C# ошибка. Ссылка на объект не указывает на экземпляр объекта.
Что делать при запуске скомпелированой версии выдаёт ошибку { public partial class Form1 : Form { public Form1() { InitializeComponent(); } private void Form1_Load(object sender, EventArgs e) { Browser1.Navigate(" http://google.ru/"); Adress1.Text = Browser1.Url.ToString(); } private void Relase1_Click(object sender, EventArgs e) { Browser1.Refresh(); } private void Adress1_KeyDown(object sender, KeyEventArgs e) { if (e.KeyCode == Keys.Enter) { Browser1.Navigate(Adress1.Text); Adress1.Text = Browser1.Url.ToString(); } } private void Down1_Click(object sender, EventArgs e) { Browser1.GoBack(); } private void Firsed1_Click(object sender, EventArgs e) { Browser1.GoForward(); } private void Home1_Click(object sender, EventArgs e) { Browser1.Navigate(" http://google.ru/"); } private void Browser1_DocumentCompleted(object sender, WebBrowserDocumentCompletedEventArgs e) { Adress1.Text = Browser1.Url.ToString(); } private void Down2_Click(object sender, EventArgs e) { Browser2.GoBack(); } private void Firsed2_Click(object sender, EventArgs e) { Browser2.GoForward(); } private void Home2_Click(object sender, EventArgs e) { Browser2.Navigate(" http://google.ru/"); } private void Relase2_Click(object sender, EventArgs e) { Browser2.Refresh(); } private void Browser2_DocumentCompleted(object sender, WebBrowserDocumentCompletedEventArgs e) { Adress2.Text = Browser1.Url.ToString(); } private void Dowen3_Click(object sender, EventArgs e) { Browser3.GoBack(); } private void toolStrip2_KeyDown(object sender, KeyEventArgs e) { if (e.KeyCode == Keys.Enter) { Browser1.Navigate(Adress1.Text); Adress1.Text = Browser1.Url.ToString(); } } private void Firsed3_Click(object sender, EventArgs e) { Browser3.GoForward(); } private void Home3_Click(object sender, EventArgs e) { Browser3.Navigate(" http://google.ru"); } private void Relased3_Click(object sender, EventArgs e) { Browser3.Refresh(); } private void Adress3_KeyDown(object sender, KeyEventArgs e) { if (e.KeyCode == Keys.Enter) { Browser1.Navigate(Adress1.Text); Adress1.Text = Browser1.Url.ToString(); } } private void Browser3_DocumentCompleted(object sender, WebBrowserDocumentCompletedEventArgs e) { Adress3.Text = Browser1.Url.ToString(); } } } ... |
| 24.09.2014, 12:25 |
Где сама ошибка-то, нам чо делать нечего сидеть твой проект воссоздавать. Вообще-то в ошибке указано где и студия там останавливается и показывает где, в конце-то концов. ... |
| 24.09.2014, 13:36 |
Virus7216Что делать при запуске скомпелированой версии выдаёт ошибку Запускай нескомпелированную версию ... |
| 24.09.2014, 13:53 |
Вот текст ошибки Подробная информация об использовании оперативной (JIT) отладки вместо данного диалогового окна содержится в конце этого сообщения. ************** Текст исключения ************** System.NullReferenceException: Ссылка на объект не указывает на экземпляр объекта. в браузер_версия_2.Form1.Form1_Load(Object sender, EventArgs e) в System.Windows.Forms.Form.OnLoad(EventArgs e) в System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) в System.Windows.Forms.Control.CreateControl() в System.Windows.Forms.Control.WmShowWindow(Message& m) в System.Windows.Forms.Control.WndProc(Message& m) в System.Windows.Forms.Form.WndProc(Message& m) в System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Загруженные сборки ************** mscorlib Версия сборки: 4.0.0.0 Версия Win32: 4.0.30319.19408 built by: FX451RTMLREL CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll ---------------------------------------- браузер версия 2 Версия сборки: 1.0.0.0 Версия Win32: 1.0.0.0 CodeBase: file:///C:/Users/%D0%92%D0%BE%D0%B2%D0%B0/Desktop/%D0%B1%D1%80%D0%B0%D1%83%D0%B7%D0%B5%D1%80%20%D0%B2%D0%B5%D1%80%D1%81%D0%B8%D1%8F%202.exe ---------------------------------------- System.Windows.Forms Версия сборки: 4.0.0.0 Версия Win32: 4.0.30319.19408 built by: FX451RTMLREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Версия сборки: 4.0.0.0 Версия Win32: 4.0.30319.19408 built by: FX451RTMLREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System Версия сборки: 4.0.0.0 Версия Win32: 4.0.30319.19408 built by: FX451RTMLREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- mscorlib.resources Версия сборки: 4.0.0.0 Версия Win32: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_ru_b77a5c561934e089/mscorlib.resources.dll ---------------------------------------- System.Windows.Forms.resources Версия сборки: 4.0.0.0 Версия Win32: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_ru_b77a5c561934e089/System.Windows.Forms.resources.dll ---------------------------------------- ************** Оперативная отладка (JIT) ************** Для подключения оперативной (JIT) отладки файл .config данного приложения или компьютера (machine.config) должен иметь значение jitDebugging, установленное в секции system.windows.forms. Приложение также должно быть скомпилировано с включенной отладкой. Например: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> При включенной отладке JIT любое необрабатываемое исключение пересылается отладчику JIT, зарегистрированному на данном компьютере, вместо того чтобы обрабатываться данным диалоговым окном. ... |
| 25.09.2014, 09:39 |
start [/forum/topic.php?desktop=1&fid=20&tid=1402431]: |
32ms |
44ms |
| others: | 217ms |
| total: | 334ms |
