Javascript:; problem in Firefox. The window won't open.
Hi, Whenever I click on a link that uses the javascript:; function to open a window, it won't open. So if I click on a [?] next to something and it wants to use javascript:; to open it, it doesn't open. When I close FireFox, the proccess is still running. Then if I want to open a new window, I usually have to end that process or it won't open. If it does its like in 5 minutes. I really would like my javascript:; problem fixed first Any help will be apprecited. I didn't find the right solution from the Internet. References: http://forums.mozillazine.org/viewtopic.php?f=38&t=405606 Creative production service Thank you. ... |
| 07.05.2018, 16:23:32 |
start [/forum/topic.php?desktop=1&fid=22&tid=1444194]: |
154ms |
32ms |
| others: | 194ms |
| total: | 426ms |
