A failure occurred writing to the resources file
Вот такая ошибка: A failure occurred writing to the resources file. Системе не удается найти указанный путь. В справке: The .resources output file could not be written by the project system. As part of preparing resources, the project system will transform XML files with a .resx extension into binary .resources files for the .NET Resource Manager. An operating-system specific reason (if any) will be appended to the end of this message. The file name of the .resx file will also be appended. Какие мысли что это может быть... ... |
| 09.07.2004, 15:33 |
start [/forum/topic.php?desktop=1&fid=20&tid=1438860]: |
80ms |
32ms |
| others: | 236ms |
| total: | 399ms |
