Не устанавливается VS.NET на Windows 2000 server SP4
Может, из-за SP4? ... |
| 06.08.2003, 10:27:18 |
а что говорит при установке? SP4 не должен мешать :)) ... |
| 06.08.2003, 10:53:32 |
ERROR LOG [08/06/03,11:03:01] setup.exe: ISetupComponent::Pre/Post/Install() failed in ISetupManager::InstallManagerHelper() [08/06/03,11:03:01] setup.exe: Component error string not specified in ISetupManager::AddToActionResultCollection() Конец из setup log ... [08/06/03,11:03:04] vs70uimgr: Entering RunningComponent() method. [08/06/03,11:03:04] Setup.exe: ISetupManager::RunInstallFromList(IP_POSTINSTALL) completed [08/06/03,11:03:04] Setup.exe: ISetupManager::RunInstallLists() completing [08/06/03,11:03:07] vs70uimgr: Entering RunningComponent() method. [08/06/03,11:03:07] VS70pgui: Failed to increment max steps for small progress. Logging as event not error ... noncritical. [08/06/03,11:03:07] Setup.exe: IsRunningUnattended [08/06/03,11:03:07] vs70uimgr: Entering DisplayFinal() method. [08/06/03,11:03:07] Setup.exe: GetGlobalCustomProperty({710A502B-4669-405C-A985-BA21545509BA}) [08/06/03,11:03:07] vs70uimgr: ISetupManager::GetGlobalCustomProperty() failed to find global prop in CUIMgr::GetGlobalProperty() [08/06/03,11:03:07] Setup.exe: GetGlobalCustomProperty({47EAF7DE-458C-4C05-B3E1-82B9C563679B}) [08/06/03,11:03:07] vs70uimgr: ISetupManager::GetGlobalCustomProperty() failed to find global prop in CUIMgr::GetGlobalProperty() [08/06/03,11:03:07] vs70uimgr: Entering Next() method. [08/06/03,11:03:07] VS70pgui: Entered CPageHeaderDynamic::OnShowWindow method [08/06/03,11:03:07] Setup.exe: GetGlobalCustomProperty({710A502B-4669-405C-A985-BA21545509BA}) [08/06/03,11:03:07] VS70pgui: ISetupManager::GetGlobalCustomProperty() failed to find global prop in CFinishPage::GetGlobalProperty() [08/06/03,11:03:07] Setup.exe: AddGlobalCustomProperty [08/06/03,11:03:07] Setup.exe: GetGlobalCustomProperty({5245094D-36FD-4472-8161-FD6CF4E5EDAE}) ... |
| 06.08.2003, 11:03:36 |
Скопировал ошибку в яндекс и сразу нашел ответ: если в названии фирмы, на которую зарегистрирована винда, есть пробелы, то VS не установится. Заменил в реестре и всё стало ОК. Кранты! ... |
| 06.08.2003, 12:04:22 |
start [/forum/topic.php?desktop=1&fid=18&tid=1396331]: |
26ms |
54ms |
61ms |
| others: | 307ms |
| total: | 504ms |
