powered by simpleCommunicator - 2.0.53     © 2025 Programmizd 02
Форумы / PHP, Perl, Python [игнор отключен] [закрыт для гостей] / Ошибка "The GET method is not supported for this route" при PHP Laravel Sanctum
2 сообщений из 2, страница 1 из 1
    #40093708
RsbAstana
Всем привет!
У меня в проекте (Laravel 8 с установленным Laravel Sanctum, PHP 7.3) выходит
ошибка "The GET method is not supported for this route" при использовании Laravel Sanctum.
Api.php:
Код: php
1.
Route::middleware('auth:sanctum')->get('/v1/cabinet/user', [CabinetController::class, 'userdata']);
CabinetController:
Код: php
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
<?php
namespace App\Http\Controllers;
use Illuminate\Http\Request;
class CabinetController extends Controller
    public function userdata(Request $request)
        return $request->user();
    public function logout()
        if (Auth()->check()) {
            Auth::user()->token()->delete();
            return response([
                'message' => 'Пользователь разлогинен',
            ], 200);
Код: php
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
Symfony\Component\HttpKernel\Exception\MethodNotAllowedHttpException: The GET method is not supported for this route. Supported methods: POST. in file C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Routing\AbstractRouteCollection.php on line 117
#0 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Routing\AbstractRouteCollection.php(103): Illuminate\Routing\AbstractRouteCollection->methodNotAllowed(Array, 'GET')
#1 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Routing\AbstractRouteCollection.php(40): Illuminate\Routing\AbstractRouteCollection->getRouteForMethods(Object(Illuminate\Http\Request), Array)
#2 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Routing\CompiledRouteCollection.php(144): Illuminate\Routing\AbstractRouteCollection->handleMatchedRoute(Object(Illuminate\Http\Request), NULL)
#3 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Routing\Router.php(647): Illuminate\Routing\CompiledRouteCollection->match(Object(Illuminate\Http\Request))
#4 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Routing\Router.php(636): Illuminate\Routing\Router->findRoute(Object(Illuminate\Http\Request))
#5 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Routing\Router.php(625): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#6 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Foundation\Http\Kernel.php(166): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#7 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(128): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request))
#8 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#9 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#10 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle(Object(Illuminate\Http\Request), Object(Closure))
#11 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#12 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#13 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TrimStrings->handle(Object(Illuminate\Http\Request), Object(Closure))
#14 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#15 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle(Object(Illuminate\Http\Request), Object(Closure))
#16 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#17 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(167): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle(Object(Illuminate\Http\Request), Object(Closure))
#18 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\fruitcake\laravel-cors\src\HandleCors.php(52): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#19 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(167): Fruitcake\Cors\HandleCors->handle(Object(Illuminate\Http\Request), Object(Closure))
#20 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Http\Middleware\TrustProxies.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#21 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(167): Illuminate\Http\Middleware\TrustProxies->handle(Object(Illuminate\Http\Request), Object(Closure))
#22 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#23 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Foundation\Http\Kernel.php(141): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#24 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\vendor\laravel\framework\src\Illuminate\Foundation\Http\Kernel.php(110): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#25 C:\Users\HP\Desktop\RS\OSPanel\domains\rick_and_morty_backend\public\index.php(52): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#26 {main}
Как исправить?
    #40093873
RsbAstana
Нашел решение:
Я добавлял токен, только брал его из таблицы personal_access_tokens,
а надо было тот который возвращает роут /login.
На видео в конце показано как добавлять токен при роуте:
https://www.youtube.com/watch?v=PcZmv1AOfFo
