Dobavit users v Web.config
Privet vsem!!! U menya takoy vopros , u menya est backoffice v kotoriy ya hochu dopuskat tolko zaregestrirovavshihsa ludey v opredelennom statuse , poka chto v ruchnuyu propisivayu v Web.config i vse rabotaet horosho <!-- start admin only --> <location path="admin"> <system.web> <authorization> <allow users="admin" /> <allow users="igor" /> <allow users="igor78" /> <allow users="vlady" /> <allow users="leon" /> <deny users="*" /> </authorization> </system.web> </location> <!-- end admin only --> No hochetsa pri registration esli user so status Dealer chtob srazu ego user name zapisivalsa v Web.config , kak napisat code na C# dlya redaktirovaniya Web.config i dobavleniya users v etu section , ya pitalsa no daet error. Exception Details: System.UnauthorizedAccessException: Access to the path "C:\Inetpub\wwwroot\Store\web.config" is denied. ASP.NET is not authorized to access the requested resource. Consider granting access rights to the resource to the ASP.NET request identity. ASP.NET has a base process identity (typically {MACHINE}\ASPNET on IIS 5 or Network Service on IIS 6) that is used if the application is not impersonating. If the application is impersonating via <identity impersonate="true"/>, the identity will be the anonymous user (typically IUSR_MACHINENAME) or the authenticated request user. To grant ASP.NET write access to a file, right-click the file in Explorer, choose "Properties" and select the Security tab. Click "Add" to add the appropriate user or group. Highlight the ASP.NET account, and check the boxes for the desired access. ... |
| 12.07.2004, 12:32:52 |
не так это делают. <allow roles="Operators" /> а при регистрации добавляешь юзера в роль. ... |
| 12.07.2004, 20:15:32 |
Ok no vse ravno kogda pitayus otredaktirovat Web.config est error access denied. Kak eto oboyti i esli ne trudno napishi pozaluysta code. Spasibo ... |
| 13.07.2004, 00:33:19 |
Rebyata nu chto net otveta :( , situaziya takaya, pri registration v moem site ya dayu status client , Dealer ili Client. Esli Dealer to dolzen ego username propisatsa v Web.config inache on ne smozet zayti v back office na site v section /admin. Pomogite ochen nado. ... |
| 16.07.2004, 12:30:34 |
start [/forum/topic.php?desktop=1&fid=18&tid=1395419]: |
44ms |
70ms |
| others: | 327ms |
| total: | 518ms |
