PyCharm обновить pip
При создании проекта в PyCharm создаётся и окружения разработка( в том числе и pip). тоесть можно подгружать модули Кое какие подгружает. Но пытаюсь подгрузить(в терменале) такое: автор(venv) C:\.........\..........\Documents\PythonProjects\testProject>pip install python-mysqldb результат: авторCollecting python-mysqldb Could not find a version that satisfies the requirement python-mysqldb (from versions: ) No matching distribution found for python-mysqldb You are using pip version 9.0.1, however version 18.0 is available. You should consider upgrading via the 'python -m pip install --upgrade pip' command. Тоеть надо обновить pip Делаю: автор(venv) C:\.............\.............\Documents\PythonProjects\testProject>python -m pip install --upgrade pip Результат: авторCollecting pip Using cached https://files.pythonhosted.org/packages/5f/25/e52d3f31441505a5f3af41213346e5b6c221c9e086a166f3703d2ddaf940/pip-18.0-py2.py3-none-any.whl Installing collected packages: pip Found existing installation: pip 9.0.1 Uninstalling pip-9.0.1: Successfully uninstalled pip-9.0.1 Rolling back uninstall of pip Exception: Traceback (most recent call last): File "C:\Users\Areostar\Documents\PythonProjects\testProject\venv\lib\site-packages\pip-9.0.1-py3.6.egg\pip\basecommand.py", line 215, in main status = self.run(options, args) File "C:\Users\Areostar\Documents\PythonProjects\testProject\venv\lib\site-packages\pip-9.0.1-py3.6.egg\pip\commands\install.py", line 342, in run prefix=options.prefix_path, File "C:\Users\Areostar\Documents\PythonProjects\testProject\venv\lib\site-packages\pip-9.0.1-py3.6.egg\pip\req\req_set.py", line 784, in install **kwargs File "C:\Users\Areostar\Documents\PythonProjects\testProject\venv\lib\site-packages\pip-9.0.1-py3.6.egg\pip\req\req_install.py", line 851, in install self.move_wheel_files(self.source_dir, root=root, prefix=prefix) File "C:\Users\Areostar\Documents\PythonProjects\testProject\venv\lib\site-packages\pip-9.0.1-py3.6.egg\pip\req\req_install.py", line 1064, in move_wheel_files isolated=self.isolated, File "C:\Users\Areostar\Documents\PythonProjects\testProject\venv\lib\site-packages\pip-9.0.1-py3.6.egg\pip\wheel.py", line 462, in move_wheel_files generated.extend(maker.make(spec)) File "C:\Users\Areostar\Documents\PythonProjects\testProject\venv\lib\site-packages\pip-9.0.1-py3.6.egg\pip\_vendor\distlib\scripts.py", line 372, in make self._make_script(entry, filenames, options=options) File "C:\Users\Areostar\Documents\PythonProjects\testProject\venv\lib\site-packages\pip-9.0.1-py3.6.egg\pip\_vendor\distlib\scripts.py", line 276, in _make_script self._write_script(scriptnames, shebang, script, filenames, ext) File "C:\Users\Areostar\Documents\PythonProjects\testProject\venv\lib\site-packages\pip-9.0.1-py3.6.egg\pip\_vendor\distlib\scripts.py", line 212, in _write_script launcher = self._get_launcher('t') File "C:\Users\Areostar\Documents\PythonProjects\testProject\venv\lib\site-packages\pip-9.0.1-py3.6.egg\pip\_vendor\distlib\scripts.py", line 351, in _get_launcher result = finder(distlib_package).find(name).bytes AttributeError: 'NoneType' object has no attribute 'bytes' Я чтото не так сделал? или этот модуль надо сначала на комп скачать? Модератор: Тема перенесена из форума "Программирование". ... |
| 04.10.2018, 10:11:18 |
Имя пакета было не правельное. поменял на PyMySQL - работает. Но как pip бновить всё ещё не понятно ... |
| 06.10.2018, 12:51:51 |
start [/forum/topic.php?desktop=1&fid=23&tid=1460152]: |
74ms |
45ms |
| others: | 193ms |
| total: | 359ms |
