IE авто загрузка javascript функции
Нашел интересную библиотек Canvas с поддержкой и FF, и IE. Пример работает! Но, он активится по нажатию кнопки. Как его заставить работать при загрузке страницы в FF и IE. с.м. кому интересно ниже iecanvas.htc автор /*----------------------------------------------------------------------------\ | IE Canvas 1.0 | |-----------------------------------------------------------------------------| | Created by Emil A Eklund | | (http://eae.net/contact/emil) | |-----------------------------------------------------------------------------| | Implementation of the canvas API for Internet Explorer. Uses VML. | |-----------------------------------------------------------------------------| | Copyright (c) 2005 Emil A Eklund | |- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -| | This program is free software; you can redistribute it and/or modify it | | under the terms of the MIT License. | |- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -| | Permission is hereby granted, free of charge, to any person obtaining a | | copy of this software and associated documentation files (the "Software"), | | to deal in the Software without restriction, including without limitation | | the rights to use, copy, modify, merge, publish, distribute, sublicense, | | and/or sell copies of the Software, and to permit persons to whom the | | Software is furnished to do so, subject to the following conditions: | | The above copyright notice and this permission notice shall be included in | | all copies or substantial portions of the Software. | |- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -| | THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR | | IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, | | FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE | | AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER | | LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING | | FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER | | DEALINGS IN THE SOFTWARE. | |- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -| | http://eae.net/license/mit | |-----------------------------------------------------------------------------| | Dependencies: canvas.js - For initialization of canvas elements | |-----------------------------------------------------------------------------| | 2005-12-27 | Work started. | | 2005-12-29 | First version posted. | | 2006-01-03 | Fixed bug in moveTo and lineTo, arguments where not converted | | | to int which could cause IE to enter an endless loop. Disabled | | | antalias for fillRect to better comply with the Mozilla, Opera | | | and possibly Safari implementations where using fillRect is | | | about the only way to raw non antialiased lines. | |-----------------------------------------------------------------------------| | Created 2005-12-27 | All changes are in the log above. | Updated 2006-01-03 | \----------------------------------------------------------------------------*/ <public:component> <public:method name="getContext" /> <public:attach event="oncontentready" onevent="initCanvas()"/> </public:component> <script language="JScript"> function getContext() { return element.context; } function initCanvas() { element.context = new IECanvasContext(); element.style.position = 'relative'; element.style.display = 'block'; element.style.overflow = 'hidden'; } function IECanvasContext() { this.fillStyle = 'black'; this.globalAlpha = 1.0; this.globalCompositeOperation = ''; this.lineCap = ''; this.lineJoin = ''; this.lineWidth = '0'; this.miterLimit = ''; this.shadowBlur = ''; this.shadowColor = ''; this.shadowOffsetX = ''; this.shadowOffsetY = ''; this.strokeStyle = 'black'; this._path = ''; this._stateStack = new Array(); this._offsetX = 0; this._offsetY = 0; this._rotation = 0; }; IECanvasContext.prototype.save = function() { var o; o = new Object(); this._copyState(this, o); this._stateStack.push(o); }; IECanvasContext.prototype.restore = function() { var o, n; n = this._stateStack.length - 1; if (n < 0) { return; } o = this._stateStack[n]; this._copyState(o, this); this._stateStack.splice(n, 1); }; IECanvasContext.prototype._copyState = function(oFrom, oTo) { oTo.fillStyle = oFrom.fillStyle; oTo.lineCap = oFrom.lineCap; oTo.lineJoin = oFrom.lineJoin; oTo.lineWidth = oFrom.lineWidth; oTo.miterLimit = oFrom.miterLimit; oTo.shadowBlur = oFrom.shadowBlur; oTo.shadowColor = oFrom.shadowColor; oTo.shadowOffsetX = oFrom.shadowOffsetX; oTo.shadowOffsetY = oFrom.shadowOffsetY; oTo._offsetX = oFrom._offsetX; oTo._offsetY = oFrom._offsetY; oTo._rotation = oFrom._rotation; }; IECanvasContext.prototype.rotate = function(r) { var MAX = Math.PI * 2; this._rotation += r; while (this._rotation > MAX) { this._rotation = MAX - this._rotation; } }; IECanvasContext.prototype.scale = function() { }; IECanvasContext.prototype.translate = function(x, y) { this._offsetX += x; this._offsetY += y; }; IECanvasContext.prototype.bezierCurveTo = function(cp1x, cp1y, cp2x, cp2y, x, y) { if (this._path) { this._path += ' '; } this._path += 'qb' + cp1x + ',' + cp1y + ',' + cp2x + ',' + cp2y + ',' + x + ',' + y; }; IECanvasContext.prototype.clip = function() { }; IECanvasContext.prototype.beginPath = function() { this._path = ''; }; IECanvasContext.prototype.closePath = function() { if (this._path) { this._path += ' '; } this._path += 'x'; }; IECanvasContext.prototype.lineTo = function(x, y) { if (this._path) { this._path += ' '; } this._path += 'l' + parseInt(x) + ',' + parseInt(y); }; IECanvasContext.prototype.moveTo = function(x, y) { if (this._path) { this._path += ' '; } this._path += 'm' + parseInt(x) + ',' + parseInt(y); }; IECanvasContext.prototype.stroke = function() { var o, s, cosa, sina, cx, cy, x, y; if (!this._path) { return; } this._path += ' e'; o = element.ownerDocument.createElement('v:shape'); o.fillColor = 'none'; o.filled = false; o.strokeColor = this.strokeStyle; o.stroked = true; // o.weight = this.lineWidth; o.strokeweight = this.lineWidth; o.coordsize = element.offsetWidth + ',' + element.offsetHeight; o.style.position = 'absolute'; o.style.left = this._offsetX; o.style.top = this._offsetY; o.style.width = element.offsetWidth; o.style.height = element.offsetHeight; o.path = this._path; s = element.ownerDocument.createElement('v:stroke'); s.opacity = this.globalAlpha; o.appendChild(s); if (this._rotation) { r = element.ownerDocument.createElement('v:group'); r.style.position = 'absolute'; r.style.left = 0; r.style.top = 0; r.style.width = element.offsetWidth; r.style.height = element.offsetHeight; r.coordsize = o.coordsize; r.style.rotation = Math.round((this._rotation * 180) / Math.PI); r.style.rotationCenter = '0,0'; r.appendChild(o); element.appendChild(r); cosa = Math.cos(this._rotation); sina = Math.sin(this._rotation); cx = element.offsetWidth / 2; cy = element.offsetHeight / 2; x = ( cx*(1-cosa) + cy*sina); y = (-cx*sina + cy*(1-cosa)); r.style.left = x * -1; r.style.top = y * -1; } else { element.appendChild(o); } }; IECanvasContext.prototype.fill = function() { var o, f, r; if (!this._path) { return; } this._path += ' e'; o = element.ownerDocument.createElement('v:shape'); o.fillColor = this.fillStyle; o.strokeColor = this.strokeStyle; o.stroked = false; o.weight = this.lineWidth; o.coordsize = element.offsetWidth + ',' + element.offsetHeight; o.style.position = 'absolute'; o.style.left = this._offsetX; o.style.top = this._offsetY; o.style.width = element.offsetWidth; o.style.height = element.offsetHeight; o.path = this._path; f = element.ownerDocument.createElement('v:fill'); f.opacity = this.globalAlpha; o.appendChild(f); if (this._rotation) { r = element.ownerDocument.createElement('v:group'); r.style.position = 'absolute'; r.style.left = 0; r.style.top = 0; r.style.width = element.offsetWidth; r.style.height = element.offsetHeight; r.coordsize = o.coordsize; r.style.rotation = Math.round((this._rotation * 180) / Math.PI); r.style.rotationCenter = '0,0'; r.appendChild(o); element.appendChild(r); cosa = Math.cos(this._rotation); sina = Math.sin(this._rotation); cx = (element.offsetWidth) / 2; cy = (element.offsetHeight) / 2; x = ( cx*(1-cosa) + cy*sina); y = (-cx*sina + cy*(1-cosa)); r.style.left = x * -1; r.style.top = y * -1; } else { element.appendChild(o); } }; IECanvasContext.prototype.arcTo = function(x1, y1, x2, y2, radius) { // not implemented in gecko, not implemented here }; IECanvasContext.prototype.quadraticCurveTo = function(cpx, cpy, x, y) { if (this._path) { this._path += ' '; } this._path += 'qb' + cpx + ',' + cpy + ',' + x + ',' + y; }; IECanvasContext.prototype.arc = function(x, y, radius, startAngle, endAngle, clockwise) { var xi, yi, x1, y1, x2, y2, x3, y3, x4, y4; if (this._path) { this._path += ' '; } xi = parseFloat(x); yi = parseFloat(y); x1 = xi - radius; y1 = yi - radius; x2 = xi + radius; y2 = yi + radius; x3 = xi + (Math.cos(startAngle) * radius); y3 = yi + (Math.sin(startAngle) * radius); x4 = xi + (Math.cos(endAngle) * radius); y4 = yi + (Math.sin(endAngle) * radius); x3 = Math.round(x3); y3 = Math.round(y3); x4 = Math.round(x4); y4 = Math.round(y4); this._path += 'ar' + x1 + ',' + y1 + ',' + x2 + ',' + y2 + ',' + x3 + ',' + y3 + ',' + x4 + ',' + y4; }; IECanvasContext.prototype.rect = function(x, y, w, h) { var x1, y1, x2, y2; x2 = x + w; y2 = y + h; x1 = Math.round(x); y1 = Math.round(y); x2 = Math.round(x2); y2 = Math.round(y2); this._path += 'm' + x1 + ',' + y1; this._path += ' l' + x2 + ',' + y1; this._path += ' l' + x2 + ',' + y2; this._path += ' l' + x1 + ',' + y2; this._path += ' x' }; IECanvasContext.prototype.strokeRect = function(x, y, w, h) { var o, s; o = element.ownerDocument.createElement('v:rect'); o.fillColor = 'none'; o.filled = false; o.strokeColor = this.strokeStyle; o.stroked = true; o.weight = this.lineWidth; o.style.position = 'absolute'; o.style.left = this._offsetX + x; o.style.top = this._offsetY + y; o.style.width = w; o.style.height = h; s = element.ownerDocument.createElement('v:fill'); s.opacity = this.globalAlpha; o.appendChild(s); element.appendChild(o); }; IECanvasContext.prototype.clearRect = function(x, y, w, h) { }; IECanvasContext.prototype.fillRect = function(x, y, w, h) { var o, f; if ((x == 0) && (y == 0) && (w == element.offsetWidth) && (h == element.offsetHeight) && (this._offsetX == 0) && (this._offsetY == 0) && (this.globalAlpha == 1)) { while (element.firstChild) { element.removeChild(element.lastChild); } } o = element.ownerDocument.createElement('v:rect'); o.fillColor = this.fillStyle; o.filled = true; o.stroked = false; o.weight = 0; o.style.position = 'absolute'; o.style.left = this._offsetX + x; o.style.top = this._offsetY + y; o.style.width = w; o.style.height = h; o.style.antialias = 'false'; f = element.ownerDocument.createElement('v:fill'); f.opacity = this.globalAlpha; o.appendChild(f); element.appendChild(o); }; IECanvasContext.prototype.addColorStop = function() { }; IECanvasContext.prototype.createLinearGradient = function() { }; IECanvasContext.prototype.createPattern = function() { }; IECanvasContext.prototype.createRadialGradient = function() { }; IECanvasContext.prototype.drawImage = function() { }; IECanvasContext.prototype.drawImageFromRect = function() { }; </script> iecanvas.js автор /*----------------------------------------------------------------------------\ | IE Canvas 1.0 | | Emulation Initialization Script | |-----------------------------------------------------------------------------| | Created by Emil A Eklund | | (http://eae.net/contact/emil) | |-----------------------------------------------------------------------------| | Implementation of the canvas API for Internet Explorer. Uses VML. | |-----------------------------------------------------------------------------| | Copyright (c) 2005 Emil A Eklund | |- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -| | This program is free software; you can redistribute it and/or modify it | | under the terms of the MIT License. | |- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -| | Permission is hereby granted, free of charge, to any person obtaining a | | copy of this software and associated documentation files (the "Software"), | | to deal in the Software without restriction, including without limitation | | the rights to use, copy, modify, merge, publish, distribute, sublicense, | | and/or sell copies of the Software, and to permit persons to whom the | | Software is furnished to do so, subject to the following conditions: | | The above copyright notice and this permission notice shall be included in | | all copies or substantial portions of the Software. | |- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -| | THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR | | IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, | | FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE | | AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER | | LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING | | FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER | | DEALINGS IN THE SOFTWARE. | |- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -| | http://eae.net/license/mit | |-----------------------------------------------------------------------------| | Dependencies: canvas.htc - Actual implementation | |-----------------------------------------------------------------------------| | 2005-12-27 | Work started. | | 2005-12-29 | First version posted. | | 2006-01-03 | Added htcFile argument to ieCanvasInit method. | |-----------------------------------------------------------------------------| | Created 2005-12-27 | All changes are in the log above. | Updated 2006-01-03 | \----------------------------------------------------------------------------*/ function ieCanvasInit(htcFile) { var ie, opera, a, nodes, i, oVml, oStyle, newNode; /* * Only proceed if browser is IE 6 or later (as all other major browsers * support canvas out of the box there is no need to try to emulate for * them, and besides only IE supports VML anyway. */ ie = navigator.appVersion.match(/MSIE (\d\.\d)/); opera = (navigator.userAgent.toLowerCase().indexOf("opera") != -1); if ((!ie) || (ie[1] < 6) || (opera)) { return; } /* * Recreate elements, as there is no canvas tag in HTML * The canvas tag is replaced by a new one created using createElement, * even though the same tag name is given the generated tag is slightly * different, it's created prefixed with a XML namespace declaration * <?XML:NAMESPACE PREFIX ="PUBLIC" NS="URN:COMPONENT" /> */ nodes = document.getElementsByTagName('canvas'); for (i = 0; i < nodes.length; i++) { node = nodes ; if (node.getContext) { return; } // Other implementation, abort newNode = document.createElement('canvas'); newNode.id = node.id; newNode.style.width = node.width; newNode.style.height = node.height; node.parentNode.replaceChild(newNode, node); } /* Add VML includes and namespace */ document.namespaces.add("v"); oVml = document.createElement('object'); oVml.id = 'VMLRender'; oVml.codebase = 'vgx.dll'; oVml.classid = 'CLSID:10072CEC-8CC1-11D1-986E-00A0C955B42E'; document.body.appendChild(oVml); /* Add required css rules */ if ((!htcFile) || (htcFile == '')) { htcFile = 'iecanvas.htc'; } oStyle = document.createStyleSheet(); oStyle.addRule('canvas', "behavior: url('" + htcFile + "');"); oStyle.addRule('v\\:*', "behavior: