT_MAX: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(115): note: см. предыдущее определение "WINT_MAX" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(230): warning C4005: INT8_C: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(117): note: см. предыдущее определение "INT8_C" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(231): warning C4005: INT16_C: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(118): note: см. предыдущее определение "INT16_C" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(232): warning C4005: INT32_C: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(119): note: см. предыдущее определение "INT32_C" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(233): warning C4005: INT64_C: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(120): note: см. предыдущее определение "INT64_C" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(235): warning C4005: UINT8_C: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(122): note: см. предыдущее определение "UINT8_C" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(236): warning C4005: UINT16_C: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(123): note: см. предыдущее определение "UINT16_C" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(237): warning C4005: UINT32_C: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(124): note: см. предыдущее определение "UINT32_C" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(238): warning C4005: UINT64_C: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(125): note: см. предыдущее определение "UINT64_C" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(241): warning C4005: INTMAX_C: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(127): note: см. предыдущее определение "INTMAX_C" c:\temp\pip-install-10mbx_19\pandas\pandas\src\headers\ms_stdint.h(242): warning C4005: UINTMAX_C: изменение макроопределения C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\include\stdint.h(128): note: см. предыдущее определение "UINTMAX_C" pandas/src\datetime_helper.h(7): warning C4005: PyInt_AS_LONG: изменение макроопределения pandas\lib.c(145): note: см. предыдущее определение "PyInt_AS_LONG" pandas\lib.c(5534): warning C4244: =: преобразование "Py_ssize_t" в "int", возможна потеря данных pandas\lib.c(5611): warning C4244: +=: преобразование "Py_ssize_t" в "int", возможна потеря данных pandas\lib.c(5623): warning C4244: +=: преобразование "Py_ssize_t" в "int", возможна потеря данных pandas\lib.c(5759): warning C4244: =: преобразование "Py_ssize_t" в "int", возможна потеря данных pandas\lib.c(5830): warning C4244: +=: преобразование "Py_ssize_t" в "int", возможна потеря данных pandas\lib.c(5842): warning C4244: +=: преобразование "Py_ssize_t" в "int", возможна потеря данных pandas\lib.c(11291): warning C4244: +=: преобразование "Py_ssize_t" в "long", возможна потеря данных pandas\lib.c(11382): warning C4244: +=: преобразование "Py_ssize_t" в "long", возможна потеря данных pandas\lib.c(17176): warning C4244: =: преобразование "npy_intp" в "int", возможна потеря данных pandas\lib.c(17441): warning C4244: =: преобразование "Py_ssize_t" в "int", возможна потеря данных pandas\lib.c(18159): warning C4244: =: преобразование "npy_intp" в "int", возможна потеря данных pandas\lib.c(18235): warning C4244: +=: преобразование "Py_ssize_t" в "int", возможна потеря данных pandas\lib.c(18266): warning C4244: +=: преобразование "Py_ssize_t" в "int", возможна потеря данных pandas\lib.c(23627): warning C4244: +=: преобразование "Py_ssize_t" в "long", возможна потеря данных pandas\lib.c(26102): warning C4133: функция: несовместимые типы - из "PySliceObject *" в "PyObject *" pandas\lib.c(26326): warning C4133: функция: несовместимые типы - из "PySliceObject *" в "PyObject *" pandas\lib.c(32797): warning C4244: +=: преобразование "Py_ssize_t" в "long", возможна потеря данных pandas\lib.c(39169): warning C4244: +=: преобразование "Py_ssize_t" в "long", возможна потеря данных pandas\lib.c(39179): warning C4244: +=: преобразование "Py_ssize_t" в "long", возможна потеря данных pandas\lib.c(39421): warning C4244: функция: преобразование "__pyx_t_5numpy_int64_t" в "int", возможна потеря данных pandas\lib.c(40001): warning C4244: =: преобразование "Py_ssize_t" в "int", возможна потеря данных pandas\lib.c(59034): warning C4244: +=: преобразование "Py_ssize_t" в "long", возможна потеря данных pandas\lib.c(60141): warning C4244: функция: преобразование "Py_ssize_t" в "int", возможна потеря данных pandas\lib.c(60349): warning C4244: функция: преобразование "npy_int64" в "int", возможна потеря данных error: command 'C:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Community\\VC\\Tools\\MSVC\\14.11.25503\\bin\\HostX86\\x64\\cl.exe' failed with exit status 2 ---------------------------------------- Command "c:\python36amd64\python.exe -u -c "import setuptools, tokenize;__file__='C:\\Temp\\pip-install-10mbx_19\\pandas\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record C:\Temp\pip-record-f1exvoet\install-record.txt --single-version-externally-managed --compile" failed with error code 1 in C:\Temp\pip-install-10mbx_19\pandas\ Что это за ошибки? Что надо сделать чтобы установить все таки Pandas используя Pip? Пробовал через Anaconda, но там при установке нужной мне версии 0.16.2 выполняется принудительный даунгрейд Python до версии 3.5.5, что неприемлемо. Может есть какая возможность установленный в виртуальном окружении Conda пакет Pandas нужной мне версии скопировать в мой Python 3.6.5 ? ... |
| 20.06.2018, 16:33:55 |
start [/forum/topic.php?desktop=1&fid=23&tid=1460263]: |
27ms |
28ms |
| others: | 235ms |
| total: | 333ms |
