Status Bar
помогите разобраться почему в методе private void button1_Click(object sender, System.EventArgs e) показывается визуальное изменение StatusBar1 а в методе public void TestMetod() не показывается ? using System; using System.Drawing; using System.Collections; using System.ComponentModel; using System.Windows.Forms; using System.Data; namespace WindowsApplication2 { public class Form1 : System.Windows.Forms.Form { private System.Windows.Forms.Button button1; protected System.Windows.Forms.StatusBar statusBar1; protected System.ComponentModel.Container components = null; public Form1() { InitializeComponent(); } protected override void Dispose( bool disposing ) { if( disposing ) { if (components != null) { components.Dispose(); } } base.Dispose( disposing ); } protected void InitializeComponent() { this.button1 = new System.Windows.Forms.Button(); this.statusBar1 = new System.Windows.Forms.StatusBar(); this.SuspendLayout(); this.button1.Location = new System.Drawing.Point(72, 128); this.button1.Name = "button1"; this.button1.Size = new System.Drawing.Size(96, 24); this.button1.TabIndex = 0; this.button1.Text = "button1"; this.button1.Click += new System.EventHandler(this.button1_Click); this.statusBar1.Location = new System.Drawing.Point(0, 251); this.statusBar1.Name = "statusBar1"; this.statusBar1.Size = new System.Drawing.Size(292, 22); this.statusBar1.TabIndex = 1; this.statusBar1.Text = "statusBar1"; this.AutoScaleBaseSize = new System.Drawing.Size(5, 13); this.ClientSize = new System.Drawing.Size(292, 273); this.Controls.AddRange(new System.Windows.Forms.Control[] { this.statusBar1, this.button1}); this.Name = "Form1"; this.Text = "Form1"; this.ResumeLayout(false); } [STAThread] static void Main() { Application.Run(new Form1()); } private void button1_Click(object sender, System.EventArgs e) { //Здесь изменяется for (int i=0;i<=10000;i++)statusBar1.Text = i.ToString(); Test qwe = new Test(); // а здесь нет qwe.TestMetod(); } } public class Test:Form1{ public void TestMetod(){ for (int i=0;i<=10000;i++)statusBar1.Text = i.ToString(); } } } ... |
| 27.03.2004, 10:12 |
Status Bar
почему не выполняется? выполняется, но в другой форме! ты же создаешь другой экземпляр формы (наследование от Form1 ещё не говорит о том, что будут выполняться методы базового класса) попробуй поставить перед qwe.TestMetod(); вызов qwe.Show(); и ты убедишься в этом ... |
| 29.03.2004, 22:22 |
start [/forum/topic.php?desktop=1&fid=20&tid=1439367]: |
58ms |
50ms |
| others: | 278ms |
| total: | 437ms |
