Sql Sever
Как перейти с локального сервера Sql Sever на сервер провайдера в Internet! ... |
| 07.04.2006, 15:05 |
Sql Sever
изменить строку подключения к серверу на ту, которую даст провайдер... в чем собственно проблема? Posted via ActualForum NNTP Server 1.3 ... |
| 07.04.2006, 15:11 |
Sql Sever
я и изменил , но выдается ошибка Server Error in '/' Application. Runtime Error Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine. Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off". <!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="Off"/> </system.web> </configuration> Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL. <!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/> </system.web> </configuration> ... |
| 07.04.2006, 15:12 |
Sql Sever
Помогите Server Error in \'/\' Application. Posted via ActualForum NNTP Server 1.3 ... |
| 07.04.2006, 15:14 |
Sql Sever
profil Помогите Server Error in \'/\' Application. Posted via ActualForum NNTP Server 1.3 Вствил это в web.config не помогло <configuration> <system.web> <customErrors mode="Off"/> </system.web> </configuration> ... |
| 07.04.2006, 15:15 |
Sql Sever
хм... надеюсь на сервере провайдера? Posted via ActualForum NNTP Server 1.3 ... |
| 07.04.2006, 15:18 |
Sql Sever
XiPoMaHtя и изменил , но выдается ошибка Server Error in '/' Application. Runtime Error Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine. Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off". <!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="Off"/> </system.web> </configuration> Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL. <!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/> </system.web> </configuration> так измените как он просит в web-config mode="RemoteOnly" вообще скорее всего вы ошиблись в строке подключения или неправильно ее используете (где определяете в тексте программы или в web config-e ) или провайдер в sql server-e не дал необходимые права пользователю через которого вы полключаетесь! проверьте все внимательно! ... |
| 07.04.2006, 15:21 |
Sql Sever
Если прописал ConnectString в web.config,то SqlDataSource1 не обходимо прописывать ConnectString ... |
| 07.04.2006, 15:28 |
Sql Sever
это что за шифровка? Posted via ActualForum NNTP Server 1.3 ... |
| 07.04.2006, 15:33 |
Sql Sever
profil это что за шифровка? Posted via ActualForum NNTP Server 1.3 <?xml version="1.0"?> <configuration> <connectionStrings> <add name="Personal" connectionString="Data Source=.\SQLExpress;Integrated Security=True;User Instance=True;AttachDBFilename=|DataDirectory|Personal.mdf" providerName="System.Data.SqlClient" /> <remove name="LocalSqlServer"/> <add name="LocalSqlServer" connectionString="Data Source=.\SQLExpress;Integrated Security=True;User Instance=True;AttachDBFilename=|DataDirectory|aspnetdb.mdf" /> </connectionStrings> <system.web> <pages styleSheetTheme="White"/> <customErrors mode="RemoteOnly"/> <compilation debug="false"/> <authentication mode="Forms"> <forms loginUrl="Default.aspx" protection="Validation" timeout="300" /> </authentication> ... |
| 07.04.2006, 15:40 |
Sql Sever
XiPoMaHtЕсли прописал ConnectString в web.config,то SqlDataSource1 не обходимо прописывать ConnectString Лучше всего создать отдельный компонент который будет возвращать строку подключения! и вызывать его во всех запросах к БД. Или прописать в web.config (только в нем больше нигде не надо!) тогда sql server сможет использовать пул подключений(!) для вашего приложения, будет ли такое в первом варианте не знаю! зы определять строку в каждом запросе к БД моральное уродство!!! ... |
| 07.04.2006, 15:46 |
Sql Sever
У меня есть такие данные Server: sql1.vwdhosting.net,1435 Database: XiPoMaHt-37 (size = 3 Mb, log size = 1 Mb) Login: XiPoMaHt-37 Как мне подключиться,если это возможно .... помогите,плиз просто уже нет сил ... |
| 07.04.2006, 15:49 |
Sql Sever
user id=XiPoMaHt-37;password=ПАРОЛЬ;data source='sql1.vwdhosting.net';initial catalog=XiPoMaHt-37 Posted via ActualForum NNTP Server 1.3 ... |
| 07.04.2006, 15:57 |
Sql Sever
profil user id=XiPoMaHt-37;password=ПАРОЛЬ;data source='sql1.vwdhosting.net';initial catalog=XiPoMaHt-37 Posted via ActualForum NNTP Server 1.3 а порт не надо указывать 1435 ... |
| 07.04.2006, 16:00 |
Sql Sever
надо Posted via ActualForum NNTP Server 1.3 ... |
