Как устранить ошибку Uncaught TypeError: .forEach is not a function
Здравствуйте! Подскажите, пожалуйста, из-за чего такая ошибка?: Uncaught TypeError: tours_list.forEach is not a function Код: javascript 1. 2. 3. 4. 5. ... |
| 17.05.2020, 16:37 |
отладка по шагам знакома? console.log() ? console.log(tours_list); ?? ... |
| 17.05.2020, 18:54 |
https://developer.mozilla.org/en-US/docs/Web/API/NodeList Although NodeList is not an Array, it is possible to iterate over it with forEach(). It can also be converted to a real Array using Array.from(). However, some older browsers have not implemented NodeList.forEach() nor Array.from(). This can be circumvented by using Array.prototype.forEach() — see this document's Example . ... |
| 18.05.2020, 08:50 |
start [/forum/topic.php?desktop=1&fid=22&tid=1443463]: |
170ms |
43ms |
| others: | 246ms |
| total: | 499ms |
