Data Grid set column Format
Hello to all Problem I get from table date column in same format. Question: How to set format to date column in running time Getting format mm/dd/yyyy and must convert to dd/mm/yyyy format Thank you ... |
| 09.01.2004, 23:59 |
А разве в израиле не на русском говорят ??;)) In datagrid column style you mast find "Format". DataGrid\TableStyles\GridColumnStyles\Format DataGridTextBoxColumn.Format Property ... |
| 10.01.2004, 15:00 |
To : ctmike И на украинском тоже ... |
| 10.01.2004, 18:45 |
start [/forum/topic.php?desktop=1&fid=20&tid=1439699]: |
148ms |
48ms |
| others: | 243ms |
| total: | 489ms |