url(#VMLRender);"); } demo.html автор <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml11.dtd"> <HTML> <head> <title>Canvas in IE</title> <script type="text/javascript" src="iecanvas.js"></script> </head> <body> <h1>Canvas Demo</h1> <canvas id="test2" width="300" height="300"></canvas> <button onclick="draw();">draw</button> Uses some of the examples from Mozilla's <a href="http://developer.mozilla.org/en/docs/Canvas_tutorial">Canvas tutorial</a>. </body> <script> window.onload = function() { ieCanvasInit(); } function draw() { var canvas = document.getElementById('test2'); var ctx = canvas.getContext('2d'); // ********************************************************** ctx.fillStyle = "red"; ctx.beginPath(); ctx.moveTo(300, 300); ctx.lineTo(150, 150); ctx.quadraticCurveTo(60, 70, 70, 150); ctx.lineTo(300, 300); ctx.fill(); // ********************************************************** ctx.fillStyle = 'green'; ctx.fillRect(5, 5, 25, 25); ctx.strokeStyle = 'red'; ctx.strokeRect(20, 20, 25, 25); ctx.beginPath(); ctx.lineWidth = 1; ctx.moveTo(1,1); ctx.lineTo(80,80); ctx.lineTo(100,20); ctx.closePath(); ctx.stroke(); ctx.strokeStyle = 'blue'; ctx.fillStyle = 'black'; ctx.beginPath(); ctx.moveTo(120,50); ctx.lineTo(150,70); ctx.lineTo(150,50); ctx.lineTo(350,150); ctx.quadraticCurveTo(150, 150, 80, 80); ctx.bezierCurveTo(85,25,75,37,75,40); ctx.closePath(); ctx.fill(); ctx.beginPath(); ctx.rect(180,180,80,80); ctx.rect(200,200,80,80); ctx.stroke(); ctx.beginPath(); ctx.arc(200, 100, 20, 0, Math.PI, true); ctx.stroke(); ctx.save(); ctx.translate(150, 0); ctx.fillRect(0,0,150,150); ctx.fillStyle = '#09F' ctx.fillRect(15,15,120,120); ctx.fillStyle = '#FFF' ctx.globalAlpha = 0.5; ctx.fillRect(30,30,90,90); ctx.fillRect(45,45,60,60); ctx.fillRect(60,60,30,30); ctx.restore(); ctx.save(); ctx.translate(10, 140); ctx.fillStyle = '#FD0'; ctx.fillRect(0,0,75,75); ctx.fillStyle = '#6C0'; ctx.fillRect(75,0,75,75); ctx.fillStyle = '#09F)'; ctx.fillRect(0,75,75,75); ctx.fillStyle = '#F30'; ctx.fillRect(75,75,75,75); ctx.fillStyle = '#FFF'; ctx.globalAlpha = 0.2; for (i=0;i<7;i++){ ctx.beginPath(); ctx.arc(75, 75, 10+(10*i), 0, Math.PI*2, true); ctx.fill(); } ctx.restore(); ctx.beginPath(); ctx.arc(200, 200, 20, 0, Math.PI*2, true); ctx.stroke(); ctx.save(); ctx.globalAlpha = 1.0; //ctx.translate(75,75); for (i=1;i<6;i++){ // Loop through rings (from inside to out) ctx.save(); ctx.fillStyle = 'rgb('+(51*i)+','+(255-51*i)+',255)'; for (j=0;j<i*6;j++){ // draw individual dots ctx.rotate(Math.PI*2/(i*6)); ctx.beginPath(); //ctx.arc(0,i*12.5,5,0,Math.PI*2,true); ctx.rect(0,i*12.5,5,5); ctx.fill(); } ctx.restore(); } ctx.restore(); } </script> </html> ... |
| 29.11.2006, 00:01 |
Кстати, нет у кого русского тотариала по Canvas ... |
| 29.11.2006, 00:02 |
Функция draw() вызывается по клику на кнопке. А кто запрещает вызвать её так: Код: plaintext 1. ... |
| 29.11.2006, 10:51 |
SkyLightФункция draw() вызывается по клику на кнопке. А кто запрещает вызвать её так: Код: plaintext 1. Небольшая поправка - в <body onload="функция" у меня уже есть. Могу я поставить несколько функций скажем через запятую ... |
| 29.11.2006, 11:25 |
HunterNomad Небольшая поправка - в <body onload="функция" у меня уже есть. Могу я поставить несколько функций скажем через запятую Ты почти угадал. <body onload="load();draw();killsystem();"> и т.д. ... |
| 29.11.2006, 11:35 |
HunterNomadКстати, нет у кого русского тотариала по Canvas Ты чертовски прав =) ... |
| 29.11.2006, 11:37 |
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. Например: Код: plaintext 1. 2. 3. При этом если на событие уже повешена функция, то она не затирается. ... |
| 29.11.2006, 11:39 |
start [/forum/search_topic.php?author=reiler&author_mode=last_posts&do_search=1]: |
55ms |
30ms |
| others: | 379ms |
| total: | 504ms |
