implicit operator + interface
Смотрим код Код: c# 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. Есть мысли? ... |
| 26.02.2018, 09:15 |
C# Language Specification, §10.10.3 Conversion operators (ближе к концу): User-defined conversions are not allowed to convert from or to interface-types. In particular, this restriction ensures that no user-defined transformations occur when converting to an interface-type, and that a conversion to an interface-type succeeds only if the object being converted actually implements the specified interface-type. - вроде как оно. ... |
| 26.02.2018, 10:09 |
start [/forum/topic.php?desktop=1&fid=20&tid=1399479]: |
146ms |
| others: | 209ms |
| total: | 400ms |
