Ado .NET
Command=new OleDbCommand(); Command.CommandText="select * from Patient;"; Command.Connection=OwnerForm.Connection; OwnerForm.Connection.Open(); Adapter=new OleDbDataAdapter(Command); OleDbCommandBuilder cb=new OleDbCommandBuilder(Adapter); Adapter=cb.DataAdapter; ds=new DataSet(); Adapter.Fill(ds); gridEX.DataSource=ds; gridEX.RootTable.Columns["CardNoColumn"].DataMember="CardNo"; gridEX.RootTable.Columns["NameColumn"].DataMember="FName"; string s=Adapter.DeleteCommand.CommandText; Возвращает null Что не правильно? C ув. Tors ... |
| 09.02.2005, 18:14 |
Ado .NET
Сорри не в тот форум влез C ув. Tors ... |
| 09.02.2005, 18:23 |
start [/forum/topic.php?desktop=1&fid=20&tid=1437312]: |
71ms |
32ms |
| others: | 241ms |
| total: | 383ms |
