Как поставить Visual Studio?
Можно ли поставить VS DOT.NET на ME? ... |
| 01.03.2004, 15:27 |
Не советую! Лучше на 2000 или XP Proffessional ... |
| 01.03.2004, 15:34 |
Понимаю, что на 2000 или XP лучше, но если кто то знает отзовитесь!!! ... |
| 01.03.2004, 16:20 |
System Requirements for Visual Studio .NET Minimum Requirements Processor 450-megahertz (MHz) Pentium II-class processor, 600-MHz Pentium III-class processor recommended Operating System Visual Studio .NET 2003 can be installed onto any of the following systems: Microsoft Windows® Server 2003 Windows XP Professional Windows XP Home Edition¹ Windows 2000 Professional (SP3 or later required for installation) Windows 2000 Server (SP3 or later required for installation) Applications can be deployed onto the following systems²: Windows Server 2003 Windows XP Professional Windows XP Home Edition Windows 2000 (Service Pack 2 recommended) Windows Millennium Edition (Windows Me) Windows 98 Microsoft Windows NT® 4.0 (Service Pack 6a required) Windows 95 (using Microsoft Visual C++® .NET) Memory Windows Server 2003: 160 megabytes (MB) of RAM Windows XP Professional: 160 MB of RAM Windows XP Home Edition: 96 MB of RAM Windows 2000 Professional: 96 MB of RAM Windows 2000 Server: 192 MB of RAM Hard Disk 900 MB of available space required on system drive, 3.3 gigabytes (GB) of available space required on installation drive Additional 1.9 GB of available space required for optional MSDN Library documentation Drive CD-ROM or DVD-ROM drive Display Super VGA (1024 x 768) or higher-resolution display with 256 colors Mouse Microsoft Mouse or compatible pointing device ¹ Limited functionality. Visual Studio .NET 2003 does not support creating ASP.NET Web applications or ASP.NET XML Web services when using Windows XP Home Edition. ² ASP.NET Web applications and XML Web services can only be hosted on Windows XP Professional, Windows 2000, and Windows Server 2003. взято здесь http://www.codeproject.com/store/requirements.asp ... |
| 01.03.2004, 16:47 |
start [/forum/topic.php?desktop=1&fid=20&tid=1439466]: |
43ms |
38ms |
| others: | 233ms |
| total: | 353ms |
