DirectoryEntry
Не могу саздать обьект. подскажите как сделать правельно!!! Писал так: DirectoryEntry entry=new DirectoryEntry(sPatch); DirectoryEntries myEnries=entry.Children; DirectoryEntry myDirectoryEntry=myEnries.Add"Sample", entry.SchemaClassName); myDirectoryEntry.CommitChanges(); Вылетает ошибка: General access denied error Exception Details: System.UnauthorizedAccessException: General access denied error ASP.NET is not authorized to access the requested resource. Consider granting access rights to the resource to the ASP.NET request identity. ASP.NET has a base process identity (typically {MACHINE}\ASPNET on IIS 5 or Network Service on IIS 6) that is used if the application is not impersonating. If the application is impersonating via <identity impersonate="true"/>, the identity will be the anonymous user (typically IUSR_MACHINENAME) or the authenticated request user. To grant ASP.NET write access to a file, right-click the file in Explorer, choose "Properties" and select the Security tab. Click "Add" to add the appropriate user or group. Highlight the ASP.NET account, and check the boxes for the desired access. ... |
| 08.07.2005, 15:51 |
DirectoryEntry
дай юзеру ASPNET права в АД Posted via ActualForum NNTP Server 1.2 ... |
| 08.07.2005, 19:02 |
start [/forum/topic.php?desktop=1&fid=18&tid=1393863]: |
149ms |
51ms |
| others: | 232ms |
| total: | 481ms |
