можно ли imagebuttone drawline ом порисовать
Может кто подскажет алгоритм действий .... есть ImageButton при клике на нем нужно прорисовать линии это вообще реально на VB.Net ? спасибоРоссия - единственная страна, где можно сбыть мечту!! ... |
| 30.06.2006, 16:08 |
Вот пример как можно картинку нарисовать. <%@ Page Language="VB" %> <%@ import Namespace="System.Drawing" %> <%@ import Namespace="System.Drawing.Imaging" %> <%@ import Namespace="System.Drawing.Drawing2D" %> <script runat="server"> Private Sub Page_Load(sender As Object, e As EventArgs) ' Set the page's content type to JPEG files ' and clear all response headers. Response.ContentType = "image/jpeg" Response.Clear() ' Buffer response so that page is sent ' after processing is complete. Response.BufferOutput = True ' Create a font style. Dim rectangleFont As New Font( _ "Arial", 10, FontStyle.Bold) ' Create integer variables. Dim height As Integer = 100 Dim width As Integer = 200 ' Create a random number generator and create ' variable values based on it. Dim r As New Random() Dim x As Integer = r.Next(75) Dim a As Integer = r.Next(155) Dim x1 As Integer = r.Next(100) ' Create a bitmap and use it to create a ' Graphics object. Dim bmp As New Bitmap( _ width, height, PixelFormat.Format24bppRgb) Dim g As Graphics = Graphics.FromImage(bmp) g.SmoothingMode = SmoothingMode.AntiAlias g.Clear(Color.LightGray) ' Use the Graphics object to draw three rectangles. g.DrawRectangle(Pens.White, 1, 1, width - 3, height - 3) g.DrawRectangle(Pens.Aquamarine, 2, 2, width - 3, height - 3) g.DrawRectangle(Pens.Black, 0, 0, width, height) ' Use the Graphics object to write a string ' on the rectangles. g.DrawString("ASP.NET Samples", rectangleFont, SystemBrushes.WindowText, New PointF(10, 40)) ' Apply color to two of the rectangles. g.FillRectangle( _ New SolidBrush( _ Color.FromArgb(a, 255, 128, 255)), _ x, 20, 100, 50) g.FillRectangle( _ New LinearGradientBrush( _ New Point(x, 10), _ New Point(x1 + 75, 50 + 30), _ Color.FromArgb(128, 0, 0, 128), _ Color.FromArgb(255, 255, 255, 240)), _ x1, 50, 75, 30) ' Save the bitmap to the response stream and ' convert it to JPEG format. bmp.Save(Response.OutputStream, ImageFormat.Jpeg) ' Release memory used by the Graphics object ' and the bitmap. g.Dispose() bmp.Dispose() ' Send the output to the client. Response.Flush() End Sub 'Page_Load </script> <html> <head> </head> <body> <form runat="server"> </form> </body> </html> Вот статья как можно сделать прямую ссылку на картинку: http://www.aspnetmania.com/Articles/Article/20.html Добавляешь парамерт, в зависимости от которого надо либо рисовать, либо не рисовать---------------------------------------- Knowledge is power! My site ... |
| 30.06.2006, 16:43 |
хм ... так тут просто картинка... :( , у меня задача прямо на ImageButton е линии рисовать..., боюсь это вообще невыполнимая задача... а как можно просто рисунок наложить(*.ico там или *.gif) поверх имджбуттона, в заданных координатах никто не знает?Россия - единственная страна, где можно сбыть мечту!! ... |
| 03.07.2006, 09:19 |
А какая собсно разница то? Имажбуттон картинку из атрибута scr своего берет - это ж не его собственность Многие вещи нам непонятны не оттого, что наши понятия слабы, а оттого, что данные вещи не входят в круг наших понятий. ... |
| 03.07.2006, 13:14 |
start [/forum/topic.php?desktop=1&fid=18&tid=1392115]: |
149ms |
27ms |
| others: | 201ms |
| total: | 412ms |
