DataAdapter
Private Sub Page_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load Dim conn As New System.data.OleDb.OleDbConnection("параметры коннекта") Dim cmd As String cmd = "SELECT * from myTable" Dim adapt As New System.Data.OleDb.OleDbDataAdapter(cmd, conn) Dim ds As New DataSet adapt.Fill(ds, "myTable") 'здесь ругается DataGrid1.DataSource = ds DataGrid1.DataMember = "myTable" DataGrid1.DataKeyField = "ID" DataGrid1.DataBind() End Sub Выдает ошибку Incoorect syntax near null Подскажите, в чем ошибка? ... |
| 24.05.2006, 15:57 |
start [/forum/topic.php?desktop=1&fid=18&tid=1392456]: |
163ms |
32ms |
| others: | 236ms |
| total: | 476ms |
