float или хз
Всем доброго времени суток. Вот код: #left { background-color: rgb(57,57,57); BACKGROUND-IMAGE: url(news_logo.jpg); BACKGROUND-POSITION: 25px 0px; BACKGROUND-REPEAT: no-repeat; MARGIN-TOP: 15px; WIDTH: 255px; HEIGHT: 100%; border-style:dashed; border-width: 1px; border-color: rgb(57,57,57); float: left } #right { WIDTH: 1px; HEIGHT: 100%; float: right; border-style:dashed } #main { BACKGROUND-POSITION: 25px top; BACKGROUND-IMAGE: url(records_logo.jpg); background-color: rgb(57,57,57); BACKGROUND-REPEAT: no-repeat; MARGIN: 15px 0px; HEIGHT: 490px; border-style:dashed; width:100% } ............................ <DIV id=left> <DIV class="news_block first"> <P class=news_bolck_header>March 31, 2003<BR><FONT color=white>Create once, Share Anyware</FONT></P> <P class=news_bolck_text>Seminar OnDemand shows the best way to electronically distribute Microsoft Office documents that look exactly like your original, regardless of the recipient's hardware or software. </P> </DIV> <DIV class=news_block> <P class=news_bolck_header>March 31, 2003<BR><FONT color=white>Beyond PDF Creation</FONT></P> <P class=news_bolck_text>Seminar OnDemand shows the best way to electronically distribute Microsoft Office documents that look exactly like your original, regardless of the recipient's hardware or software. </P> </DIV> <DIV class="news_block last"> <P class=news_bolck_header>March 31, 2003<BR><FONT color=white>Whach You See Is What They Get</FONT></P> <P class=news_bolck_text>Seminar OnDemand shows the best way to electronically distribute Microsoft Office documents that look exactly like your original, regardless of the recipient's hardware or software. </P> </DIV> </DIV> <div id=right></div> <DIV id="main"> <DIV id=main_content> <DIV id=main_add> <DIV id=main_add_up> <img src="treug.jpg" id="treug"><i class=news_bolck_header style="font-style: normal">March 31, 2003<i> </DIV> <DIV id=main_add_middle> <p class="news_bolck_text" style="margin-top:5px">New Release!</p> <p class="news_bolck_text">ToykoDawn Records finnaly made the debut. 1st EP/CD release is now available in the shops</p> </DIV> <DIV id=main_add_bottom><A href="#" id="read_more"> Read More ></A></DIV> </DIV> </DIV> </DIV> В результате получается наслойка слоя left на main. Файл прикрепляю. Первый раз столкнулся с таким. Как быть? Заранее, спасибо. ... |
| 14.05.2007, 17:07 |
float или хз
Из скрина ничего не понятно ;) Попробую протелепатировать: У тебя 2 плавающих элемента - right и left. Я так понял, что они у тебя должны располагаться в одной горизонтали. У тебя же left вытолкнут right'ом на main. Для того, чтобы они шли в одной горизонтали, нужно сначала вписывать правый флоат, а затем левый. В коде поменяй местами left и right. Код: plaintext 1. 2. $50 + $100 бесплатно для игры на PartyPoker.com ... |
| 14.05.2007, 17:28 |
start [/forum/topic.php?desktop=1&fid=22&tid=1458275]: |
39ms |
32ms |
| others: | 203ms |
| total: | 313ms |
