сфотографировать экран
Есть задача, сфотографировать экран и сохранить фотку на диск, как это можно сделать? Если только через PInvoke, то какой метод ? ... |
| 23.12.2004, 12:04 |
Actually, there is a Save method on the Image class, and because Bitmap derives from Image, then the Save method should be on there. As for getting a screen shot, I think the best way to do this would be to use the GetDesktopWindow API function (through the P/Invoke layer). Once you have this, create a bitmap with the same dimensions and the color-depth that you want. Then, get the Graphics instance for the bitmap using the static FromImage method on the Graphics class. Finally, call the BitBlt API function to do a copy from the desktop to the bitmap (the handles can be retrieved from the Graphics instances). Hope this helps. -- - Nicholas Paldino [.NET/C# MVP] - nicholas.paldino@exisconsulting.com ... |
| 23.12.2004, 13:20 |
start [/forum/topic.php?desktop=1&fid=20&tid=1437584]: |
56ms |
52ms |
| others: | 211ms |
| total: | 359ms |
