Календарь
ребят проблемка сайт http://www.rabitadunyasi.info.az/ слева чуть ниже календарь как видите он не работает подключен к базе данных Accses ни ссылки ни преход по месяцам ничерта не работает помошите плиз рвазобратся в чем может быть дело Sub Calendar(cmonth, cyear) If cmonth = "" Then cmonth = Mid(CurrDate,4,2)*1 End If If cyear = "" Then cyear = Mid(CurrDate,7,4)*1 End if months = Array("Yanvar", "Fevral", "Mart", "Aprel", "May", "İyun", "İyul", "Avqust", "Sentyabr", "Oktyabr", "Noyabr", "Dekabr") Set rst = Server.CreateObject("ADODB.Recordset") SQL = "SELECT DISTINCT datest, nomern FROM art WHERE year(datest)="&cyear&" AND month(datest)="&cmonth rst.Open SQL,Conn,3,1 Response.Write "<table border=0 cellpadding=2 cellspacing=0 width=100%>"&chr(13) Response.Write "<tr bgcolor=red align=center>"&chr(13) Response.Write "<td width=14% class=txt><font color=white>Be.</font></td><td width=14% class=txt><font color=white>Ça.</font></td><td width=14% class=txt><font color=white>Ç.</font></td><td width=14% class=txt><font color=white>Ca.</font></td><td width=14% class=txt><font color=white>C.</font></td><td bgcolor=#221786 width=14% class=txt><font color=#ffffff>Ş.</font></td><td bgcolor=#221786 width=14% class=txt><font color=#ffffff>В.</font></td>"&chr(13) Response.Write "</tr>"&chr(13) kalendar = Array (0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0) If weekday("01."&cmonth&"."&cyear) = 1 Then d = 7 Else d = weekday("01."&cmonth&"."&cyear) - 1 End If If cmonth = 1 or cmonth = 3 or cmonth = 5 or cmonth = 7 or cmonth = 8 or cmonth = 10 or cmonth = 12 Then mm = 31 Else mm = 30 End If If cmonth = 2 Then If cyear / 4-int(cyear / 4) = 0 Then mm = 29 Else mm = 28 End If End If j = 0 For i = d - 1 To d + mm j = j + 1 kalendar(i) = j Next i = 0 tt = 0 For k = 1 To int(((d + mm) / 7) + 1) If tt = 1 and kalendar(i) > mm Then Exit For End If Response.Write "<tr align=center>" For j = 1 To 7 If cmonth - month(date) = 0 AND kalendar(i) - day(date) = 0 AND cyear - year(date) = 0 Then Response.Write "<td bgcolor=red class=txt><font size=1>" Else If j = 6 OR j = 7 Then Response.Write "<td class=txt><font size=1 color=#796DE7>" Else Response.Write "<td class=txt><font size=1>" End If End If If kalendar(i) > 0 and kalendar(i) <= mm Then If not rst.eof Then If cmonth - month(rst("datest")) = 0 AND kalendar(i) - day(rst("datest")) = 0 AND cyear - year(rst("datest")) = 0 Then If j = 6 OR j = 7 Then Response.Write "<a href='index.asp?day_="&kalendar(i)&"&month_="&cmonth&"&year_="&cyear&"'><font color=#2B5374><b>"&kalendar(i)&"</a>" Else Response.Write "<a href='index.asp?day_="&kalendar(i)&"&month_="&cmonth&"&year_="&cyear&"'><font color=#000><b>"&kalendar(i)&"</a>" End If If not rst.eof Then rst.MoveNext End If Else Response.Write kalendar(i) End If Else Response.Write kalendar(i) End If tt = 1 End If Response.Write "</TD>"&chr(13) i = i + 1 Next Response.Write "</TR>"&chr(13) j = j + 1 Next Response.Write "<tr>"&chr(13) Response.Write "<td colspan=7 align=center> </td>"&chr(13) Response.Write "</tr>"&chr(13) Response.Write "<tr>"&chr(13) Response.Write "<td colspan=7 align=center>"&chr(13) Response.Write "<form method=get action=index.asp>"&chr(13) Response.Write "<select name=month_ class=txt>"&chr(13) For i=1 to 12 ss = "" if i-cmonth=0 then ss = " selected" end if Response.Write "<option value="&i&" class=table "&ss&">"&months(i-1)&"</option>"&chr(13) Next Response.Write "</select>"&chr(13) Response.Write "<select name=year_ class=txt>"&chr(13) For i=2002 to 2005 ss = "" if i-cyear=0 then ss = " selected" end if Response.Write "<option value="&i&" class=table "&ss&">"&i&"</option>"&chr(13) Next Response.Write "</select><img src=null width=40 height=1><br>"&chr(13) Response.Write "<input type=submit value=' Goster '>"&chr(13) Response.Write "</td>"&chr(13) Response.Write "</tr>"&chr(13) Response.Write "</form>"&chr(13) Response.Write "</table>"&chr(13) rst.Close End Sub ... |
| 19.08.2004, 08:54:32 |
Календарь
а может воспользоваться готовым календарем ? я юзаю DHTML Calendar Widget он поддерживает popup и flat mode, халявный и т.д. работает нормально под asp и asp.net ... |
| 19.08.2004, 10:30:06 |
start [/forum/topic.php?desktop=1&fid=18&tid=1395293]: |
50ms |
62ms |
| others: | 283ms |
| total: | 468ms |
