bower EINVEND Decomposed endpoint must have a name
Добрый день! Пытаюсь инициализировать bower.json, но безуспешно, в самом низу сообщение, что оно означает? user@ubuntu:/var/www/test/current$ bower install bower ENOENT No bower.json present user@ubuntu:/var/www/test/current$ bower init bower ENOINT Register requires an interactive shell Additional error details: Note that you can manually force an interactive shell with --config.interactive user@ubuntu:/var/www/test/current$ bower init --config.interactive ? name test_pro ? description desc ? main file index.html ? what types of modules does this package expose? ? keywords ? authors Admin ? license MIT ? homepage ? set currently installed components as dependencies? Yes ? add commonly ignored files to ignore list? Yes ? would you like to mark this package as private which prevents it from being accidentally published to the registry? Yes bower EINVEND Decomposed endpoint must have a name ... |
| 03.02.2016, 11:52 |
start [/forum/topic.php?desktop=1&fid=22&tid=1445454]: |
146ms |
36ms |
| others: | 249ms |
| total: | 471ms |
