vb.net: ошибка при загрузке формы Attempted to read or write.....
На форме есть объекты, созданные в конструкторе и созданные динамически. При загрузке этой формы возникает ошибка: "Текст ошибки"See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt. at System.Drawing.SafeNativeMethods.Gdip.GdipDrawRectangleI(HandleRef graphics, HandleRef pen, Int32 x, Int32 y, Int32 width, Int32 height) at System.Drawing.Graphics.DrawRectangle(Pen pen, Int32 x, Int32 y, Int32 width, Int32 height) at System.Drawing.Graphics.DrawRectangle(Pen pen, Rectangle rect) at System.Windows.Forms.UpDownBase.OnPaint(PaintEventArgs e) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs) at System.Windows.Forms.Control.WmPaint(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.UpDownBase.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3643 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- FreeZvit Assembly Version: 1.11.3.0 Win32 Version: 1.11.3.0 CodeBase: file:///C:/FreeZvit/FreeZvit.exe ---------------------------------------- Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3645 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3644 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3644 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Runtime.Remoting Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3082 (QFE.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll ---------------------------------------- System.Transactions Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll ---------------------------------------- System.EnterpriseServices Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. Если ее пропустить, все работает нормально. И вокруг объекта красная рамка. Но если убираю с формы или ставлю visible=false для NumericUpDown, ошибка не возникает. На машине, где установлен VB и ведется разработка ПО, ошибки нет. Я так понимаю, проблема с прорисовкой данного объекта. ... |
| 04.11.2015, 15:35 |
Если форму, открытую через ошибку, закрыть и снова открыть, она открывается уже без ошибки, то есть в процессе работы программы ошибка возникает только 1 раз за сеанс. И собственно, сам вопрос.... Из-за чего может возникать ошибка? Что можно сделать, чтобы она не возникала? Модератор: Тема перенесена из форума "Visual Basic". ... |
| 04.11.2015, 15:45 |
Bidgo, Если не критично соберите с версией 4.0 фреймворка. Возможно нужны какие нибудь обновления для 2.0, которые фиксят ошибку, т.к. похоже что это ошибка изнутри порождается ... |
| 04.11.2015, 21:05 |
Критично, потому что пользователей программы много. И у многих компы старые. В самом начале разработки была включена функция из .NET3.5, так было куча вопросов, почему не работает. Пришлось переделать под 2.0. В большинстве систем он уже был установлен ранее с какой-нибудь программой. Надо как-то обойти эту ошибку, чтоб она не появлялась. Вернее, чтобы пропускалась без сообщения пользователю. ... |
| 04.11.2015, 21:18 |
BidgoНадо как-то обойти эту ошибку, чтоб она не появлялась. Вернее, чтобы пропускалась без сообщения пользователю. try...catch ... |
| 04.11.2015, 21:35 |
Bidgo, вот тут пишут что аналогичная проблема возникала из-за видеокарты или плохих драйверов для нее. ... |
| 04.11.2015, 21:41 |
Axelerontry...catch Не вариант. Не могу ее поймать. Появляется в момент, когда рисуется обьект. То есть вылазит между событиями Form.Load и Form.Activated Пробовал ставить по умолчанию visible=false, а visible=true прописал в Form.Shown Ошибка вылезла именно в этом месте. Еще нюанс - замечено на некоторых ВинХР, не на всех. На Вин7 или нет ошибки, или пользователи молчат. ... |
| 04.11.2015, 21:59 |
bazile, возможно действительно и-за видеокарты. На 2 машинах точно Radeon. Но такой же счетчик есть на других формах, и они загружаются без ошибок. Попробую поэкспериментировать с размерами и расположением объекта. ... |
| 04.11.2015, 22:09 |
На одной машине проблема решилась обновлением драйверов на видео. На других еще не пробовал. Видеокарта интегрированная IntelG41 Express Chipset, изначально драйвера были установлены с диска. Значит все таки проблема не в программе, но это не сильно радует. Если бы в программе, то можно было исправить/обойти. А советовать пользователям, которые не очень умеют мышь в руках держать, обновлять дрова на видеокарту, не самый лучший ответ.=( ... |
| 05.11.2015, 12:02 |
start [/forum/topic.php?desktop=1&fid=20&tid=1401082]: |
30ms |
35ms |
| others: | 220ms |
| total: | 320ms |