| 07.04.2006, 16:01 |
Sql Sever
ConnectionString="data source='sql1.vwdhosting.net,1435';database='XiPoMaHt-37'; user id='XiPoMaHt-37';password=ПАРОЛЬ;" ... |
| 07.04.2006, 16:02 |
Sql Sever
автор<add name="LocalSqlServer" connectionString="Data Source=.\SQLExpress;Integrated Security=True;User Instance=True; AttachDBFilename=|DataDirectory|aspnetdb.mdf " /> Чё то ты вообще стессуешь не по теме - причём тут строка подключения - у тебя mdf лежит в проекте, что тебе надо от хостера??? просто спроси установлени ли у них SQL 2005 - express - это во первых... а во вторых - действительно добейся вывода полного описания ошибки - тогда и начинай стрессовать... ... |
| 07.04.2006, 16:03 |
Sql Sever
ЮщенкоИли прописать в web.config (только в нем больше нигде не надо!) тогда sql server сможет использовать пул подключений (!) ... А как это работает и почему это так здорово? ... |
| 07.04.2006, 16:05 |
Sql Sever
Galant ЮщенкоИли прописать в web.config (только в нем больше нигде не надо!) тогда sql server сможет использовать пул подключений (!) ... А как это работает и почему это так здорово? Кому что нравится а работает примерно так Код: plaintext 1. ... |
| 07.04.2006, 16:08 |
Sql Sever
Спасибо за помощь,но я так и делал ,но опять таже ошибка что и выше ... |
| 07.04.2006, 16:09 |
Sql Sever
Galant ЮщенкоИли прописать в web.config (только в нем больше нигде не надо!) тогда sql server сможет использовать пул подключений (!) ... А как это работает и почему это так здорово? sql server автоматически организует связный пул подключений для веб-страниц с одинаковыми строками подключения.... чтобы несколько клиентов могли одновременно использовать одну строку подключения не создавая каждый раз новое подключение..... что повышает производительность ... |
| 07.04.2006, 16:11 |
Sql Sever
код default.aspx <%@ Page Language="C#" AutoEventWireup="true" CodeFile="Default.aspx.cs" Inherits="_Default" %> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml" > <head runat="server"> <title>Untitled Page</title> </head> <body> <form id="form1" runat="server"> <div> <br /> <asp:DataGrid ID="MyDataGrid" runat="server"> </asp:DataGrid> </div> <asp:Button ID="Button1" runat="server" OnClick="Button1_Click" Text="Button" /> </form> </body> </html> код default.aspx.cs using System; using System.Data; using System.Configuration; using System.Web; using System.Web.Security; using System.Web.UI; using System.Web.UI.WebControls; using System.Web.UI.WebControls.WebParts; using System.Web.UI.HtmlControls; using System.Data.SqlClient; public partial class _Default : System.Web.UI.Page { protected void Page_Load(object sender, EventArgs e) { } protected void Button1_Click(object sender, EventArgs e) { SqlConnection myConn = new SqlConnection("data source='sql1.vwdhosting.net,1435';User ID='XiPoMaHt-37';Password=P;initial catalog='XiPoMaHt-37'"); SqlDataAdapter myCmd = new SqlDataAdapter("CREATE TABLE [dbo].[tbKSA] ([idShop] [int] NOT NULL)", myConn); SqlDataAdapter myCmd1 = new SqlDataAdapter("select * from tbKSA", myConn); DataSet ds = new DataSet(); myCmd1.Fill(ds, "tbKSA"); MyDataGrid.DataSource = ds.Tables["tbKSA"].DefaultView; MyDataGrid.DataBind(); } } может кто заметит ошибку ... |
| 07.04.2006, 16:14 |
Sql Sever
> Спасибо за помощь,но я так и делал ,но опять таже ошибка что и выше то что выше, это не ошибка :) добейтесь, для начала, что бы сервер вам вернул ошибку, а только после этого можно будет пытаться их устранять Posted via ActualForum NNTP Server 1.3 ... |
| 07.04.2006, 16:14 |
Sql Sever
profil > Спасибо за помощь,но я так и делал ,но опять таже ошибка что и выше то что выше, это не ошибка :) добейтесь, для начала, что бы сервер вам вернул ошибку, а только после этого можно будет пытаться их устранять Posted via ActualForum NNTP Server 1.3 Модет подскажите как вернуть ошибку?!Но спасибо за участие и помощь ... |
| 07.04.2006, 16:17 |
Sql Sever
автордобейтесь, для начала, что бы сервер вам вернул ошибку, а только после этого можно будет пытаться их устранять помоему самый разумный совет... а решить вопрос можно закомментировав вот эти строки в конфиге Код: plaintext 1. ... |
| 07.04.2006, 16:19 |
start [/forum/topic.php?desktop=1&fid=18&tid=1392705]: |
148ms |
36ms |
| others: | 193ms |
| total: | 413ms |
